Creation date
by Duffyjr - 11/14/19 10:36 AM
Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
STP mulit purpose motor treatment + fuel stabalizer
by Chris142 - 11/14/19 08:08 AM
"Universal" electric coolant circulation pump
by Superflan - 11/14/19 07:32 AM
Thermostat question
by nicholas - 11/14/19 07:13 AM
why michelin changed their tire lineup?
by edwardh1 - 11/14/19 07:12 AM
how do you mark your name on key fob?
by edwardh1 - 11/14/19 07:08 AM
"New EV Battery Can Charge in 10 Minutes..."
by wemay - 11/14/19 05:52 AM
TDS review
by Espada - 11/14/19 03:30 AM
SD40 Guide Rod ?'s
by GumbyJarvis - 11/14/19 01:08 AM
contraption22, Caydel, Bull58, Koncrete_Cam, DirtyTony
69863 Registered Users
103 registered members (alarmguy, alchargo, Alfred_B, 14Accent, 8 invisible), 2,352 guests, and 20 spiders.
Topics297,404
Posts5,114,728
Members69,856
Most Online3,589
Nov 2nd, 2019
168 inch pounds feels really--really tight #5244613 10/19/19 10:36 PM
P
perfect_oil Offline OP
P
GM 3800 V6 Engine. I've had trouble with Wix filters leaking at the gasket before, so this time I decided to try the factory recommended torque spec which is 14 foot pounds. The torque wrench I used is a brand new Snap-on QJR117F inch pound torque wrench. I've used the same torque wrench previously to do the upper/lower intake manifold gaskets at 89 and 189 inch pounds respectively. No leaks from the replacement intake manifold gaskets. I will monitor the filter in the coming days, but 168 inch pounds feels really really tight. I kept hoping I would hear the click and I finally did.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244617 10/19/19 10:52 PM
Z
ZeeOSix Offline
Z
Did you keep track of how far the filter turned with 14 ft-lbs once the gasket hit the mount?
Re: 168 inch pounds feels really--really tight [Re: ZeeOSix] #5244620 10/19/19 11:07 PM
P
P
No I didn't. I kept turning it until I felt the wrench release and click.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244625 10/19/19 11:37 PM
T
tundraotto Offline
T
Just put the filter on - you're not seeing the forest for the trees. finger tight, then torque with hand, and check for leaks.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244628 10/19/19 11:54 PM
U
user52165 Offline
U
I assume that is a 1/4" drive and shorter than the more common 3/8" or 1/2" drive. Always seems tight because of the short handle....... the moment arm.
Sleep well.
50 years of oil changes and never used a torque wrench here.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244635 10/20/19 12:14 AM
R
Reddy45 Offline
R
If the threads had residual oil on them, you most likely exceeded the torque spec which would explain it feeling tight.
I doubt this is of any concern, but technically....
Re: 168 inch pounds feels really--really tight [Re: Reddy45] #5244637 10/20/19 12:20 AM
Z
ZeeOSix Offline
Z
It's still 14 ft-lbs when the torque wrench clicks, regardless if the threads are dry or lubed. Since it's an oil filter I'd think the torque spec assumes oily threads.
Re: 168 inch pounds feels really--really tight [Re: user52165] #5244646 10/20/19 01:21 AM
P
P
Sleep well.
The overall length is 8-3/4'' to 9-1/2'' depending on the torque setting and where the thimble is turned to. Being at 168 inch pounds, the thimble was probably turned almost all the way in---making the wrench shorter. Torque range is 40 to 200 inch pounds.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244674 10/20/19 04:15 AM
L
Lubener Offline
L
If I had issues with a particular filter in the past, I wouldn't use it again. You may have a tough time come next filter change.
The "thinking" man's friend.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244679 10/20/19 04:53 AM
Sayjac Offline
'Imo', it boils down to either you trust the OF torque spec listing and the torque wrench used, or you don't. Subjective feel should only enter into it for the latter case, then that makes the spec and torque wrench use moot. That said, even though Honda has an OF torque spec, I never use it. It's lube gasket, hand tight to 2/3-3/4 turn max, check for leaks. And I've used lots of (wix)/Napa Gold 5/7356, 5/1348 never a leak issue.
As an editorial aside, it's difficult for me to comprehend why one would continue to use a product that hasn't preformed to ones expectations often in the past. It's similar to reading another recent thread here purporting an OF leak of some sort, while simultaneously promoting purchase of the same product on another sub-forum. Puzzling. With the many OF brand purchase options, all I can assume is the benefits must far outweigh any issue or potential issue. Off my soap box.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5244957 10/20/19 11:43 AM
N
NoNameJoe Offline
N
Yeah I would expect it to feel tight, 168 inch pounds is around the upper limit on lots of torque wrenches that are 1/4 drive. Coupled with the short length of the tool it's going to feel really tight and you're going to have to muscle it.
Had you used a 3/8 it would have felt like nothing (and it was a good thing you didn't, you might not have felt a click at all at 14ftlbs). The feeling of tightness depends on the length of the torque wrench is all.
2015 Civic LX Coupe
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5245015 10/20/19 12:39 PM
slacktide_bitog Offline
People use a torque wrench on oil filters? hide
I just hand-tighten them
Re: 168 inch pounds feels really--really tight [Re: slacktide_bitog] #5245025 10/20/19 12:47 PM
SLO_Town Offline
Me too.
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Kendall GT1 Max 5W-30)
11 BMW E90 328i M-Sport (BMW TPT 5W-30)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5245069 10/20/19 01:31 PM
Z
ZeeOSix Offline
Z
^^^ That's why I asked if the amount the filter turned was measured with 14 ft-lbs. I did similar on my Z06 once just to see how far the filter turned with the called out torque spec, and it was around 3/4 turn. So never used a torque wrench after that.
Re: 168 inch pounds feels really--really tight [Re: perfect_oil] #5245966 10/21/19 12:03 PM
DGXR Offline
14 lb-ft may seem pretty tight but actually it's not that much. Even if the threads and the gasket are oiled... as long as it doesn't leak, you are good. And as long as your service intervals are reasonable, you shouldn't have trouble getting it off.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
