anyone have better filter data than I can find? here is the problem:
my 1998 Cub Cadet 7275 (mitusbishi tractor, K3M motor) takes the following 3 filters:
30A4000102 - for oil. I have found this to be xreffed as the Pennzoil PZ109, Baldwin B1402, Wix 51356, Hastings LF240, Casite CA240 etc. no problem there and I can get filters for $4ish rather than the dealers $12ish. (got a case of PZ109s for 50 cents each when Central Tractor went tits up)
MA19632558000 - for the hydrostatic drive. On the Jplan board (3 years ago) it was stated that Balwdin was making a BT260 and Wix a 51664 to replace this. IS this true? can anyone xref this? Currently neither website xrefs to the mitsu number, but do to each other.
MA19642509000 - for the tractor hydraulics. Wix xrefs on the website for 57118, which crosses to Hastings KF47 and Baldwin BC7173 so Im fairly confident here.
Any other sources I can verify? Hydraulic pumps and hydrstatic drives are hideously expensive and I cringe at sending $80 per lube cycle to mitsubishi....
