Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
Harry_Seaward, MrH1325, Thetarmac, lbstyling, tanpw
70483 Registered Users
38 registered members (Bighorn2500, Astro_Guy, Bookmaker, brages, 77GrandPrix, 6 invisible), 1,383 guests, and 22 spiders.
Topics300,336
Posts5,173,605
Members70,483
Most Online3,825
Jan 19th, 2020
Page 1 of 3 1 2 3
Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count #5293642 12/13/19 04:34 PM
T
thescreensavers Offline OP
T
[Linked Image from i.imgur.com]
I did this oil analysis on my Jeep for fun to see how the filtering was doing after 22k on the XG8A, The filter was installed on 8/2017, 80% of this OCI was short tripping to work <10min.
It has four oil changes on this filter 2x with 10W30 Maxlife and 2x 15W40 HDEO Maxlife.
Flashpoint being low not sure about though I did take this sample after a short idle to warm it up.
I did my RMS two OCI ago and did use some rtv on the rear cap so that might be leaching into the oil.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293647 12/13/19 04:44 PM
N
N Heat Offline
N
Dang. XG held up nicely for that many miles.
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293677 12/13/19 05:24 PM
T
Triple_Se7en Offline
T
Is this UOA above 15W40 HDEO Maxlife?
19' Hyundai Santa Fe 2.4 GDI - Valv Adv. 5w30 / OEM Oil Filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Pennzoil Gold 5W30 / OEM filter
04' Colorado 3.5 Castrol Edge 0W40 / K&N filter
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: Triple_Se7en] #5293691 12/13/19 05:32 PM
T
T
Yes
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293693 12/13/19 05:33 PM
J
jbutch Offline
J
Always a treat to see a PC in a report.
How much does BS charge for PC?
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293708 12/13/19 05:51 PM
CharlieBauer Offline
Thanks for getting and sharing a particle count.
This Ultra's particle count is a bit disappointing. The silicon is also high for an Ultra.
In this thread: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4650751/1
I linked to some particle counts with other filters which performed notably better.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: CharlieBauer] #5293717 12/13/19 06:03 PM
K
kschachn Offline
K
As far as silicon goes, I can't imagine any spin-on filter removing particles that show up on an ICP analysis. They can be down to the atomic level.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293729 12/13/19 06:17 PM
harry j Offline
Your PC is through the roof! Try a Royal Purple or Amsoil oil filter to see if we can improve these numbers.
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293732 12/13/19 06:22 PM
harry j Offline
I always get a PC from Blackstone, look under "Amsoil 0W-30, 14198 miles, 1993 Civic"
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293738 12/13/19 06:29 PM
B
bullwinkle Offline
B
Any chances of photos of the cut open filter? Any chance it could have been blinded off & in bypass? Or possibly running a K&N air filter or similar? You make me want to go out & pull/cut the XG8A off the '98 XJ 4.0 in my sig, now!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293919 12/13/19 11:11 PM
T
TXCarGeek Offline
T
Newb here when it comes to particle count and I'm curious for some definitive info being that I'm using a Fram Ultra on my '99 Wrangler 4.0 right now. Could the high particle count numbers be due to the length of time the filter has been used?
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293921 12/13/19 11:15 PM
F
Farnsworth Offline
F
Now that the fun is done, what is your next filter change interval going to be? Not to be critical, but the Jeep probably uses 1000 gals of gas in this interval, say at $3/gal equals $3000. Three more Ultras would be $27 or so. It would be interesting to do PC on one oci with one filter. Generally the PC numbers are about what would be expected on a full flow filter. They have to filter all the oil flow all the time. A Frantz would clean that right up in a few miles. All is IMO.
2cents
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293924 12/13/19 11:17 PM
RDY4WAR Offline
Before we go bashing the Fram Ultra, this is a 4th oil change and 22k miles on this filter. The efficiency is certainly nowhere near what it is new. This is why I'm a big advocate of changing the filter every oil change.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: CharlieBauer] #5293952 12/14/19 01:05 AM
Z
ZeeOSix Offline
Z
Possible that running the filter for 22,000 miles wasn't ideal on this motor. Iron ppm is high too in this UOA compared to other Ultra PC and iron counts in other engines. There have been UOAs posted in this forum with PC data when using an Ultra that had a way better PC level and way less iron ppm.
Oil filters can become less efficient if loaded too much, there's technical info about that phenomenon. Guys think they are getting better oil filtration by running a filter an extended long time, but they could actually be getting worse filtration.
Re: Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count [Re: thescreensavers] #5293963 12/14/19 02:04 AM
RDY4WAR Offline
The filter starts clogging which increases the pressure delta which starts dislodging previously captured particles as well as making bypass events more frequent.
Page 1 of 3 1 2 3
