Originally Posted by clinebarger
Originally Posted by Chris142
This guy says to replace the engine. Not worth trying to fix.
https://youtu.be/xcN_WcGr4BU
And he's wrong.....It all boils down to "Mechanics" wanting to swap whole components! That engine wasn't badly sludged at all & didn't have a Follower failure....As he would have certainly said something!
He has no proof that the "Small Oil Passages" clogged up.....Because they didn't!
Ford redesigned the spark plugs & cylinder heads for 2008, With his alleged level of knowledge on this engine.....Why not state this? Too busy making engine noises?
Using Idenifix/Direct Hit as further proof?? While I like Direct Hit & even subscribe to it myself.....Some of the "Confirmed Fixes" should be taken with grain of salt!
Last but certainly not least.....The Ford repair procedure for timing chains & Phasers on this engine is BS!!!!!!! They can be done EXACTLY like a 2V engine with the exception of the cam gear holding tool so the bolt can be torqued properly.
I have done many successful 5.4 cam phaser jobs (usually without even pulling the front cover), and only once did a cylinder head have to come off because it just wasn't getting enough oil to work.
I do think the 5.4 is generally a hunk of junk and I will never own one, but they do make me money.
