My 90 chevyrado ate another set of drivers door hinge pin bushings tonight. Got in it at work to head home tonight and the (censor) door wouldn't close. Had to get out and lift the door up and close it then slide in the other side. Checked it out at home in the light and wala the second set of HELP bushings had broke the shoulder off the bushing , the bushing slid down the pin and the pin worked its self up and just a little more and I think the door could have fell off of the truck. I don't think the bottom pin alone would have supported the weight of the door. So now I am not buying any more HELP junk. Any body got any opinions as to the quality of pin rebuild kits if I were to use dealer GM kits versus this junk? This is the second set that has failed in 2 years
