Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
50 registered members (2002 Maxima SE, AlienBug, 2015_PSD, ArrestMeRedZ, 2009Edge, 7 invisible), 937 guests, and 18 spiders.
Topics298,820
Posts5,141,917
Members70,129
Most Online3,589
Nov 2nd, 2019
2008 Mustang V6 ATF #5245844 10/21/19 09:58 AM
Sixxer Offline OP
I have used Amsoil previously, but I am looking to use something I can pickup at the store without issue. I’ve used Castrol import in the wife’s Mazda and can’t decide between Castrol or MaxLife. The car is at 135,000 and is driven mostly highway/stop and go traffic on the return from work. I haven’t noticed any transmission issues as of yet.
Thanks in advance
2008Mustang
Current fill: RoyalPurple
Current stash:15RoyalPurple 10QSUD 19Peak 5NxtGN 5SSAmsoil 5PU 10PP
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245860 10/21/19 10:15 AM
MolaKule Offline
Global Moderator
Global Moderator
Which Amsoil, ATF or ATL?
What is the ATF specification for transmission, Mercon LV?
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245863 10/21/19 10:17 AM
bdcardinal Offline
Mercon V was the spec. The hardest part about these transmissions is filling the unit through the drain plug.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245870 10/21/19 10:20 AM
Sixxer Offline OP
MERCON V Is the spec and yes they are a pain to service. My concern was that many of the fluids I see specify LV and not V and a quick google search tells me not to mix them. Some people have private messaged Valvoline and we’re told it would be okay, but why isn’t it listed on the bottle? Just looking for feedback from those that have had success Yes Amsoil ATF
2008Mustang
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245907 10/21/19 11:12 AM
Silverado12 Offline
I use NAPA Merc V. I'm assuming you have the special fitting to fill through the drain plug, because if not you'll need that. You can find them on eBay, etc. I think my 2010 GT took about 5 quarts with a new filter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5245925 10/21/19 11:27 AM
J
Jimzz Offline
J
Maxlife should work fine, used it in several rangers and other ford vehicles that called for Mercon-V
If worried then supertech Mercon-V will work also.
yup
Re: 2008 Mustang V6 ATF [Re: Sixxer] #5246066 10/21/19 01:10 PM
69GTX Offline
I'm in the same boat with my 2001 Lincoln. And in all the research I did I didn't see anything that suggested moving down from a Mercon V medium viscosity of 7.5 cSt @100 C to a LV (Dex 6) at 5.8 cSt was a great idea. Most regular Mercon V's are semi-synthetic and will shear down over a 20,000-30,000 mile OCI to about an LV spec. But there are full synthetic Merc V's that will stay up at 6.8-7.2 during their lives. Mobil 1 ATF and the Amsoil or Redline syn ATF's are of the correct viscosities and will not shear down much. MaxLIfe ATF is a great fluid....but it's not medium viscosity. Until I see a ton of evidence that the Merc V vehicles ran 150K-200K miles on "only" Max LIfe fluid, I'm not convinced it's a correct substitute.
Despite all that I use the Super Tech Mercon V (semi-syn) and have used Amalie Mercon V as well. The only ones that I know have the Ford Merc V approval are Super Tech and Castrol Merc V. I change out my ATF every 15K-25K miles based on color/appearance.
Whatever your Mercon V fluid is, change it every 20k-30k miles and you shouldn't have a problem. If you go to a Quick Lube place be aware they might put in the older Mercon/Dex 3. They've done that to me. So now I just change my own fluid 2-1/2 to 3 yrs.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
