It meets spec, nothing more nothing less. I have used it with no problems over the years in both a Toyota Corolla and a KIA sportage that specs a DEX III type fluid.quote:
Originally posted by MC5W20:
Who is using this and what are your opinions. I can get this for $5.72 for a 4 quart jug. It so happens my refill capacity after a drain is listed at 4quarts.
Back when you used the Supertech Dexron-III/Mercon it was the Dexron-III(G). The current version of Supertech Dexron-III/Mercon sold on the shelves today is the Dexron-III(H), which is significantly improved over the Dexron-III(G).quote:
Originally posted by iontrap:
Back when I had my 00 Camry I used it for a couple of drain and refills. The tranny didn't like it, there occasionally was a hesitation in the 1-2 shift. I drained out the Supertech and replaced it with Pennzoil and never experienced any hesitation with it.
quote:
here I've allways thought ALL that red stuff met the same specifications!
Micheal,quote:
