Let’s see how this looks after 4 seasons
by Bettez88 - 11/15/19 11:04 AM
Interstate batteries problems
by JimPghPA - 11/15/19 09:49 AM
2008 Dodge Ram 3500, first sample
by A_Harman - 11/15/19 09:44 AM
Steelers/Browns
by CourierDriver - 11/15/19 09:04 AM
Beard care in cold weather?
by pandus13 - 11/15/19 08:39 AM
Door Sill protection for new car - which one?
by henni - 11/15/19 08:18 AM
Exterior Home Security Cameras?
by Gebo - 11/15/19 08:13 AM
5w-20 ok for GMC 6.2l ?
by jdw1222 - 11/15/19 08:02 AM
M. Defender vs Cont. TrueContact Tour?
by lukejo - 11/15/19 07:53 AM
Alternative for Lexus Toyota WS
by Joephu - 11/15/19 06:19 AM
F1 - 2019 Brazilian Grand Prix
by gofast182 - 11/15/19 06:10 AM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
DjS71, Akhunter, rov137, Dorisy, DesktopDave
69870 Registered Users
95 registered members (2004WJ, 1978elcamino, 14Accent, Aichiguy, 77GrandPrix, 11 invisible), 1,981 guests, and 32 spiders.
Topics297,439
Posts5,115,824
Members69,870
Most Online3,589
Nov 2nd, 2019
Fram Racing HP17 Cut open w/pictures #5246161 10/21/19 02:27 PM
G
geeman789 Offline OP
G
Picked up a couple of these mainly because I had never seen one before ... the HP17 is the 20x1.5 mm thread Honda / Nissan / Subaru etc. application. They were $ 10 CDN , which is about $ 4.00 less than a Fram Ultra 7317.
These filters are advertised as HIGH FLOW / HEAVY DUTY, and come with a Subaru friendly 22 psi by-pass. This model does not have the screened by-pass valve advertised for other models. Efficiency is listed as 94% @ 20 mu.
This is the first Fram I have seen with a louvered core. Louvers look ok, but if you hold them up under a light ( have to gut the filter to do it ... ) , they look good. Seems to be WAY MORE louvers than there are holes in a comparable Fram Ultra.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Fram Racing HP17 Cut open w/pictures [Re: geeman789] #5246196 10/21/19 02:58 PM
Z
ZeeOSix Offline
Z
Looks decent, but surprised it doesn't have a sealing surface on the end cap for the leaf spring/bypass valve assembly like the Ultra has - or does it and it's not shown in the photos? Louvers look good. Thanks for the C&P.
Re: Fram Racing HP17 Cut open w/pictures [Re: ZeeOSix] #5246204 10/21/19 03:12 PM
G
G
Originally Posted by ZeeOSix
... surprised it doesn't have a sealing surface on the end cap for the leaf spring/bypass valve assembly like the Ultra has - or does it and it's not shown in the photos? Louvers look good. Thanks for the C&P.
Nope. Metal on metal, and not a real tight fit. By-pass spring is STIFF. Can seems thicker as well.
Is this filter actually made by Fram ? The baseplate and louvered core are unlike any other Fram's I have seen in this size, 6607 / 7317.
Re: Fram Racing HP17 Cut open w/pictures [Re: geeman789] #5246208 10/21/19 03:15 PM
Sayjac Offline
A Fram with a louvered centertube...Oh the humanity! Are louvered center tubes in the future for other Frams? popcorn
The bypass and flat compression spring combo and endcap interface look very similar to some Champ Labs filter anecdotes posted here. If the metal surfaces milling and flat compression spring pressure good, should be fine.
Thanks for c&p.
Re: Fram Racing HP17 Cut open w/pictures [Re: geeman789] #5246218 10/21/19 03:22 PM
I
Ignatius Offline
I
I have thought about using one of these instead of a Subaru OEM Fram in a blue can and aside from the heavy duty construction that you certainly pay extra for, the only functional advantage you gain is the silicon ADBV.
I have gone round and round thinking about Napa Gold/Wix and Fram Ultra as alternatives to the OEM blue can be it about bypass, flow rate, delta-p, blah blah blah and have decided to just use the Fram Ultra XG7317 or the TG7317 and be done with it.
But those Napa sales and cheap Premium Guards on Rock Auto... I'll be doing this all again soon enough I'm sure ontome
2018 Subaru Outback Limited - 75,000 miles
2018 Subaru Outback Premium - 30,000 miles
2012 Hyundai Accent GLS - 93,000 miles
2005 Dodge Sprinter 3500 - 161,000 miles
Re: Fram Racing HP17 Cut open w/pictures [Re: geeman789] #5246225 10/21/19 03:32 PM
Sayjac Offline
Looking further the base/tapping plate design also looks very much like a Champ Labs made filter. Fram 7317 series uses the protruding thread boss design. This one looks very much like the Champ Labs 6607 baseplate, can find it on the current Super Tech. Combine with louvers and bypass endcap design I'm now wondering if Fram subbing these out to Champ Labs? Is there some type of collaboration for the HP filter? Or is this just a Canada thing? hmmmm As Artie might say here...…
[Linked Image from pushpull.files.wordpress.com]
Re: Fram Racing HP17 Cut open w/pictures [Re: geeman789] #5246557 10/21/19 09:23 PM
K
kstanf150 Offline
K
Thanks for the cut and post
I’ve always wondered about the insides of a Fram Racing
Thank you !!👍
