Valve Stem Carbon Build-up from Oil in DI Engines
by paoester - 12/10/19 03:52 AM
New plugs in 2012 Frontier
by MolaKule - 12/09/19 11:02 PM
SN vs SN+
by natas - 12/09/19 11:02 PM
75w90 conventional vs syn???
by Doublehaul - 12/09/19 10:21 PM
UOA for my extended OCIs
by Kbuskill - 12/09/19 09:34 PM
Question on Job Interview Etiquette
by bunnspecial - 12/09/19 08:40 PM
Tesla V3 Supercharger - 1,000 MPH
by JeffKeryk - 12/09/19 08:16 PM
Drill bit test
by faltic - 12/09/19 07:50 PM
Xenum-comparing grp oil
by Marco620 - 12/09/19 07:37 PM
Tire Pressure Question
by The Critic - 12/09/19 05:59 PM
Rock Island Armory VR80
by DriveHard - 12/09/19 05:40 PM
STP S 2808 CUT OPEN
by 53' Stude - 12/09/19 05:24 PM
How dumb can she get, and what comes next?
by JimPghPA - 12/09/19 05:23 PM
BDCardinal is THE man!
by 2015_PSD - 12/09/19 05:23 PM
Prestone Command in Caterpillar Engine,
by George7941 - 12/09/19 05:01 PM
Online Tire Dealers Are A Threat?
by SubLGT - 12/09/19 04:39 PM
Rhawk, mrawlin, BBC489, JimmyRS17, scarecrowdjinnn
70080 Registered Users
51 registered members (askani79705, 69Torino, AurionX2, Aero540T, 87sammy, 77GrandPrix, 4 invisible), 834 guests, and 19 spiders.
Topics298,520
Posts5,137,080
Members70,080
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Help me pick- ZT mower maintenance #5240115 10/15/19 10:03 AM
SubieRubyRoo Offline OP
So, I finally got my Ariens Apex ZT mower after a fiasco with Lowes. It has the 24HP Kawasaki FR730V engine and the ZT-3100 hydros. Let's start off with money: since I plan on changing the oils and filters once a year, $100-125 for fluids & filters is not going to be a big deal even if it means I am over maintaining it. But I have several oils on the shelf that "would" possibly work. So here's my choices, let me know what you think.
Kawasaki 10W30 oil, Kawasaki button-sized oil filter, Kawasaki air filter, HydroGear 52114 filters and HydroGear 15W50 hydro oil is OEM.
1. Delo XLE or Rotella T5 oil or Motul 4100 15W50, VPB 10W30 (all currently on my shelf), Amsoil 10W40 Small Engine Oil, or?
2. XG3614 oil filter (OTS), NAPA Gold 7035 hydro filters, or?
3. Amsoil 20W50 hydro oil, or?
I'd imagine yearly usage will be somewhere around 100 hours; I know the manual says oil change every hundred hours and filter every 200 hours, but this is BITOG and I want something to do in the garage once winter hits, so I will be changing all three filters and oils every winter. Do I go all-out and get Amsoil fluids and low-micron filters, or use cheaper "spec" oils and filters which are rated 25-28 micron? For reference, oil change is 2.2 quarts with filter, and hydros are about 2.5 quarts each with filter. So three filters and 2 gallons of fluid total per winter.
Who has the most hours on an FR730V and/or ZT-3100s, and what was your maintenance regimen? smile
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240119 10/15/19 10:10 AM
N
NormanBuntz Offline
N
I had a Kawasaki motor on my 2005 Wright 52 inch ZTR, and I always used 5w-30 synthetic PCMO and Baldwin filters. I didn't see any reason to overdo it. My son still uses the mower in his business 14 years later with no engine work ever done.
Firesign Theater: "Heavy on the 30 weight, Mom."
2013 Honda Accord LX, 61K, 2nd owner
2007 Honda Ridgeline RTS, 95K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240139 10/15/19 10:39 AM
M
mattwithcats Offline
M
Wix 51516 and Shell Rotella T6 in 5W-40...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240145 10/15/19 10:46 AM
M
MParr Offline
M
You probably won’t be operating the mower in sub-freezing weather so, 20W50 engine oil will be fine. 20w50 for the hydros as well. Super Tech will be fine in both applications. Use whatever engine oil filter that you like. For the hydros, use a WIX/NAPA Gold hydraulic filter. WIX makes the Hydro-Gear OE filters and many other brands. You can probably pick up the Rotary branded filter a little cheaper. Change the engine oil and filter after the first 5 hours and every 100 hours thereafter. I have included the service manual for the ZT-3100. I changed the hydraulic oil in my Toro at first 75 hours.
https://www.hydro-gear.com/54ca412913_sites/hydro-gear.com/files/BLN-52441_P19.pdf
2019 VW Tiguan SE Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240147 10/15/19 10:47 AM
W
WyrTwister Offline
W
Diesel or gasoline ?
Wyr
God bless
Re: Help me pick- ZT mower maintenance [Re: WyrTwister] #5240156 10/15/19 10:53 AM
M
MParr Offline
M
It’s gasoline powered.
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240160 10/15/19 10:58 AM
T
tundraotto Offline
T
Most popular choice I know of and what I use is Mobil 1 15W-50 and the hydrogear filters 1 5gt jug will do both sides. The OEM filters dont have a drainback valve, so didnt feel like inviting any problems for myself.
Re: Help me pick- ZT mower maintenance [Re: tundraotto] #5240166 10/15/19 11:06 AM
M
MParr Offline
M
That’s right, there is no ADBV on the hydraulic filters. You’re asking for trouble if you run a filter other than a purpose built hydraulic filter.
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240170 10/15/19 11:10 AM
M
MParr Offline
M
WIX hydro filter WL 10102 is the same as the Hydro-Gear 52114.
Engine oil filter should be FRAM TG4967 or XG4967 or NAPA Gold 1394
Re: Help me pick- ZT mower maintenance [Re: MParr] #5240177 10/15/19 11:20 AM
That's what I came up with as well. Thanks!
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240180 10/15/19 11:23 AM
M
MParr Offline
M
That’s right. Rotary hydro filters may be a little cheaper. See above for engine oil filters.
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240275 10/15/19 01:34 PM
T
tony1679 Offline
T
FR691V here that sees 200 hours a year between 2 properties totaling 4 acres. Stellar engine. Been using 5W-30 Valvoline SynPower SN (still have a stash) it's whole life since the 8hr change and WIX 57035s @100-125hr OCIs. Literally runs identical to the day we got it. Never once even had to use the choke. A little splash of Techron here on rare occasion and maintaining the rest of the stuff like Kawasaki recommends, and it still runs like a champ. It's almost at 1000 hours. Wouldn't trade it. Stellar engine.
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240286 10/15/19 01:44 PM
Thanks tony thumbsup
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240298 10/15/19 01:54 PM
T
tony1679 Offline
T
Edited my post, forgot to say 5W-30 is what I've been running.
Re: Help me pick- ZT mower maintenance [Re: SubieRubyRoo] #5240385 10/15/19 03:21 PM
T
tundraotto Offline
T
Forgot to say I usually use the Mobil 1 15W-50 in the small engines too, now having a diesel I buy 15w-40 in bulk so will just use that in the engines.
I don't like the big plume off startup smoke I get from my new Kawasaki FR651V or 20yo B&S 21hp Intek that I get with 10W-30 or thinner.....the thicker winter grade seems lo leak less by the rings of the horizontal cyliners when sitting, and have less startup smoke.
Page 1 of 3 1 2 3
