Old Vice info
by A310 - 11/16/19 10:18 PM
2003 Ranger Radiator Replacement: Which Coolant?
by chucky2 - 11/16/19 08:55 PM
ATV axle removal
by supton - 11/16/19 07:45 PM
High speed chase
by P10crew - 11/16/19 07:28 PM
Oil for Daily Beater Camry
by Speak2Mountain - 11/16/19 07:18 PM
Green coolant, future availability ?
by rubberchicken - 11/16/19 06:11 PM
Weird tire wear
by ledslinger - 11/16/19 04:50 PM
Why does Ford resell lemons?
by avacado11 - 11/16/19 04:07 PM
Slow initial response to loading web pages
by JHZR2 - 11/16/19 04:06 PM
Motorcraft FL-910S
by PW01 - 11/16/19 03:54 PM
Walmart ammo clearance
by redbone3 - 11/16/19 03:35 PM
GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
billad67, aka_Claus, Diverdown, natas, matt3540
69886 Registered Users
82 registered members (A310, ammolab, Astro14, 11 invisible), 1,615 guests, and 21 spiders.
Topics297,521
Posts5,117,330
Members69,886
Most Online3,589
Nov 2nd, 2019
2019 Nissan Pathfinder CVT drain/fill. #5247858 10/23/19 08:19 AM
J
JTK Online Content OP
OP Online Content
J
I bought this vehicle a few days ago. It's first 9 months and ~22K miles were in rental service. I did it's first CVT drain and fill today. I do them cold and 4qts come out. Here's what the fluid looked like compared to new:
[Linked Image from i.imgur.com]
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247863 10/23/19 08:25 AM
N
NoNameJoe Offline
N
Wow I like the color of the new fluid. grin2
2015 Civic LX Coupe
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247864 10/23/19 08:26 AM
M
Miller88 Offline
M
Wow - that's really bad looking!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247867 10/23/19 08:31 AM
K
khittner Offline
K
Looks like it's been doing some towing.
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: Miller88] #5247871 10/23/19 08:35 AM
J
OP Online Content
J
Right?
Thing is, color of these types of fluids/lubes really isn't an indication of much. When I did the first CVT fluid drain/fill on our Nissan Quest at ~33K miles (same powertrain), the factory fluid looked the same. It cleaned right up after 2 drain/fill cycles and stayed cleaner looking every ~20K miles after that.
It's about $40-50 a pop to do a 4qt spill and fill with NS-3, but I have to think it's beneficial to the unit.
There's no tow package installed on this Pathfinder. It is exceptionally clean for an ex-rental. Still smells and looks new, even under the hood. A few bumper dings, one small door ding and a missing trim piece on the rear wiper.
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247912 10/23/19 09:18 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
The first change is always the darkest because of break-in.
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247928 10/23/19 09:38 AM
Char Baby Offline
When I changed the OE CVT fluid on my '15 Altima this past summer at 51K miles, the fluid draining out looked decent and even better on a clean rag. But, when the fluid was in a clear container(3.7qts) it too looked like what JTK is showing. I used/replaced with Castrol Transmax CVT fluid(RED) and all is well thus far.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247933 10/23/19 09:45 AM
J
OP Online Content
J
Char- Same deal. On a clean white rag, the fluid is a clean, greenish color. Poured in a jar or jug, it looks worse. There's zero visible solids in the fluid. My OCD would be unbearable that being the case. LOL
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247943 10/23/19 10:11 AM
M
mclasser Offline
M
mmm looks like blue koolaid
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247955 10/23/19 10:29 AM
H
HyundaiAbuser Online Content
Online Content
H
In my experience it takes very little time for transmission fluid to darken to an extent, at least in a transmission that hasn't been through extensive flushing or ultra religious maintenance. Immediately after changing or doing a fluid exchange the atf would near always darken to an extent after a couple hundred miles (although in a not spotless transmission). The tint doesn't mean the fluid is bad, just that there are some contaminants that have become miscible within in. I'd be willing to bet the fluid looks very similar to the stuff that came out with the new fluid added.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5247972 10/23/19 10:59 AM
N
NoNameJoe Offline
N
Yup I agree, the dirty fluid doesn't look that bad. I find the real indication is when you spread it out thin (or when it's draining as a stream), you can see right through it usually and it's a nice clear color, just a little bit of contaminants suspended in it is all.
Now if it's so dark and burnt that the viscosity changes and you can't see through it at all...
2015 Civic LX Coupe
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5248079 10/23/19 12:54 PM
J
OP Online Content
J
Agree on all points above.
Like I mentioned, I've been through the same drain/fill regimen with our previous Nissan and the darkest fluid was the initial drain/fill which makes perfect sense. Successive drains didn't look as dark.
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5248105 10/23/19 01:29 PM
Sayjac Offline
So JTK you don't mess with all the CVT fluid temp checks that Nissan talks about when doing a fluid change? Using the overflow plug. So how do you know that that sump wasn't low to begin with? Or you just take it on your experience with other Nissans that 4 came out so 4 back in and all good.
There's a youtube of a guy doing his Pathfinder CVT fluid and he used an IR temp gun with the overflow. I guess you had enough ground clearance with the Pathfinder, no raising vehicle needed? Have any issue getting "charging tube" plug off?
NS-3, ridiculously high.
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: JTK] #5248128 10/23/19 02:05 PM
M
Miller88 Offline
M
I'm not sure it's as important as the manufacturers make it out to be. I imagine there has to be some thing taken into consideration for volume in the heat/cold , off camber, going up and down hills. Seems that as long as the fluid is at the same temp, it's easy enough to get it close enough that the transmission won't grenade because of the fluid change.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 2019 Nissan Pathfinder CVT drain/fill. [Re: Sayjac] #5248192 10/23/19 03:34 PM
J
OP Online Content
J
After I do the 2nd drain/fill in a week or so, I'll get it up to the recommended 104F (or what ever the fluid temp spec is) and check level with the level check plug.
I have to use my IR gun and shoot the pan. I did that once on my 2016 Quest after a few drain/fills and didn't have to adjust level.
I did forget to mention, the hardest part of this job was again removing that stupid locking cap on the refill tube. It took various flat bladed screw drivers, a pick, a pair of channel locks and some knuckle skinning to get it off for the first time. I then use a small file to neatly file off the plastic locking tab on the cap and apply some silicone grease to the O-ring so it doesn't stick inside the refill tube.
