Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69937 Registered Users
72 registered members (Bailes1992, atikovi, 53' Stude, 2K2AcuraTL, 01rangerxl, avi1777, 9 invisible), 1,497 guests, and 22 spiders.
Topics297,761
Posts5,122,046
Members69,937
Most Online3,589
Nov 2nd, 2019
Rate Thread
Floor jack - have to step on it to lower #5245783 10/21/19 09:01 AM
H
HoosierJeeper Offline OP
H
I have a floor jack that I need to step on for it to lower all the way down. I turn the handle, vehicle drops, pull it out and I have to push it down to get it down the last inch or so. Any ideas?
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: Floor jack - have to step on it to lower [Re: HoosierJeeper] #5245791 10/21/19 09:08 AM
SteveSRT8 Offline
I can only compare it to mine, they both have a return spring. You probably need to lube it up it may just be a minor bind...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Floor jack - have to step on it to lower [Re: HoosierJeeper] #5245801 10/21/19 09:20 AM
W
WyrTwister Offline
W
Too much fluid ?
Wyr
God bless
Re: Floor jack - have to step on it to lower [Re: WyrTwister] #5245892 10/21/19 10:49 AM
H
hallstevenson Offline
H
Mine definitely slows down at the very bottom of it's travel and I have used my foot to push it down on occasion. Didn't think much of it though....
Originally Posted by WyrTwister
Too much fluid ?
I have one of the very common Harbor Freight floor jacks (steel, 3-ton, rapid-pump) and heh, just checked the manual about filling it.... As many know, HF has multiple versions of many parts. For this floor jack, they have (4) versions. I may have downloaded the wrong manual for mine. Three of them say
Quote
Add high grade hydraulic fluid (sold separately) slowly until the fluid reaches 1/4″ below the top of the Fill Port.
while one says
Quote
Add high grade hydraulic fluid into the fill hole slowly until the fluid reaches the top of the hole.
Re: Floor jack - have to step on it to lower [Re: HoosierJeeper] #5246035 10/21/19 12:47 PM
H
H
I've never added/changed fluid on it, it's just a couple years old. Just started this a month or two ago. Good idea on the return spring! I'll check that.
Re: Floor jack - have to step on it to lower [Re: HoosierJeeper] #5246120 10/21/19 01:58 PM
Yah-Tah-Hey Offline
Possibly binding due to accumulated friction at all the pivot points from lack of lubrication. The spring should be adequate if the pivot points have lube.
Re: Floor jack - have to step on it to lower [Re: HoosierJeeper] #5250463 10/26/19 09:02 AM
demarpaint Offline
I have a fairly new Harbor Freight 4 ton floor jack. Occasionally I have to put some weight on it to get it to fully come down. I was attributing it to the possibility that the Jack needed to break in a bit. I’m wondering if that is the case now. The Jack functions perfectly otherwise.
God Bless Our Troops
