04 F150 ride height - standard VS FX4
Iowa
Hey guys, I've got an 04 F150 with 190k miles and the front seems a little low. I'm planning an putting new strut/springs under it and am wondering if I can gain a touch of height over new stock with the FX4 strut/spring combo or if the only difference is strut valving. Part 2 is if the FX4 spring does raise it, is that going to change the front geometry enough to matter, or did they use the some control arms and other front end parts?
Originally Posted by tcp71
Put on some bilstein 5100s. Adjustable from stock height to +2.25".
^^this^^ - I installed them on my FX4 and adjusted the front to remove the rake angle from it. In addition to the improved ride, the Bilsteins gave the truck a whole new stance.
