hand sanitizer
by matrass - 04/09/20 08:57 AM
Sludge concerns
by otis24 - 04/09/20 08:43 AM
Anyone Ever Have Their OEM rims Powder Coated?
by LoneRanger - 04/09/20 07:59 AM
Group 7 V2222
by GumbyJarvis - 04/09/20 03:56 AM
I'm looking for a 0w30 A5 B5 oil
by Marco620 - 04/08/20 11:57 PM
Does anyone put heat shrink tubing over a connector plug?
by motor_oil_madman - 04/08/20 10:39 PM
Anyone ‘excited’ for API SP/GF-6?
by addyguy - 04/08/20 10:30 PM
O'Reilly online learning for .gov email addresses
by spackard - 04/08/20 10:26 PM
Welding Helmet Fogging Up
by George7941 - 04/08/20 09:54 PM
Detroit 4-53T 2009 Ford F350 Update.:)
by A310 - 04/08/20 09:48 PM
Thoughts on CAFE standards
by otis24 - 04/08/20 09:20 PM
PUP amazon 5w-20
by Koncrete_Cam - 04/08/20 08:54 PM
Duralube Trans Shudder Fixx question
by soulburner - 04/08/20 08:36 PM
Number of Spare Magazines You Consider Adequate?
by 2015_PSD - 04/08/20 08:24 PM
Troy Bilt TB6044XP string trimmer dies when hot
by 92saturnsl2 - 04/08/20 07:18 PM
JD Yanmar deisel engine
by yankees1 - 04/08/20 07:14 PM
PQIA Looks at Leading 0W-20's
by Jackson_Slugger - 04/08/20 07:03 PM
Marine oil in a passenger car engine
by Thunderbolt - 04/08/20 06:50 PM
edot1, Tori, siroisma, i4ni, Monica
71133 Registered Users
112 registered members (AandPDan, 97prizm, 1978elcamino, 53' Stude, 77GrandPrix, 007, 8 invisible), 2,054 guests, and 19 spiders.
Topics303,813
Posts5,242,345
Members71,133
2006 Acura TSX Buying Advice #5328913 01/21/20 05:35 PM
M
maverickfhs Offline OP
M
Looking at a 06 TSX navigation with 200K, in quite good condition cosmetically and less than $2000.
Needs tires, brakes and some TLC. Radio doesn't work, so as the clock and temperature view - right above the navigation.
All the controls are working. Does anyone know what could be the issue for the clock and temperature view not showing up?
I love the car and will probably pull the trigger, but just being realistic and asking if fixing above issues can add up quick? Thanks for all the help thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5328923 01/21/20 05:46 PM
M
madeej11 Offline
M
Might not be what you want to hear but I would not pull the trigger on the deal. Don't ask me why but it just doesn't seem pass the sniff test. Too much mileage and probably a lot of nagging little issues. Put your 2 grand into another vehicle. Good luck.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5328948 01/21/20 06:37 PM
A
atikovi Offline
A
$2,000 is a good price if it looks and runs good even with those miles. Transmission would be the biggest concern. Clock and temp aren't something worth fixing on something like that unless you get lucky and it turns out to be a fuse.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5328957 01/21/20 06:46 PM
T
t1snwrbrdr12 Online Content
Online Content
T
Listen to it on a cold start for engine rattle, watch for oil smoke out the tail pipe. K24’s are good but known to burn oil and stretch timing chains.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5328967 01/21/20 06:58 PM
G
Gebo Online Content
Online Content
G
You know you got brakes and tires to do. Do you know the owner or have the service records? How many previous owners?
Have you done a car fax? I'd try and get a little more info.
Hey, for 2K and add 1K for tires and brakes you'd be in decent shape.
I like tinkering and fixing up old girls. I'd go for it.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5328992 01/21/20 07:20 PM
J
JeffKeryk Offline
J
$2K is not a lot for a 2006 TSX unless it's a beater.
Our 2006 has $195K and is perfect. With proper service, I see another 50K to 100K.
If the body and interior are good, you like the car and you can work on it, I say go for it.
Brakes are easy; do a flush when you are down there.
Service the transmission right away. All good!
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329018 01/21/20 07:40 PM
M
M
Carfax is clean, 2nd owner and have some maintenance records as well as things show up on the car history.
Transmission has been serviced by the dealer around 100K, so not really concerned since hopefully not the factory fill!
I'll probably have to overlook on the clock and temp issues, was hoping might be a simple fix.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329061 01/21/20 08:12 PM
ctechbob Offline
Add in about $100 in compliance bushings (If you do the work yourself and have tools, or add another $90 if you buy the tool) if they've not been done. By 200k they're shot and will start chewing up your brand new tires.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329086 01/21/20 08:52 PM
R
rtree Offline
R
The radio PCB is probably bad. Somewhat common on 1st gen TSX. You can search the acurazine tsx or tsxclub forums for posts on how to replace. I replaced the board in my wife's 2004 TSX back in 2015, but I think the parts is now discontinued.
There isn't really any go-to double DIN dash kit if you want to go aftermarket. The Metra kit gets pretty bad reviews.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329283 01/22/20 08:05 AM
J
jeepman3071 Online Content
Online Content
J
If they serviced the trans at the dealer it shows they at least did some maintenance. If it runs and drives okay then $2000 is a fair deal. Around here it's hard to find any car for that price that isn't falling apart.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329315 01/22/20 09:10 AM
B
bubbatime Offline
B
I sold a 2010 TSX Tech that had good tires, good brakes, and perfect maintenance history with 240,000 miles a few months ago for 2750.
Re: 2006 Acura TSX Buying Advice [Re: maverickfhs] #5329349 01/22/20 09:53 AM
B
brages Offline
B
I was looking for a nice little commuter car two years ago and all the TSXs (manual of course) I saw were priced at $5k-10k. Nothing cheap and good. I ended up getting a Volvo S40 for quite a bit less than any of the TSXs I saw.
$2k for a good car with an interior and exterior in good shape is a bargain to me.
Learn about the self-serve junkyards in your area and you may be able to find all the little stuff you need to get it to 100%. IMO, if the car runs good and looks good, you should invest a bit and fix it up.
