Does anyone have second citizenship?
by Martula - 11/14/19 10:38 PM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
Lightweight easy up
by Redright9 - 11/14/19 05:00 PM
Thinking of getting a cat
by 53' Stude - 11/14/19 04:42 PM
Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
rov137, Dorisy, DesktopDave, HPD, kildeth
69868 Registered Users
49 registered members (14Accent, AC1DD, abcdefg, bdcardinal, 2strokeNorthstar, aleneros, 4 invisible), 1,200 guests, and 38 spiders.
Topics297,431
Posts5,115,480
Members69,868
Most Online3,589
Nov 2nd, 2019
Page 2 of 3 1 2 3
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5245633 10/21/19 06:05 AM
sdowney717 Offline
Watch from 11 minute, of course lifetime fluid is a scam.
https://www.youtube.com/watch?v=LdF5DnGwz7E
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5245745 10/21/19 08:22 AM
B
Bailes1992 Offline
B
I have an AW AW71-SC in my Volvo which Volvo recommends the fluid is fit of life. I changed it out at 20k with a universal ATF. Factory ATF was still bright red and clean.
19 Volvo V40 D3 Auto - 96 Defender 300TDi - 03 Ford Mondeo ST 3.0 V6
Engine - Castrol Edge 5w30 LL
Manual - Fuchs Sintofluid 75w80
ATF - Comma MVATF
Diff & Transfer - Fuchs Sintopoid 75w90
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5246320 10/21/19 05:38 PM
R
RoyFJ Offline
R
I have AISIN A750F on my FJ Cruiser and I change every 30000 with AISIN AFW+ synthetic oil, I do a complete flush with machine. I have an oil cooler and Magnefine inline filter as well.
Re: Volvo dealer cautions against ATF change. Ever. [Re: RoyFJ] #5246454 10/21/19 07:35 PM
B
BlakeB Online Content
Online Content
B
I looked up AFW+, it’s a little thicker than WS, but if Aisin recommends it for WS applications I’m sure it’ll work no problem, they made the A750 after all....
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5246551 10/21/19 09:14 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Silvertone2000
...Something about the transmission adjusting to the changing viscosity of the fluid...
Most transmissions work on specific pressures at specific points in the transmission, plus or minus a few percentage points, so I call this misinformation.
Depending on how the vehicle has been driven, in my experience most FF fluids are looking pretty bad by 35k, i.e., the fluid is black, oxidized, increased in viscosity by 3-5 cSt points, with a lot of solid, particulate matter.
Find a good local mechanic who has the correct tooling to do a proper fluid and or filter job.
For every action there is an equal and opposite opposite criticism. shrug
Re: Volvo dealer cautions against ATF change. Ever. [Re: MolaKule] #5246615 10/21/19 11:32 PM
O
Oro_O Offline
O
Boom. The voice of reasons and experience.
Fluids are not going to last forever, and random babble 2nd hand from dealer monkeys does not constitute articles of faith.
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5246631 10/22/19 12:21 AM
J
Jetsfan421 Offline
J
Your transmission will fail eventually no matter how well you maintain it, but by not changing the fluid you guarantee an earlier death. Find a maintenance schedule and stick to it. Be it yearly drain and fills or cooler line flushes.
Re: Volvo dealer cautions against ATF change. Ever. [Re: Jetsfan421] #5246693 10/22/19 05:25 AM
sdowney717 Offline
True but if your maintaining the fluid, it may not fail while you own it.
Re: Volvo dealer cautions against ATF change. Ever. [Re: Oro_O] #5246705 10/22/19 05:46 AM
B
BMWTurboDzl Offline
B
An anecdotal reports on this site some how do? There are plenty of people who perform a change on units with over 50k miles miles where the fluid looked fine. The reality is that the overwhelming majority of transmission will go over 100k miles without a fluid change. That has been proven over the last 10-15 yrs.
435i
Re: Volvo dealer cautions against ATF change. Ever. [Re: Oro_O] #5246707 10/22/19 05:50 AM
SteveSRT8 Offline
I have yet to see any modern slushbox that does not regulate the pressure carefully according to defined limits. Old fluid will indeed accelerate wear.
And I would be extremely unlikely to ask any stealership monkey about maintenance. The schedule and exact procedures required are right in the owner's manual...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Volvo dealer cautions against ATF change. Ever. [Re: BlakeB] #5247322 10/22/19 04:25 PM
R
RoyFJ Offline
R
Yes its thicker than WS ATF but its been tested and used extensively in Russia under low temps and folks have had good results with no degradation of any kind. Being synthetic it has better cold weather range. The shift feel after changing to it from WS ATF on my transmission is a big improvement especially when the transmission is being pushed in stop and go traffic or hills under hot sun. Incidentally Aisin recommends change every 20,000 with their fluid. https://aisin.ae/upload/lpic/lpic_5.pdf
Re: Volvo dealer cautions against ATF change. Ever. [Re: RoyFJ] #5247447 10/22/19 06:15 PM
B
Online Content
B
I know someone that uses Mobil 1 Full Synthetic ATF in his A750 on a Tacoma and he says it shifts better on it than it does with WS. It’s not recommended for WS applications but these transmissions aren’t very picky about fluid types(about anything Dex/Merc seems to work), imo. I’ve been using Maxlife ATF in a Tacoma and a 4Runner with good results, I’ll likely stay with it for the foreseeable future. A lot of Dexron VI ATFs are recommended for or suitable for WS applications, so I may try one of them one sometime and see how they do in place of WS.
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5247503 10/22/19 07:07 PM
A
ARB1977 Offline
A
I use Amsoil blue cap in my 15 Tacoma that requires WS. The same fluid will be used in my wife’s 19 Pilot that requires DW1. Ran Valvoline Maxlife in her 08 CRV that required DW1 with 180K without issue.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Volvo dealer cautions against ATF change. Ever. [Re: Silvertone2000] #5247767 10/23/19 06:20 AM
M
meep Offline
M
I've owned 3 high mileage gen1 s60s. All have benefited, even from the first gear flare in one of them, by moving to amsoil and installing an inline filter. In the one with a moderate flare, the it essentially went away after about 25,000 miles.
2018 F150
2015 crv (wifey!)
Re: Volvo dealer cautions against ATF change. Ever. [Re: MolaKule] #5247988 10/23/19 11:20 AM
E
edyvw Offline
E
It is absolutely awful how fluid looked in my 2015 Sienna when I drained it few weeks ago at 63k.
I did same in my 2013 BMW, and it was still red at 65k.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Page 2 of 3 1 2 3
