valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
Does old adhesive need to be removed for vinyl planking?
by JLawrence08648 - 12/12/19 04:06 PM
How straight does a oscillating saw cut?
by JLawrence08648 - 12/12/19 03:58 PM
Hastings filter efficiency ratings.
by mpgo4th - 12/12/19 03:12 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
81 registered members (4WD, Bailes1992, AZjeff, Astro14, alcyon, 7 invisible), 1,419 guests, and 29 spiders.
Topics298,662
Posts5,140,006
Members70,115
Most Online3,589
Nov 2nd, 2019
1977 2-stroke moped ESSO 2-T 18:1? #5264568 11/11/19 08:50 PM
N
N8conn Offline OP
N
I inherited a 1977(?) Carabela 60cc 2 stroke moped. The manual says to use an ESSO 2-T 18:1 mix.
Is/was ESSO 2-T the same thing as regular 2-cycle oil?
Any thoughts on weather I really need to mix it that rich?
Thanks!
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5264587 11/11/19 09:11 PM
U
UrS4 Offline
U
With our new 2t oils I believe a 3% mix will be just fine.
1993 Audi S4 2.2 20V Turbo - German Castrol Edge FST 0W-40 - Mahle filter
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5264760 11/12/19 06:47 AM
Cujet Offline
As a general rule, very few 2t engines require such a mixture. In our testing, 32 to 1 (or 4 ounces per gallon) provided all the wear protection possible in outboard engines. However, there are a few "cheap" engines that don't use roller bearings in critical locations, but instead use a brass or "oilite" bushing. Those engines do need very rich oil mixtures. Examples include some 1960's 2 stroke lawn mowers and other ancient engines.
I don't know how your engine is constructed, but it is a Mexican copy of a European design. I suspect it's a conventional roller bearing design and would do just fine on 32 to 1.
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5264777 11/12/19 07:19 AM
F
FastGame Online Content
Online Content
F
If you change the mix ratio (32-1, 40-1, 50-1) you will need the carb mixture settings adjusted, you will be rich in fuel if you don't.
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: Cujet] #5265473 11/12/19 07:54 PM
N
N8conn Offline OP
N
Thanks! Can you tell from this exploded view what type of bearings it has? [Linked Image]
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5265571 11/12/19 09:44 PM
MolaKule Offline
Global Moderator
Global Moderator
It looks to me like the crankshaft has roller bearings while the connecting rod has bushing bearings.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: MolaKule] #5265618 11/12/19 10:34 PM
Z
ZeeOSix Offline
Z
Big end looks like a caged needle bearing. Diagram doesn't have enough resolution to really tell.
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5265625 11/12/19 11:01 PM
Silk Online Content
Online Content
Ball bearings on the mains, roller on the bigend.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5265739 11/13/19 07:19 AM
W
weasley Offline
W
I'd guess so, yes. Esso is just the name of an oil company - part of ExxonMobil now. Esso comes from 'S' 'O', which comes from Standard Oil. Outside of America, Esso is to us what Exxon is to you. I have no reason to believe that Esso 2T oil was anything different (in general terms) from any similar 2T oil.
One difference may be whether the oil they recommend is prediluted or not.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5265803 11/13/19 08:44 AM
K
Kamele0N Offline
K
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5266354 11/13/19 06:48 PM
N
N8conn Offline OP
N
Wow, thanks for the awesome responses! Sounds like I should mix it to the original spec because it may have some of the old school bushings rather than roller bearings. Thanks again everyone!
Re: 1977 2-stroke moped ESSO 2-T 18:1? [Re: N8conn] #5266609 11/14/19 01:17 AM
K
Kamele0N Offline
K
Mix it in 32:1 (3%) with synthetic wich can be mixed up [email protected]:1... (quality synthetic)
