Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
Those with 5.3's weigh in
by Speak2Mountain - 02/23/20 04:26 PM
wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
wjamyers, L00btech, Lucase483, Chaucha, UofA
70790 Registered Users
28 registered members (FordCapriDriver, domer10, Black_Thunder, Char Baby, carlprop, ArrestMeRedZ, 3 invisible), 1,190 guests, and 23 spiders.
Topics301,852
Posts5,203,955
Members70,790
cold radiator hose #5331063 01/24/20 12:43 PM
M
macdole99 Offline OP
M
He guys have a quick question. i have an 02 qx4 (pathfinder clone) i had to replace a hose on my water pipe. i get everything done, bleed the system but something peculiar is happening. the car is not running hot, i have my scanner and im getting temps of 187 to 194 on it. i drove several miles no over heating but the lower radiator hose is cold. my first thought was the thermostat went out but it was not giving my any trouble and on top of that im getting great heat inside. any ideas what could be causing the cold lower hose? im stumped
2002 qx4 107k
1999 altima 235k
2002 tahoe 275k
Re: cold radiator hose [Re: macdole99] #5331078 01/24/20 01:00 PM
J
JLTD Offline
J
IMO you've got a bubble. Try parking with the front higher than the rear and let it run awhile with the cap off.
"Several miles" in winter isn't far enough to overheat.
Lates.
Re: cold radiator hose [Re: macdole99] #5331100 01/24/20 01:31 PM
A
atikovi Offline
A
Drive it longer. If it's a bypass hose it might not get warm until the thermostat is fully open.
Re: cold radiator hose [Re: macdole99] #5331108 01/24/20 01:42 PM
StarCaller Offline
Quote
this ^
Re: cold radiator hose [Re: macdole99] #5331227 01/24/20 04:20 PM
M
mk378 Offline
M
You are experiencing the phenomena that scientists call "normal operation." The lower radiator hose is where coolant leaves the radiator after its heat has been, umm, radiated away. If you're driving through winter air it's going to stay really cold.
Re: cold radiator hose [Re: macdole99] #5331307 01/24/20 06:38 PM
2
2010Civic Offline
2
He lives in Alabama. Can't imagine it's that cold.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: cold radiator hose [Re: mk378] #5331327 01/24/20 07:10 PM
T
Tman220 Offline
T
^^This! It doesn't have to be as cool out as you think to find a cold radiator hose during cool weather. The Qx4 has a tow capacity of 5000 lbs, the cooling system is designed to keep the engine cool when its 110 degrees out while towing 5000 lbs... Therefore this engine has plenty of excess cooling capacity when its cool out, not towing, and when you are using some engine heat for the interior.
The fact of the matter is your engine is staying cool and stable, your heat is hot, its working as designed. It's not unusual to trap a little air while opening up the system, keep the overflow topped up and you will be fine at this point.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 166k
2004 Civic LX M5 186k
2007 Camry 2.4 245k
2016 Victory Vegas
Re: cold radiator hose [Re: macdole99] #5331361 01/24/20 08:22 PM
M
michaelluscher Offline
M
The temperature seems right
However I will say, if you didn't bleed it with a vacuum filler or spill free funnel, their still is an air pocket in there
Rebleed, and check again
2006 Toyota Camry SE V6
131k
