Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
118 registered members (apollo18, 928, 2012AccentSE, Anduril, ABomb369, 750IX, 10 invisible), 2,275 guests, and 23 spiders.
Topics301,698
Posts5,200,852
Members70,759
Toyota Oem filter mileage #5326165 01/18/20 10:22 AM
B
Bettez88 Offline OP
B
I was surfing the web and stumbled on to this site and I was intrigued on what it said:
Oil Specifications
The 2009 Corolla requires 4.5 quarts of 100 percent synthetic 0W-20 motor oil for maximum performance. It requires 5W-20 OE for normal performance. The oil filter typically needs to be replaced every 25,000 miles. The oil drain plug is torqued to between 27 and 29 ft-lbs.
Can the Oem filter really be good for 25k?! The manual states changing the oil every 5k
https://itstillruns.com/2009-toyota-corolla-oil-requirements-7670221.html
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Toyota Oem filter mileage [Re: Bettez88] #5326174 01/18/20 10:30 AM
PimTac Offline
Don’t believe everything you read.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Toyota Oem filter mileage [Re: PimTac] #5326177 01/18/20 10:32 AM
SatinSilver Offline
Yeah really. The normal interval for the oem filter is 10k. Not sure I'd want to go past that mileage on a $4 filter. At least that's what they run here.
You could probably go 25k on a Fram Ultra if you wanted to. They are rated for 20k and kind of look like new with 20k on them.
Re: Toyota Oem filter mileage [Re: Bettez88] #5326204 01/18/20 11:06 AM
W
wdn Online Content
Online Content
W
That is not a Toyota website. You can get 2009 Toyota Corolla specs from Toyota.
The oil change interval on the 2009 Corolla is 5,000 miles. It's in the owners manual.
Re: Toyota Oem filter mileage [Re: SatinSilver] #5326231 01/18/20 11:31 AM
L
Linctex Offline
L
2 x oil changes?
I would agree.
The Fram Ultra has very good flow, even when heavily loaded,
and the efficiency numbers are higher than most all commonly available oil filters.
Re: Toyota Oem filter mileage [Re: wdn] #5326236 01/18/20 11:38 AM
CR94 Offline
Originally Posted by wdn
... The oil change interval on the 2009 Corolla is 5,000 miles. It's in the owners manual.
At the time, Toyota's recommended interval may have assumed non-synthetic oil. For later ones with the same engine, 10k intervals are officially recommended for (synthetic 0W-20) oil and filter. However, the OE Toyota filter I ran for about 18.5k (two oil changes) in my car (which has essentially the same engine) came out looking good-as-new, except the few barely visible carbon particles it had captured.
2011 Toyota Prius now at 109K
Re: Toyota Oem filter mileage [Re: Bettez88] #5326239 01/18/20 11:40 AM
W
wdn Online Content
Online Content
W
The factory interval on the '09 Corolla is 5,000 miles "oil and filter". Filter gets changed at every oil change.
Re: Toyota Oem filter mileage [Re: CR94] #5326253 01/18/20 11:54 AM
W
wdn Online Content
Online Content
W
The 2009 Corolla uses 0W20 synthetic. Again, no point going back and forth on this I have the 2009 Corolla maintenance interval manual right here. Sure car companies sometimes change their intervals different model years. I am responding to the false information on that web page listed by OP, that is about 2009 Corolla. If you want to follow your own maintenance methods on the same or different car go ahead.
https://www.toyota.com/t3Portal/doc...a%20SMG%20123138%20Eng%201st%20Print.pdf
Re: Toyota Oem filter mileage [Re: wdn] #5326260 01/18/20 12:08 PM
B
Bettez88 Offline OP
B
So just stick to my 5k synthetic oil changes then?
Re: Toyota Oem filter mileage [Re: wdn] #5326287 01/18/20 12:32 PM
R
Rolla07 Offline
R
+1
That 25k mile info is wrong. Oil and dilter change is 5k miles. (8000km). I have gone to 6200 miles with no issue. I wouldnt exceed the interval much further. Worst case use a Fram Ultra and extend. These engines are easy on oil.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Toyota Oem filter mileage [Re: Bettez88] #5326317 01/18/20 01:12 PM
G
Gebo Offline
G
If most of your driving is short trips, less than 10 miles, I would change at 3K. I do this and change the Toyota OEM filter every oil change as they are so inexpensive anyways.
Personally, I would never go over 5K with any oil. As you can see, I keep my cars loooong term and that does influence my short OCI. My belief is car manufacturers have lengthened
the OCI's because they want to sell more cars. I could be wrong. I listen to agco.com podcast and they say they hardly ever did engine repairs years ago when everyone did the 3K OCI. Since we have trended towards the long OCI's they do engine repairs every week. They are convinced the repairs have increased because we have stretched out our OCI's. This makes sense to me but I have no way to prove it. They say they see it. That's all I know.
I will say this. It sure makes me more confident my cars will last when I drain the oil and it is not black as the resin in my gas grill. LOL
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Toyota Oem filter mileage [Re: Bettez88] #5326389 01/18/20 02:38 PM
danez_yoda Offline
The OEM filter does 10K easily. My wifes van is the yzza1 and at 10K miles it is straight as an arrow and still pliable. I can it does not fall apart when inspected. Yes a $4 filter can really go the distance which is why I run them.
Your "maintenance required" light comes on solid at 5K so I would just go by that and keep life easy. Walmart oil and a $4 filter are cheap.
Re: Toyota Oem filter mileage [Re: danez_yoda] #5326409 01/18/20 03:07 PM
B
Bettez88 Offline OP
B
So run supertech 0w20 full synthetic for 5k?
Re: Toyota Oem filter mileage [Re: Bettez88] #5326477 01/18/20 04:58 PM
CR94 Offline
... So run supertech 0w20 full synthetic for 5k?
You're free to do whatever you like. IF the engine is sludge-free and IF you're doing mostly longer trips, the Supertech oil and a Toyota filter can both easily go 8-10k safely. Not so, if you're doing a lot of short trips in cold weather.
Toyota doubled their recommended interval to 10k in late 2009 on most models in non-severe service.
Re: Toyota Oem filter mileage [Re: CR94] #5326559 01/18/20 07:16 PM
Bryanccfshr Offline
They didn’t just change the oil recomendation to double the oil recomendation and there is a good reason why they kept the older models at a 5 k OCI.
One thing they did to most the new engines around 2009 and later is they increased the sump capacity, they also went to rollerized valvetrain the same time also reducing the stress on the engine oil, they also went to cartridge oil filters with these updates.
If you have a bucket tappet valve train engine with the lower oil sump capacity you can take or leave the recommendation of 0w20 back spec, I would just run the original oil recommendation (most were 5w20 or 5w30 at this time) and grade for 5 k in those engines. The bucket lifters are going to have more friction and deplete the additives in engine oil faster than rollerized valve trains, that combined with smaller sumps says stick with 5 k .there are major mechanic differences beyond the oil that allow the longer OCI to be recomended.
The back spec is mainly so that the toyota dealers could use a smaller number of fluids in the service departments.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
