Originally Posted by Vigg
Originally Posted by MParr
I happen to agree with you on the formulation was to meet CAFE standards. That is the only logical conclusion that I can come to. I really don't believe that using Mobil1 ESP is going to lead to catastrophic engine failure. I am going to post a link to the Mobil 1 UK link. It shows that Mobil 1 ESP 0W30 & M1 ESP 5W30 can be used for short drains. Whatever that means and Mobil 1 ESP 0W20 for extended drains.
https://www.mobil1.co.uk/which-synt...obil1&equipment_id=FawEcXL3l&p=2
Correct I don't think using the ESP would lead to an engine failure. Quite the opposite as I think it would be an excellent oil to run. There have been a few earlier build S4/S5/SQ5 that have had engines let go. Mine isn't an early build but I would hate for something to happen.
Interesting the UK site for Mobile and Shell say to use a 504 spec and 502 along with 508. I've tried to google Audi UK but cant for the life of me figure out where they list oil specs for models.
Originally Posted by KCJeep
I can see experimenting with the Motul but chasing after Liqui Moly is not likely worth doing IMO.
If you are seeing rapid TBN depletion maybe you are better off with the Castrol and having that quart top off to give it a nice shot in the arm through the OCI.
Not a fan of 0w20 in anything, but in a German engine it just seems silly. CAFE again for sure. Once out of warranty I'd be putting a good Euro oil in it for sure.
Very nice car by the way. The A4 was my favorite when recently car shopping.
I'll be honest I've never used Liqui Moly and personally think they are one of the "boutique" oils that cost a lot of money. Their oils seem to perform well but oils that are half the price seem to be just as good too. The main reason I threw it out there was just for the lack of options I have to choose from. If I still have this car when the warranty is up a good Euro oil will be going in for sure.
Also thanks for the kind words. Its actually my wife's car and she loves it. She had an S3 before and likes the bigger size of the S4 along with how nice it rides and how refined it looks inside. Its a type of car that does a lot of things very well.
Originally Posted by Tikka
Hi
Anyone make a suggestion as to why Boron levels are 9 in first test and 50 in second when same oil is used?
I've been told that Audi uses a bulk oil made by Castrol (Not the LL IV FE) for the factory fill, that's probably cheaper to manufacture but still meets the specs they require. I will admit that the Castrol LL IV FE add pack looks boring minus the Ti.
I see your in the UK. Can you confirm what oil spec Audi calls for over there for the S4/S5 models. Thanks!
Hi Vigg
I really wish I could be of more help to you. I tried contacting Audi UK but just hit a brick wall without specific vehicle details. Looking around the Audi forums would suggest the Castrol LL4 FE is the one to use. I could only find 3 VW508 oils available here. The Castrol, a Motul 508 specific oil and one from Millers Oils.
I did notice the Motul product shared its spec with Porsche C20 if that adds a string to your bow.
Sorry I cant help more.
