'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Looking for a soft riding car
by Nayov - 11/18/19 04:00 PM
Do you use one filter brand or many?
by wemay - 11/18/19 02:43 PM
ATV engine oil
by supton - 11/18/19 02:02 PM
10w30 HDEO or 15w40, others. What's in your engine?
by 53' Stude - 11/18/19 01:47 PM
GM dealer oil change: Who makes their oil?
by Benzadmiral - 11/18/19 01:45 PM
Don't Fix Your Car!
by Y_K - 11/18/19 01:18 PM
best LL01 oil (for F10 M5/S63Tu)?
by vafan13 - 11/18/19 12:55 PM
Stripped oil pan
by dosmom - 11/18/19 12:35 PM
HyunKia Wix 51334XP $6.73 @ Amazon
by SlavaB - 11/18/19 12:18 PM
spiffy63, WhiteMega1227, ak2az, vafan13, Breezeknees
69908 Registered Users
143 registered members (alchargo, 4WD, 645ja, 01rangerxl, Al, 69GTX, 15 invisible), 2,138 guests, and 19 spiders.
Topics297,607
Posts5,119,039
Members69,908
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Switch to High Mileage Oil or No? #5242802 10/17/19 09:21 PM
B
Blake1107 Offline OP
B
Hi, y'all! Been a member for a bit and just lurking and reading, but finally have a question. I've tried using the "Search" function for about 15 minutes to find some information, but I guess I just haven't been using this forum enough to know what I am doing.
I drive a 2016 F-150 4x4 with the 5.0. I purchased it just shy of 2 years ago with a little over 49,000 miles on it (has 84,500 miles now). I am unsure of what the previous owner ran (FS, Blend, etc). So, the first thing I did after I purchased was an oil change and put what I wanted in it, which was Amsoil SS 5W20. I have been going about 9,500 miles before an oil change and I drive 18,000- 20,000 miles a year. So, I average 2 oil changes a year. Oil consumption is minimal as I think I have only ever had to add oil once and was close to time to change the oil.
I ran Amsoil SS 5W20 every oil change until my last one because I have gotten tired of paying so much for oil. I know it's only twice a year, but paying double is just no fun anymore. I switched to Motorcraft Full Synthetic 5W20 after finding a good deal on it on RockAuto (believe I read that ConocoPhilips makes it) and have about 3,000 miles on it so far.
After hitting my local WM and picking out some oil for my wife's 2013 Equinox / 2.4L (Valvoline FS HM 5W30), it got me thinking, should I have switched to a HM formulation? I know my truck isn't old, but it does fall in the 75K+ range that the HM oils are advertised towards. Really like the qualities/benefits the Valvoline FS HM touts, too.
Those who have always run a FS, do you switch to HM formulations when you hit the "HM qualifications"? Am I best to just stick to what I am doing since I don't have any leaks and my truck is barely 3 years old? Any HM formulations to stay away from? I'd appreciate any advice on the topic!
Thanks in advance!
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242808 10/17/19 09:32 PM
M
mazdamonky Offline
M
Some will say no, some will say yes.
But in reality, will the switch to an HM oil hurt anything? No.
Can yous witch back to a non HM oil? Yes.
Will the HM oil keep you from having an issue down the road? Who knows, but possibly.
If the price is the same, I would personally use an HM over the non HM oil. Specifically with the Valvoline FS with Maxlife, they seem to believe it is superior to their regular Full synthetic across the board. Price being the exact same, i see no reason to run the non-Maxlife version instead. I feel the same way about any other Full synthetic HM such as Castrol HM or Supertech HM. When priced the same, you might as well get the extra seal conditioners and antiwear additives.
2018 mazda3 hatch 2.5 26148 miles
1985 rx7 1.1 100k miles
2002 protege 236k miles
1985 rx7 with a 5.0 swap
2020 corolla 750 miles
4 more running cars in yard not mentioned
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242810 10/17/19 09:36 PM
csandste Offline
I've put high mileage oil in relatively new cars and then switched again. Generally it was a monetary decision, if a high mileage oil cost the same I'd have used it. The standard "syn blend" at my oil change place is MaxLife, the conventional oil change is Daily Protection which is also a syn blend. Think the standard "syn blend" at Walmart is ST synthetic high mileage, they're killing a number of birds with one stone, there.
So not to worry. High mileage oils perform just fine and the contain conditioners, not swellers.
2017 Kia Soul Plus-- VWB 5w30-- 70,000 miles
Re: Switch to High Mileage Oil or No? [Re: mazdamonky] #5242814 10/17/19 09:40 PM
B
B
I noticed that when studying their bottles this afternoon. They have "star rankings" and the HM Maxlife ranked higher in most categories. Really confused me, but I figured it was a no brainer for her's and then made me wonder if it's something to run in mine, too!
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242817 10/17/19 09:45 PM
M
Mad_Hatter Offline
M
Another HiMi thread... coffee
Maybe this should be a sticky.🤔
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242818 10/17/19 09:46 PM
csandste Offline
Everyone has star ratings on their bottles. Means almost nothing IMO. Marketing play to get you to buy the more expensive oil. Forgive me for restating the same thing over and over but I use VWB because I can't change my own (condo rules and geezerhood) and I have a bunch of $10 oil change coupons. If I was changing my own I'd probably get the ST HM syn 5w30. My girlfriend has to park outside and I'm suggesting that for her next oil change-- low thirties at Wally World.
