NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
63 registered members (750IX, 65convertible, BBDartCA, brages, bbhero, 5 invisible), 1,331 guests, and 18 spiders.
Topics300,377
Posts5,174,545
Members70,491
Page 2 of 2 1 2
Re: Just replaced Flooded battery with AGM, was that a mistake? [Re: jayjr1105] #5283681 12/03/19 07:35 AM
K
Kira Online Content
Online Content
K
Extremes, specific benefits and application needs are to be assessed before pulling the trigger on an AGM purchase.
Re: Just replaced Flooded battery with AGM, was that a mistake? [Re: jayjr1105] #5283863 12/03/19 10:50 AM
J
jayjr1105 Offline OP
J
Pennsylvania so no extreme heat other than a few days in July and A few days in January in single digits. On the other hand, can someone decode the manufacture date from this battery. I took several pics...
https://imgur.com/a/ovJIFwQ
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Just replaced Flooded battery with AGM, was that a mistake? [Re: jayjr1105] #5283925 12/03/19 11:49 AM
P
PowerSurge Offline
P
October 2019
Re: Just replaced Flooded battery with AGM, was that a mistake? [Re: jayjr1105] #5284028 12/03/19 02:07 PM
Yah-Tah-Hey Offline
NO
Re: Just replaced Flooded battery with AGM, was that a mistake? [Re: PowerSurge] #5284362 12/03/19 07:16 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Originally Posted by PowerSurge
https://www.consumerreports.org/car...ts-your-car-battery-what-to-do-about-it/
“But even AGM batteries face challenges. “AGM batteries will perform well in the heat, but the life span will be hampered due to loss of water from the high temperatures,”
FLA’s last longer in hot climates.
This makes zero sense unless they are essentially abusively charged.
AGMs, which are also valve regulated lead acid batteries, are designed to fully recombine the formed hydrogen and oxygen inside. The “valve” prevents escape.
They can overpressurize on charging and lose gas. Recall that coulombs and amperes relay numbers of electrons. Electrochemical reactions are reliant upon mass - quantity of reactant to create those numbers of electrons in the circuit. If charged too fast, ie too many amperes, the overpotential (voltage) must be higher. This gives a one-two punch. Higher voltage which drives the electrolysis reaction, and more current which means more electrolysis can happen. Too much happening (faster splitting than recombination) will create pressure. Simple concept. Then the burped has, which should have recombined to water, is lost forever, impossible to add back.
So it is possible. But I’d suspect it needs to be a very fast charge on a very high impedance battery. In normal use, they should not lose appreciable water.
Page 2 of 2 1 2
