Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
124 registered members (762fermeandyou, 390pi, 1978elcamino, aircooled, ABerns, 2013ecof150, 14 invisible), 2,547 guests, and 20 spiders.
Topics301,887
Posts5,204,587
Members70,796
Leaf spring advice. #5327128 01/19/20 02:19 PM
M
mpack88 Offline OP
M
As I was refilling my differential I noticed my leaf springs are turn somewhat is this a normal thing to happen or do I need some work done?
Re: Leaf spring advice. [Re: mpack88] #5327133 01/19/20 02:27 PM
H
HangFire Offline
H
Check another truck of the same vintage. Usually there is a retaining strap to prevent that.
Various musings: http://hangfire.net
Re: Leaf spring advice. [Re: mpack88] #5327144 01/19/20 02:48 PM
Chris142 Online Content
Online Content
I put a hose clamp on mine to stop that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Leaf spring advice. [Re: mpack88] #5327149 01/19/20 02:55 PM
AZjeff Offline
Leaf spring clamps
[Linked Image]
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Leaf spring advice. [Re: Chris142] #5327154 01/19/20 03:07 PM
E
eljefino Offline
E
+2
Re: Leaf spring advice. [Re: mpack88] #5327198 01/19/20 04:48 PM
gathermewool Offline
Duct tape
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Leaf spring advice. [Re: mpack88] #5327298 01/19/20 06:50 PM
L
Lubener Offline
L
You will need to loosen the u bolts, shock and take the load off the spring to shift it back in place. Once you do that, replace the missing leaf spring clamp, set the car back in the ground and tighten up the u bolts and shock. Radiator hose clamps as mentioned won't pull that spring back in place and hold it there for any length of time.
The "thinking" man's friend.
Re: Leaf spring advice. [Re: Lubener] #5327301 01/19/20 06:52 PM
I'm not saying it's the correct way to do it, but I got my buddy home 100's of miles away with much worse springs, using nothing but a large dead-blow and TONS of duct tape in his old F250. It do recall it taking a long time to bang the leaf spring back into place, but it did work.
Re: Leaf spring advice. [Re: gathermewool] #5327302 01/19/20 06:54 PM
L
Lubener Offline
L
Why beat the snot out of the spring and tape it up like that, that's laughable. I am sure he is looking for a long term repair.
Re: Leaf spring advice. [Re: Lubener] #5327316 01/19/20 07:09 PM
Haha! It WAS a short-term repair for a couple of no-nothing, broke-[censored] college grads. We were on our way home from college. He dropped me off in the mid-Atlantic, on his way south. He couldn't stay long enough for a better repair and just needed something good enough. We had already made it a few hundred miles to my home without the spring getting any worse, so the 20 minutes spent banging it back into place and then duct-taping it for SOME measure of safety seemed better than doing nothing at all.
My point, is that banging it wasn't that big of a deal. The duct tape was purely anecdote to complete the story, not as an offer of a permanent fix.
Re: Leaf spring advice. [Re: mpack88] #5327412 01/19/20 09:08 PM
Dave9 Offline
Meh, nothing wrong with beating it back into position. There is no benefit to loosening the u-bolts and shocks, but you might want a squirt of oil over and under that leaf to help ease the process. Be pushing with one hand while using the other to hit it closer to center, 1/3rd to 1/2 way out, not all the way out on the end which the spring will just absorb more.
I would not touch the U-bolts unless necessary because you just might find they don't come loose then you need to replace them, money wasted if you can move it while leaving them alone, unless they're already at the next stage of rust where they're about to fall off and so should be replaced anyway.
Re: Leaf spring advice. [Re: mpack88] #5327540 01/20/20 06:16 AM
K
Kira Offline
K
Just for giggles, see how close a spring shop is to you. Go and ask.
There's a big, old, busy-as-the-dickens one in Hackensack.
I wonder if they'd do that job while the customer waited.
Re: Leaf spring advice. [Re: mpack88] #5327590 01/20/20 07:58 AM
W
WyrTwister Offline
W
Seen lots of leaf springs like that . Is it OK ? Can not say . Fix it if it makes you feel better .
Wyr
God bless
Re: Leaf spring advice. [Re: Dave9] #5327592 01/20/20 07:58 AM
M
MasterSolenoid Offline
M
I agree with this. Also, the oil could help - big time.
How about jacking the vehicle UP before realigning the Springs ?
That may take some weight off them to make the job easier.
And then add NEW Spring Brackets.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Leaf spring advice. [Re: mpack88] #5327597 01/20/20 08:00 AM
M
Miller88 Offline
M
Get spring clamps from a spring shop for it. Advance sells them but they are $27 a set. The same exact spring clip from my local spring shop was $1.53.
Also, when the springs in my Cherokee start to fan out like that, it's from the u bolts stretching or backing off.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
