Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
22 registered members (Char Baby, DerekPho, dishdude, Dave9, Calikura, Black_Thunder, 2 invisible), 706 guests, and 18 spiders.
Topics298,818
Posts5,141,874
Members70,129
Most Online3,589
Nov 2nd, 2019
Stalling and difficult restart problem #5265556 11/12/19 09:26 PM
R
RDMgr Offline OP
R
I need help! My truck is a 2003 Silverado 1500 HD with a 6.0L engine.
It usually quickly starts with a turn of the key. The other day it cranked but did not catch but started on the second try. Then, it drove fine. The next day it had the same starting issue. I drove it five blocks and it stalled as I slowed to a stop sign. No codes, no check engine light. It just stopped and it would not start. I had a diagnostic run which said poor battery connections which did appear to be the case. It test drove fine. In fact, what I thought was a little surge on acceleration before this problem disappeared.
The next day it started fine. I drove about a mile and it stalled while I was approaching a red light. It was difficult to start. It cranked and eventually started. I drove it right home without incident.
What should I be looking for…what can cause this behavior? Could it be the battery or battery connections or is it something more?
Re: Stalling and difficult restart problem [Re: RDMgr] #5265560 11/12/19 09:33 PM
O
oldhp Offline
O
Check fuel pump pressure.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Stalling and difficult restart problem [Re: RDMgr] #5265579 11/12/19 09:53 PM
I
irad Offline
I
A bad ground, camshaft or crankshaft sensors can also cause your symptoms, particularly camshaft sensor.
Re: Stalling and difficult restart problem [Re: RDMgr] #5265615 11/12/19 10:31 PM
E
Exit32 Offline
E
Could be an intermittent ignition switch.
2020 Explorer 3.0 EcoBoost
2004 Buick Rainier V8
2002 T-Bird
1999 F250 V10
1967 Camaro
1966 Shelby Cobra
1966 Pontiac GTO
1965 Rambler American
1957 T-Bird
Re: Stalling and difficult restart problem [Re: irad] #5265648 11/13/19 12:09 AM
c502cid Offline
^^^^^This^^^^^
16 F150 2.7 EB 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Stalling and difficult restart problem [Re: RDMgr] #5265694 11/13/19 05:30 AM
L
LeakySeals Offline
L
Fuel pump is a common failure in those trucks at older age and higher mileage.
Check under driver side frame rail, that was one of the last years with an external fuel filter.
Do you have a code reader? Any codes pending. Want live data including LTFT and ECT.
Any exhaust manifold bolts missing?
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: Stalling and difficult restart problem [Re: RDMgr] #5265709 11/13/19 06:16 AM
caprice_2nv Offline
Our one previous work truck a 2002 GMC, the fuel pump failed around 100k miles (I don't think it helped that the driver at the time ignored my recommendation to keep it above 1/4 tank). It just randomly died and never restarted one day. There were a couple of times it didn't start first try prior to this happening but it was like once every couple weeks when the truck would be started an average of 20 times a day.
A dirty mass air flow sensor can sometimes cause them to run bad also. That's a cheap preventative fix you can try at home. I just did it on our 2005 Silverado at work a couple weeks ago. It didn't fix my stumble but was due to be cleaned anyways.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Stalling and difficult restart problem [Re: RDMgr] #5265716 11/13/19 06:33 AM
W
wag123 Offline
W
+4 on the fuel pump. They commonly fail on that vintage of Chevy trucks.
Re: Stalling and difficult restart problem [Re: RDMgr] #5265763 11/13/19 08:03 AM
DaleRider Offline
Fuel pump, as others have said. I had the exact same symptoms as the OP with an '02 Blazer...intermittent difficulty starting, dying randomly.....died completely pulling out my driveway one morning. At least I didn't have far to push it out of the road.
Re: Stalling and difficult restart problem [Re: RDMgr] #5265769 11/13/19 08:08 AM
B
bubbatime Offline
B
These trucks lose a fuel pump at this age. Has yours been replaced yet?
My 2006 has had two replacement fuel pumps already.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Stalling and difficult restart problem [Re: RDMgr] #5265812 11/13/19 08:52 AM
W
wag123 Offline
W
The fuel level sensor also commonly fails on GM trucks from this era and can throw a CEL. When you replace the fuel pump you should purchase the entire fuel pump and fuel level sensor assembly. DON'T CHEAP OUT ON THIS, purchase ONLY the OEM part! I know that there are much cheaper replacements available, but they are junk. Ask me how I know.
Also, replace wiring pigtail at pump with new updated design because factory pigtails are known for poor connections, get hot, and burn terminal ends (this could actually be your problem, but go ahead and replace the pump assembly anyway because it WILL fail). It will only cause you problems in the future if you don't. Use dielectric grease on plug.
Re: Stalling and difficult restart problem [Re: RDMgr] #5265970 11/13/19 11:31 AM
J
JMJNet Offline
J
For the battery, you just have to do a load test on it.
If you don't have load tester, any part store can do it for you.
  • 2017 Toyota Sienna
Re: Stalling and difficult restart problem [Re: JMJNet] #5266098 11/13/19 01:37 PM
R
Rand Offline
R
if its cranking its not the battery causing it to stall?
