Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
87 registered members (38Chevy454, 2015_PSD, aquariuscsm, Aero540T, Asterix, ARCOgraphite, 5 invisible), 1,892 guests, and 55 spiders.
Topics298,361
Posts5,133,759
Members70,047
Most Online3,589
Nov 2nd, 2019
Fleetguard WF2074 Coolant Filter Cut Open #5270143 11/17/19 05:24 PM
P
Pyrotechnic Offline OP
P
I bought a coolant filter mount and it came with a new Fleetguard WF2074 filter. Unfortunately, it has DCA4 additive for a 36 gallon cooling system so I can't use it. I've always wondered what these looked like inside, so here it is cut open.
[Linked Image]
It's a paper element that seems to be stained by whatever the additive is inside. The additive seeped out.
[Linked Image]
Coil spring.
[Linked Image]
I removed the bottom plug in the element, and the center of the filter is packed full of additive.
[Linked Image]
All the additive dumped out.
[Linked Image]
Not sure if this is a date code, would be interesting to know how long this filter has been sitting around.
[Linked Image]
I didn't expect to see that much additive inside the filter. If someone installed this filter on a typical 3 to 4 gallon cooling system I have a feeling it wouldn't end well.
Re: Fleetguard WF2074 Coolant Filter Cut Open [Re: Pyrotechnic] #5270152 11/17/19 05:31 PM
53' Stude Offline
Thanks for c&p. Hopefully diesel powered truck/semi owner operators will comment smile
Re: Fleetguard WF2074 Coolant Filter Cut Open [Re: Pyrotechnic] #5270161 11/17/19 05:40 PM
B
bullwinkle Online Confused
Online Confused
B
342nd day of 2012-I think that filter got wet, usually the DCA/SCA additive is in tablet form (it is in the ones I've used), I use the DCA2 additive (same as NAPA Kool) in my 7.3 IDI F-450 in my sig, usually either 4 units (WF2051 or equivalent) or a blank filter, depending on what the test strip tells me I need. 12 units is a tremendous amount!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fleetguard WF2074 Coolant Filter Cut Open [Re: bullwinkle] #5270393 11/17/19 11:04 PM
P
P
Well the age explains it. I have no idea where or how this filter was stored, and a lot can happen in 7 years.
Re: Fleetguard WF2074 Coolant Filter Cut Open [Re: Pyrotechnic] #5270782 11/18/19 12:03 PM
L
Linctex Offline
L
The stuff is located AFTER the element...
Does it all dissolve itself in say, just 500 miles?
