Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
57 registered members (avi1777, atikovi, 97K15004WD, 2002 Maxima SE, ARB1977, anthonym6, 6 invisible), 1,301 guests, and 21 spiders.
Topics297,760
Posts5,122,001
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
2017 Chevy Cruze recommended oil filter #5245419 10/20/19 08:13 PM
E
Electromotive Offline OP
E
A couple months ago I noticed that Advance Auto has changed their filter application for the 2017 Cruze with the 1.4 liter gas turbo engine. It formerly called for a CARQUEST 84060 or Purolator PL12222. Now it calls for the CARQUEST 95140 and Purolator PL11403. Anyone know why the change was made?
Re: 2017 Chevy Cruze recommended oil filter [Re: Electromotive] #5245430 10/20/19 08:23 PM
Z
ZeeOSix Offline
Z
Probably a higher bypass setting that GM seems to be going to. Compare the bypass specs of the old vs new filter midels.
Re: 2017 Chevy Cruze recommended oil filter [Re: Electromotive] #5245488 10/20/19 09:45 PM
O
oldhp Offline
O
Went from approx 12lbs bypass to 22lbs bypass.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 2017 Chevy Cruze recommended oil filter [Re: oldhp] #5245560 10/21/19 03:49 AM
Snagglefoot Online Content
Online Content
Yes, this is equivalent to the Fram 12060 which has the 19-25 psi bypass pressure.This was discussed at length during the past year on this forum. It was to catch up with Chevrolet’s higher pressure oiling systems such as in the 2014 up LS 5,3 and 6.2 liter V-8’s which went from a 40 psi system to an 80 psi system.
If you want the job done right......do it yourself.
Re: 2017 Chevy Cruze recommended oil filter [Re: Snagglefoot] #5246251 10/21/19 04:03 PM
Malo83 Offline
Try the Wix WL10290 with 22 psi bypass.