Re: Switch to High Mileage Oil or No? [Re: csandste] #5242824 10/17/19 09:58 PM
M
Mad_Hatter Offline
M
Wow that's harsh bro... you won't share any of the "bunch" of $10 oil change coupons with her? 😂
Re: Switch to High Mileage Oil or No? [Re: Mad_Hatter] #5242825 10/17/19 09:59 PM
B
B
I apologize. I really did try using the Search and couldn’t get it to work. Tried looking in specific forums, in posts and titles, etc, and my searches kept bringing up nothing about high mileage. Like I said, been on here for a while, just reading here and there, but not totally acquainted with Searching.
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242827 10/17/19 10:02 PM
M
Mad_Hatter Offline
M
I was just busting your chops.. besides, the search feature here DOES suck donkey bal$# (that's prolly gonna earn me another ban😂)..so no apologies necessary.
Scroll to page 2 or 3 of postings in this sub forum. You'll find a couple of threads on the subject.
Re: Switch to High Mileage Oil or No? [Re: csandste] #5242829 10/17/19 10:05 PM
B
B
The stars weren’t what swayed me, just thought it odd they would market it like that compared to the FS. You’d think they’d call it the same with added benefits for HM vehicles rather than saying it’s better in multiple areas. I liked that it was the same price as the FS and had the MaxLife benefits, too. Seemed silly not to get it over the FS.
Re: Switch to High Mileage Oil or No? [Re: Mad_Hatter] #5242888 10/18/19 02:56 AM
csandste Offline
She parks outside,drives less and probably needs syn.
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242919 10/18/19 04:34 AM
B
billt460 Offline
B
I'm beginning to think "High Mileage" oil is somewhat of a snake oil. Will it prevent seals on older engines from leaking? Possibly, if it's used soon enough. But there is no real way to tell. In most cases once a leak starts, it's not going to be stopped with high mileage oil. Reduced a bit? Again perhaps, but there is no way to accurately tell that either. A oil leak is just that... A leak.
In many cases they are hard enough to diagnose where they are coming from. Let alone how much, and / or if they have been reduced or improved by switching to HM oil. It's one of those products that, "can't hurt to try". And the oil manufacturers obviously sell enough of it on that basis alone.
But I think for most people like myself, who have tried it on an older, (29 year old) vehicle that has a few leaks, it's not going to do much, if anything. I'll keep using it for a few more oil changes, hoping for the best. But I would be shocked if anything really improved enough for me to keep using it beyond that.
I'll only add that I would love to be proven wrong about this. But I'm certainly not going to hold my breath waiting. As always, YMMV.
Re: Switch to High Mileage Oil or No? [Re: billt460] #5242923 10/18/19 04:52 AM
SubieRubyRoo Offline
Originally Posted by billt460
I'm beginning to think "High Mileage" oil is somewhat of a snake oil. I'll only add that I would love to be proven wrong about this.
MolaKule has gone on the record stating that high mileage oils generally have a more robust antioxidant package than a non-hi-mi version, along with other "good" stuff (usually extra detergents and seal conditioners). He even said it may be preferable to run high-mileage oil from day one to maximize its benefits; and considering that 99% of the time, the high-mileage version is the same cost as the "regular" version, what downside is there?
Re: Switch to High Mileage Oil or No? [Re: SubieRubyRoo] #5242935 10/18/19 05:20 AM
B
billt460 Offline
B
I'm not trying to stress any downside. I really don't think there is one. The stuff isn't going to hurt anything. But I could say that about most any oil or fuel additive currently out there. (Other than the added cost of using it, that HM oil does not contribute to). I'm simply saying I would like to know how many, if any, have had oil leaks stopped by simply switching to HM oil? That's the one and only reason that I, and many others have tried using it.
As far as antioxidants, detergents, saving the whales and poor the people, and all the rest. I really don't care simply because I doubt that is going to make any difference in an almost 3 decade old truck. Perhaps that's my fault, because I waited too long to try it. My truck started leaking around 10 years, and 100,000 miles ago.
There may be a valid argument in using this stuff from day one. I don't know because I don't have MolaKule's expertise. But then why don't the manufacturers put the additive package in all of the oils they currently sell, and be done with it? Like you said, It's not like the stuff costs any more. And if it were used from day one, again could it be proven it actually did anything 10 years and 150,000 miles down the road?
That's the problem with most of this kind of stuff. You don't have a clue if it's doing anything or not. STP still sells on that basis. It doesn't hurt anything. But can anyone prove it helps anything either?
I'm not trying to "pick on" HM oil. As I said, it can't hurt anything to try it. But like all the rest of these type of products, it's difficult to prove one way or another if they actually do anything. It's much like sex in that regard. If it makes you feel good, then go ahead with it...
Re: Switch to High Mileage Oil or No? [Re: Blake1107] #5242937 10/18/19 05:22 AM
demarpaint Offline
I see no real downside. If I can grab some on a closeout or some other great deal I'd have no problem using it.
God Bless Our Troops
Page 1 of 3 1 2 3
