I did the front brake upgrade to 13 inch rotors and calipers from the gmt 900. Bought the element 3 new calipers with brackets. and raybestos coated rotors with the raybestos police pads. The rotors have a good bit more area, and are thicker. Replaced the passenger side bearing hub that was causing false abs activation. I replaced the drivers side 6 months ago.
I forgot to snap pics of the calipers or the finished assembly.
I had to pound the bearing hub to get it out. I cleaned up the rust with an angle grinder with wire brus, and i used a stone to dress up the edge of the knuckle where i used a chisel.
The pads were FF, and the bearing is Timken.
