Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
Low VI gear oils
by dparm - 01/25/20 05:28 PM
Removed valve cover, need to move car change oil?
by mazdamonky - 01/25/20 05:23 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
19 registered members (dishdude, charmer37, coondog, ArrestMeRedZ, Char Baby, 1 invisible), 927 guests, and 23 spiders.
Topics300,570
Posts5,178,477
Members70,527
06' V6 Accord 12,462 miles Penzoil Platinum 0W20 #5272007 11/19/19 04:57 PM
Daschicken Offline OP
Did this one a while ago, just neglected to post it here. More highway trips this time. At some point I had to replace a torn intake hose, plus reseal the oil pan using hondabond. I'm pretty sure the intake hose tore on my previous analysis, while the oil pan sealing happened this time around. Hopefully that explains the high silicon. Changed filter with same Fram Ultra Synthetic that was on it before. The universal averages have changed slightly since my last oil change, which I found interesting, numbers in parenthesis are the new universal averages.
Code
Oil          Penzoil Platinum 0W-20                 Penzoil Platinum 0W-20         Universal averages
Miles in use          12,462                                  10,065
Miles                 161,276                              148,814
Sample taken          5/4/2018                             6/25/2017
Make up oil added       0 qt                                 1 qt
Aluminum                  4                           9                              3   (3)
Chromium                  1                           1                              1   (1)
Iron                      23                          20                              9   (9)
Copper                    1                           1                              9   (8)
Lead                      0                           0                              2   (2)
Tin                       0                          1                              1   (1)
Molybdenum               53                           51                              74   (74)
Nickel                    0                           0                              0   (0)
Manganese                 1                           2                              1   (1)
Silver                    0                           0                              0   (0)
Titanium                  0                           0                              2   (2)
Potassium                 1                           1                              2   (2)
Boron                     3                           5                              51   (51)
Silicon                  24                           13                              11   (11)
Sodium                   25                           78                              38   (40)
Calcium                  2313                          2190                            2109   (2084)
Magnesium                 10                           7                              130   (135)
Phosphorus                611                          610                             691   (691)
Zinc                     692                           693                             815   (814)
Barium                    0                           0                              0   (0)
                               Values Should be(far right)
SUS Viscosity @ 210F     53.8              53.0         46-49
cST Viscosity @ 100C     8.42              8.17        6.0-10.2
Flashpoint in F          410              430           >385
Fuel %                  <0.5             <0.5           <2.0
Antifreeze %             0.0              0.0            0.0
Water %                  0.0              0.0           <0.1
Insolubles %             0.2              0.3           <0.6
TBN                      3.2              3.5           >1.0
As blackstone says:
"The second report for your Accord is another good one. Aluminum improved and a reading of 4 ppm tells you the pistons/bearings are doing just fine. Iron (steel wear)is a pinch higher, and that's normal after a longer run. The increase in silicon is a bit of a surprise. That could show dirt in the oil, unless it's from a sealer/lube of some sort. If you didn't open the engine up recently, just make sure the air filter is clean and properly seated. The TBN shows active additive left, and no fuel or coolant showed up. Try ~14,500 miles next time."
Well, I actually went for 15,832 next time, but no analysis for that one, i've got the data I need, and would now like to save money from it. That interval included a nearly 5,000 mile trip from Georgia to Montana and back, plus the usual amount of highway driving. The oil life indicator hit 0% at a whopping 11,656 miles! Keep in mind this car was made in 2006! That was far longer than I have ever seen it hit 0%.
Last edited by Daschicken; 11/19/19 05:02 PM. Reason: Added new universal averages
2006 Accord V6 6 Speed Sedan-180K
0W20 PP
Re: 06' V6 Accord 12,462 miles Penzoil Platinum 0W20 [Re: Daschicken] #5272029 11/19/19 05:26 PM
M
madeej11 Offline
M
Nice. Love to see long runs with no makeup oil, it really shows what an oil on a DD is capable of. If that silicon gets cleaned up I can see even longer oci's. Might also bring iron wear down? not that it's bad mind you. Thanks for your posting, keep it up.
Re: 06' V6 Accord 12,462 miles Penzoil Platinum 0W20 [Re: Daschicken] #5272066 11/19/19 06:37 PM
ctechbob Offline
I actually have a spare intake hose on hand. They seem to just randomly tear sometimes, especially if you don't loosen the connection when trying to change the air filter.
The J30A4 really is a nice running engine if you keep up the maintenance.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: 06' V6 Accord 12,462 miles Penzoil Platinum 0W20 [Re: ctechbob] #5272079 11/19/19 06:54 PM
It doesn't help that I put on a slightly milled down intake manifold spacer from a Honda Odyssey. Mine is the J30A5. wink
Athens, huh? Not too far from me!
0W20 PP
Re: 06' V6 Accord 12,462 miles Penzoil Platinum 0W20 [Re: Daschicken] #5272104 11/19/19 07:49 PM
ctechbob Offline
Well, Statham, but no one knows where that is, so Athens is close enough.
Still, hard to beat a non-VCM J-Series.
Trans-Idemitsu H+
Re: 06' V6 Accord 12,462 miles Penzoil Platinum 0W20 [Re: Daschicken] #5272118 11/19/19 08:09 PM
M
maverickfhs Offline
M
That's some really good report and I change the oil at 5K? WOW
Thanks for sharing thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
