2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
82 registered members (ARCOgraphite, 03s, askani79705, AlienBug, 2015_PSD, 9 invisible), 1,694 guests, and 34 spiders.
Topics305,926
Posts5,282,969
Members71,537
Maintenance Doseage of Techron #5323673 01/15/20 05:32 PM
B
blufeb95 Offline OP
B
I'm looking at buying a newer Hyundai Sonata SE and me being me was thinking about all the pedantic maintenance things I'm going to do to it.
Looking at datasheets, it looks like Techron Concentrated Fuel System cleaner probably has about at much PEA (datasheet says 25-45% but some anecdotes say probably ~32%) as Redline SI-1(~28-34%) and Redline recommends something like 1.5-2oz per 10 gallons of gasoline as maintenance treatment, so I was looking and there's that Techron marine fuel system treatment that's sold in 4oz bottles it appears to have the same concentration of PEA as regular Techron Concentrated and also some stuff that I guess is supposed to help stabilize ethanol fuel, I was wondering what peoples opinions are of using a 4oz bottle of this in the tank every fill up as a maintenance dose because it seems like a convenient way to add a small dose to the tank without having to pour out of a larger bottle and measure it out. A 4oz bottle of this cost about as much as a 12oz bottle of the regular though but with the 12oz I'd have to measure out a small amount and running a full 12oz bottle every tank would easily excede Chevron's recommendation of using a max of 5 bottles between oil changes, assuming I change the oil every 7500-10000mi and get about 500mi per 18.5gal tank using the 4oz bottles would be about the equivalent of using 4 or 5 20oz bottles over the OCI.
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323681 01/15/20 05:48 PM
wemay Offline
Buy the Sonata and just run Top Tier 50%+ of the time and enjoy the car. If piece of mind is what you're after, run Top Tier all the time and a bottle of your favorite PEA fuel injection cleaner every OCI.
19 VW Passat Wolfsburg TSI: Castrol Edge Pro LL IV Fe 0W20 + VW oil filter
13 Hyundai Santa Fe Sport 2.0T: Shell Rotella Gas Truck 5W30 + H/K oil filter
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323686 01/15/20 05:54 PM
V
Virtus_Probi Offline
V
I agree with wemay, just look for Top Tier fuel and then use an additive every so often if desired.
Let somebody else mix the detergents for you! ;^)
Costco is Top Tier if there is one near you, and some lesser known chains like Kwik Trip also sell TT gas.
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323702 01/15/20 06:07 PM
B
blufeb95 Offline OP
B
Around here we have Shell, Marathon, Phillips 66, and BP among the Top tier places, I'm planning on avoiding the gas they sell at Wal-Mart, Meijer, Kroger, Speedway, etc.. Out of the options I'm leaning towards Shell the most. While possibly fouling up the injectors is possibly a problem I should probably be more worried about the GDI valve situation, you think it'd be excessive to run a can of CRC GDI Intake valve and turbo cleaner through the intake before every oil change.
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323710 01/15/20 06:19 PM
H
hallstevenson Offline
H
Skip the additives. Really no need for them.
Nothing wrong with the gas sold by the (8) names you listed either, including the grocery stores or Speedway. I don't know about Marathons or BPs around you, but the ones here certainly don't advertise or claim that they sell Top Tier gas. You are more likely to get fresh fuel at the grocery store fuel stations and/or Speedway too.
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323766 01/15/20 07:27 PM
SHOPete Offline
+wemay. TT gas and a bottle of Techron at every oil change.
17 Hyundai GLS QSUD 5w-30 OEM filter
09 Corvette LS3 M1 5w-30 M1-113A
01 Toyota Tundra 135K PZ Euro 0W-40 OEM filter
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323878 01/15/20 09:48 PM
SubieRubyRoo Offline
If you're going to use additives over TT or say Chevron gasoline, do what the bottle says. Run tank down, dump in fuel additive, fill with gas, and bury the tach repeatedly. Ok, that last one was mine. LOL Don't mess with "maintenance" doses when wemay's advice will produce similar results with less fuss.
De omnibus dubitandum.
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323981 01/15/20 11:52 PM
A
ammolab Offline
A
If your car gets Techron at every fill up....
I wonder how many diet supplements/vitamins you require with each meal?
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Maintenance Doseage of Techron [Re: blufeb95] #5323989 01/15/20 11:59 PM
csandste Offline
I use Top Tier--- usually Costco, and Gumout or Techron (PEA) about every five thousand miles.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Maintenance Doseage of Techron [Re: blufeb95] #5324002 01/16/20 12:31 AM
R
ruSSrt Offline
R
Run a full tank of 92 TT gasoline once in a while and you'll be fine. Maybe after 100K+ miles start thinking about treatment/maintenance, but until then i would not worry about it.
2001 Ram 2500 Cummins
2005 VW Passat TDI
2011 Jeep Liberty 3.7L
Re: Maintenance Doseage of Techron [Re: blufeb95] #5324013 01/16/20 12:58 AM
Y
y_p_w Offline
Y
I remember back when Costco hasn't fully rolled out their CleanPower (now Kirkland Signature) program, they stated that stations were high volume and met all EPA requirements. They said that if the customer really insisted, they sold Chevron Pro-Gard.
I actually bought a case of Pro-Gard back when it was on special. I think it was less than $2 a bottle. It was supposed to treat up to 20 gallons but came in these big 20 oz bottles. I figured that the solvent was effectively just adding more fuel.
Re: Maintenance Doseage of Techron [Re: blufeb95] #5324223 01/16/20 10:18 AM
U
UG_Passat Offline
U
If you want to do "maintenance dosage", then get a bottle of Stabil, use that quickly in your car, lawnmower, etc.
Then refill that bottle with Techron, Redline, etc and you have something for measuring and dosing
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Maintenance Doseage of Techron [Re: blufeb95] #5324237 01/16/20 10:30 AM
J
jeepman3071 Offline
J
You don't need Techron unless there is an issue with the fuel system getting dirty, and that will realistically only happen if the fuel is sitting for a length of time. Modern fuels are really pretty good, especially top tier.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Maintenance Doseage of Techron [Re: blufeb95] #5324246 01/16/20 10:42 AM
N
nascarnation Offline
N
These are direct cylinder injection, right? I thought the additives were mostly for intake valve deposits from manifold injection?
Re: Maintenance Doseage of Techron [Re: nascarnation] #5324290 01/16/20 11:31 AM
L
Linctex Offline
L
Correct, I haven't seen anything that says PEA is actually helpful in GDI.
I do, however - run TCW-III 2-cycle oil at 640:1 (1 oz per 5 gallons) in my GDI 2.4L Kia Optima to help keep things lubed and clean.
