NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
69 registered members (65convertible, BBDartCA, 750IX, bbhero, 5 invisible), 1,356 guests, and 13 spiders.
Topics300,377
Posts5,174,552
Members70,492
Page 3 of 5 1 2 3 4 5
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5276788 11/25/19 05:42 AM
J
jakewells Offline
J
Harvest king all fleet full synthetic 5w40.
1996 Chevy 1500 4.3 V6. Harvest King 5W40 Fram XG3980 oil filter
Pennzoil sycromesh >> transmission
Shell rotella nitrite free ELC >> radiator
Shell Spirax HD 80W-90 >> rear axle
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5284459 12/03/19 09:11 PM
O
OLEJOE Offline
O
Rotella T6 15-40 in my 18’ 6.7 CTD. 20 degrees F is a record temp for us.
Thinking about swapping to Delo XSP 5-40 but haven’t found any details about it.
Jack of All Trades. Master of some.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5285233 12/04/19 06:11 PM
T
tundraotto Offline
T
Heres the specsheet of the Delo XSP 5W-40
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=493727&docFormat=PDF
Looks good to me - its usually around $19/gallon at Walmart....about the same as the Rotella T6 5W-40 (which IMHO is a better oil than the Rotella T6 15W-40).
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: tundraotto] #5285609 12/05/19 06:49 AM
SavagePatch Offline
Why do you think that the 5w40 is better than the 15w40? I would think it ultimately depends on the application but I would have thought that the 15w40 was better. Not arguing, just curious.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 4WD] #5285673 12/05/19 07:59 AM
2
2004tdigls Offline
2
15w40 in the TDI and my ML, I use this oil.
https://www.bosslubricants.com/viewproductdetails/heavy-duty-extreme-diesel-engine-oils
it hardly every gets cold out here, today's low temp was 4 celcius, about 40F.
note the oil has a pour point of -33 celcius
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: SavagePatch] #5285701 12/05/19 08:34 AM
T
tundraotto Offline
T
I agree - the 15W-40 should really be 'better' - but looking at the VOA sheets; less of everything, and a 'low' TBN....
Even their own semi-syn T5 15W-40 seems better....
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5069502/rotella-t6-15w-40#Post5069502
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5286933 12/06/19 01:37 PM
H
Huie83 Offline
H
Pentosin Long Life lll 5w-30 (507.00 approved) with a VW filter in my 2013 VW Golf TDI. Before that was the Castrol SLX professional the dealer uses. Can't really tell a difference between the two. It'll be interesting to see if it burns any of the Pentosin, it didn't burn any of the Castrol over it's last 10K mile change. The Pentosin is ~$10 cheaper for 5 qts.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5287257 12/06/19 09:10 PM
Dyusik Offline
Ram in sig: 15w40 currently, 5w40 and 15w40 on standby. No mention of any other oil in the manual, not that I need any options, this is what I'd run anyway.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k STP SYNHM 10w30, WIX 57047
18 RAM 3500 8k DELO SDE15w40, DBL7349
96 Cherokee
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5288220 12/08/19 01:43 AM
T
tundraotto Offline
T
5W-40 now would make more sense with the season...
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: tundraotto] #5288857 12/08/19 07:31 PM
B
BLND1 Offline
B
15w-40 DELO XLE in the Yanmar.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5290865 12/10/19 08:41 PM
N
Newman88 Offline
N
15w40 T700 Sinopec oil in all of our diesel engines.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5294262 12/14/19 12:02 PM
-SyN- Offline
Combo - 2 Gal Triax ESP 15W-40 / 1Gal Triax ESP 5W-40 - 1 yr OCI.
17 Ram 2500 6.7L > -Triax- 10W-30/15W-40 combo w/Wix XP
19 Edge ST 2.7L EB > Castrol Edge Euro 0W-40 w/MC Filter
17 Edge Titanium 2.0L EB > Castrol Edge Euro 0W-40 w/RP Filter
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5303443 12/24/19 02:12 PM
B
billpace1956 Offline
B
I use Delvac Super 1300 Semi Synthetic 15W-40 in my 1983 Mercedes 240d and will be using that same oil in my 1984 300SD mercedes as well when it hits 255,000 miles on the next oil change. I'm using Amsoil AME 15w-40 in my 1995 E300D. The other 2 diesels are real soot loaders, the 1995 is not. So it gets an oil that will last longer. I'll do an UOA just to make sure for all of them. I did a UOA on the 240d @ 15,000 miles using the Amsoil AME and Blackstone labs said to try 17,000 miles the next time. I went 10,000 miles on the 300SD and Blackestone labs said to go 11,000 miles the next time but I not going to do that as the soot level was at 1.7 % and Mercedes said the limit was 2%. I'm just going to use the Delvac and go 10,000 miles and then I'll let the UOA tell me what to do. On the 1995 E300d I'm going to do a UOA @ 10,000 miles with the Amsoil AME and go from there. It has electronic fuel injection so the soot loading is much less. ( .2% after 15,000 miles) I also have a 1988 mercedes 300e gas engine that I used a 15W-40 travellers oil in it. I went 10,000 miles and sent a sample UOA in and it came back with a really good report but it used a quart every 3,000 miles so I went with Mobil 1's 15W-50 to slow down the oil use but it still uses a quart every 3,000 miles. I'll just go back to the HDOE 15w-40 after my supply of 15W-50 is gone. I also have a 2008 Toyota Sienna that I use Mobil1 5W-30 EP in it. I go 20,000 miles per oil change. I use the Fram Ultra in that van. The van just hit 334,000 miles yesterday. BTW, the 240d has 316,000 miles the 300SD has 252,000 miles on it the E300d has 164,000 miles on it and the 1988 E300 has 257,000 miles on it. They all run very well and I'm pleased with all of them. Thank You, Bill
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5303451 12/24/19 02:21 PM
RDY4WAR Offline
High Performance Lubricants has a synthetic HDEO with an older CI-4 add pack and available in 5w-20 up to 20w-50.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5303736 12/24/19 11:12 PM
SavagePatch Offline
Mobil 1 Turbo Diesel Truck 5w40
VM Motori 3.0L V6
