Jingle Bells...
by GumbyJarvis - 12/12/19 02:38 PM
Meguiar's M305
by sohccammer427 - 12/12/19 02:29 PM
Will it fit?
by Bettez88 - 12/12/19 12:58 PM
Diagnosis Confirmatioin
by Gebo - 12/12/19 12:58 PM
Mercury 25hp PCMO
by SimpleGuy48 - 12/12/19 12:50 PM
IIHS Pushing for Better Headlights
by SubLGT - 12/12/19 11:58 AM
My favorite flight ever
by Astro14 - 12/12/19 11:31 AM
Does anybody else have reactions to MSG?
by Chris142 - 12/12/19 10:35 AM
injecter cleaner?
by ernied - 12/12/19 09:27 AM
Which would you use for 5k
by Bettez88 - 12/12/19 09:08 AM
Effective ways to reduce humidity inside the car
by MoneyJohn - 12/12/19 08:21 AM
Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
kalima, Powertool1994, lutvi20, Bazik, Lamasuna
70113 Registered Users
97 registered members (4WD, 53' Stude, 77GrandPrix, alchargo, 8 invisible), 1,946 guests, and 21 spiders.
Topics298,632
Posts5,139,575
Members70,113
Most Online3,589
Nov 2nd, 2019
2019 Kia Sedona - Oil Filter Housing #5273071 11/20/19 07:46 PM
X
XpressAuto Offline OP
X
Can someone tell me what the purpose of this hole is? This is on a 2019 Kia Sedona with a 3.3 motor. Oil filter is located on the bottom of the vehicle beside the oil pan. This type of housing is also common on some of the Hyundai Genesis. Filter is tightened to spec and after starting and letting it sit a second, oil will SLOWLY seep out of hole. Other tech is saying this is normal.
[Linked Image]
Oil change shop located in Raleigh, NC.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273093 11/20/19 08:10 PM
J
JLTD Online Shocked
Online Shocked
J
Looks to me that when you loosen the housing, it allows the oil inside to seep out...and/or directs the oil flow as you remove the housing. Same purpose as the Toyota's end cap.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273095 11/20/19 08:13 PM
JohnnyJohnson Offline
That's normal no a screw on filter is normal and costs less.
2004 Corolla 137480
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76862
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273113 11/20/19 08:29 PM
X
X
The other tech is saying he thinks its the oil that is between the gasket and cap just running out until dry. The gasket on this filter is about a 1/3rd of the way up the filter.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273175 11/20/19 10:00 PM
blupupher Offline
No idea on the answer to your question, but I don't understand the reason for a cartridge filter on the bottom side?
And what is weird as well is that is basically the same Lambda II motor that is in my Hyundai Santa Fe, but mine has a cartridge filter on top.
6mo:'18 Santa Fe:PP 10W-30/OEM, '18 Soul:Synpower 5W-30/PG, '10 Santa Fe:Synpower5w-30/D+, '04 F150/Magnatec 10w-30/ST
1yr: '12 xB:M1EP 0W-20/CQB, '02 F150:Magnatec 5W-20/D+, '94 VT1100:Peak 15W-40/D+
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273187 11/20/19 10:14 PM
6
69Torino Offline
6
Kia/Hyundai moved it to that location because it’s a shorter trip from the oil pump. The top mounted ones have quite the journey from the pump to the filter.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2000 Nissan Xterra
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 2019 Kia Sedona - Oil Filter Housing [Re: JLTD] #5273242 11/21/19 01:12 AM
O
OilUzer Offline
O
thumbsup
Toyota filter comes with a little plastic thing you screw/push in to drain the filter oil ... this is after you remove the end cap. you do this before removing the housing. Drains the left-over oil in filter. Filter is also at the bottom.
This model has no end cap and little hole does the job. I guess two less parts. No end cap and no special tool (plastic thing). I bought a fancier aluminum part (comes with a hose) instead of using the plastic part to drain.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: 69Torino] #5273503 11/21/19 10:26 AM
STIcandy Offline
They're probably trying to solve the dry start issue that causes the timing chain rattle on startup
Re: 2019 Kia Sedona - Oil Filter Housing [Re: STIcandy] #5273554 11/21/19 11:25 AM
PimTac Offline
How do you connect a drain hole in the filter housing to solving timing chain rattle?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: PimTac] #5273567 11/21/19 11:39 AM
blupupher Offline
I think they are referring to my comment of the filter housing being moved from the top of the engine to the bottom, not the OP question of the hole in the housing.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: PimTac] #5273572 11/21/19 11:41 AM
6
69Torino Offline
6
In regards to the physical location of the oil filter housing having a shorter distance for oil to travel on initial startup. Older Lambda engines have the housing mounted to the valley, up top, transmission side. This comment was not in regards to the drain hole. Rather just the location change of the housing.
2000 Nissan Xterra
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 2019 Kia Sedona - Oil Filter Housing [Re: XpressAuto] #5273593 11/21/19 12:01 PM
PimTac Offline
Okay I see the point there.
2017 Mazda CX5
Roki OEM filter.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: blupupher] #5273646 11/21/19 01:02 PM
STIcandy Offline
Yeah sorry. You are correct. I was referring to the housing relocation attempt to solve the constantly dry filter. I've even looked into weather there is an ADBV in the housing, but I've found nothing.
Re: 2019 Kia Sedona - Oil Filter Housing [Re: STIcandy] #5273692 11/21/19 01:51 PM
PimTac Offline
I had keyed in on the idea that it was more cost effective relocating the filter. I didn’t know of the timing chain issue.
2017 Mazda CX5
Roki OEM filter.
