Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Boris_Be, NHR, zip15, PeterNST, SkinnRS
70796 Registered Users
120 registered members (01rangerxl, 762fermeandyou, 53' Stude, 2015_PSD, 928, 69GTX, 14 invisible), 2,547 guests, and 25 spiders.
Topics301,888
Posts5,204,618
Members70,796
Ravenol MTF-2 #5324849 01/16/20 10:36 PM
E
E365 Offline OP
E
Just bought some Ravenol MTF-2 (75w-80 GL-4) for the transmission in my 2017 MINI Cooper Clubman S ALL4 6-speed manual. It’s an Aisin GS6X60BA transmission that specs BMW MTF-LT2. Purchased from Blauparts. About $22/liter with tax and shipping.
I don’t see any post here about it so I thought I’d put up some pics.
Hope to swap the fluid next week.
https://www.ravenolamerica.com/transmission-fluid/75w-80-manual-transmission-fluid-ravenol-mtf-2/
Whatever's on sale...
Re: Ravenol MTF-2 [Re: E365] #5324880 01/17/20 12:11 AM
MolaKule Offline
Global Moderator
Global Moderator
It has been discussed in many threads on MTF.
If you can get a VOA that would be great to see if the formula and viscosity has changed.
Originally Posted by MolaKule
NOTE: This list is only a “suggested” list of MTFs. It is not an endorsement nor a critique of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear.
A. These MTL fluids are closest to a Kinematic Viscosity of 6.X [email protected] (About the same viscosity as a Dexron VI) and SAE 70 or so:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M65 5-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
6. Redline MT-LV SAE Viscosity Grade 70W/75W Vis [email protected]°C
B. The next higher viscosity MTL would be the 7.0 to 7.6 [email protected] versions (SAE 70W75) (About the same viscosity as the original DexronIII/Merc)
1. Royal Purple's Synchromax
2. Ravenol MTF-2
3. Honda MTF
4. VW part number G052512A2
5. GM Manual Transmission and Transfer Case Fluid
6. BMW (Pentosin MTF 2) MTF-LT-1, 2 ,3
7. Tutelo (Petronus, Italy, Product Code 1402)
8. Pentosin Pro Gear 70W75 (Australia)
9.0 Pentosin FFL-4
10. Redline Power Steering Fluid
11. RAVENOL STF
Note: C, D and E are often considered popularly as “synchromesh” fluids.
C. The next higher viscosity MTL group is in the 8.0 cSt to 8.9 cSt Range would be:
1. Castrol Syntrans V FE (8.0cSt)
2. Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
3. BG Synchroshift II (8.2 cSt)
4. Valvoline MTF Part Number 811095 8.8 cSt
5. RAVENOL PSA (8.9 cSt)
D. The next higher viscosity MTL group in the 9.0 to 9.5 cSt range is (SAE 75W80):
1. Mopar Type MS-9417 MTL 9.0 cSt
2. Pennzoil Synchromesh 9.0 cSt
3. RAVENOL SSG 9.5 cSt
E. The next group of MTL’s are in the 9.6 to 10.X cSt range (SAE 75W80):
1. Redline MTL 75W80
2. Amsoil MTF (9.7 cSt)
3. GM Synchromesh’s
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF (Carries a GL-5 rating as well)
6. Lodexol (Morris Lubricants) MTF
7. Motylgear 75W-80
F. The next higher viscosity MTL would be a [email protected] and SAE 75W85:
1. Redline MT-85
G. The next higher viscosity MTLs in the 14-15 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission Fluid XT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-90
9. LiquiMoly 75W-90 GL4
10. Pennzoil 75W90 GL-4
11. Subaru High Performance Gear Oil (HPGO; carries GL-4 and GL-5 ratings).
I'm a Student Pilot. Frightening, isn't it?
Re: Ravenol MTF-2 [Re: E365] #5326685 01/19/20 12:01 AM
E
E365 Offline OP
E
^ Thanks 👍🏻
Just changed the fluid today.
