Havoline ProDS Syn 10W-30 $19.73 6-pack
by Jackson_Slugger - 10/23/19 03:02 PM
Wix Oil Filter Rating Question
by 02vito - 10/23/19 02:30 PM
Help me decide between Fram and Mobil 1
by ZiTS - 10/23/19 02:13 PM
2003 BMW E46 M3 Rotella 15w40
by Manners226 - 10/23/19 02:10 PM
Firearm solvent/oils
by HyundaiAbuser - 10/23/19 01:56 PM
Coloured wax
by Propflux01 - 10/23/19 01:36 PM
Elk Jerky
by 28oz - 10/23/19 01:15 PM
If idle is to be avoided?
by Rglossip - 10/23/19 01:01 PM
Beck Arnley Brake Pads FMSI Materials?
by jrvn - 10/23/19 12:39 PM
Aging - What the ....
by coopns - 10/23/19 12:13 PM
Chevron Supreme 5W20 Bay Area Trade/Sell
by e55amgbenz007 - 10/23/19 10:07 AM
Auto Extra 51348 Vs Napa Gold 1348
by BeerCan - 10/23/19 10:05 AM
Latest Scam Method?
by 2015_PSD - 10/23/19 09:47 AM
Medical bills from 3 year back
by stockrex - 10/23/19 09:31 AM
2019 Nissan Pathfinder CVT drain/fill.
by JTK - 10/23/19 09:19 AM
Do I need Intel RST?
by Quattro Pete - 10/23/19 08:50 AM
Anabond 230 for bonding brake linings
by sdowney717 - 10/23/19 07:29 AM
2010 Mazda 3 FL400s options
by Sixxer - 10/23/19 06:50 AM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
95 registered members (4WD, AdditiveOCD, AC1DD, 2010Civic, 72te27, 02vito, 5 invisible), 2,171 guests, and 34 spiders.
Topics296,391
Posts5,096,795
Members69,652
Most Online3,532
Jul 30th, 2019
Utility trailer tires.... #5213847 09/15/19 10:03 PM
K
kenwin30 Offline OP
K
looking for tires 205 75 15, the trailer is a 5x10, i have noticed the tires wearing on the inside. not sure if its inflation or the load. i'm in the lawncare business and i haul a john deere zero turn mower (1300 lbs) the tires i have are load c . any suggestions for a good tire??
Re: Utility trailer tires.... [Re: kenwin30] #5213872 09/15/19 10:34 PM
N
Newman88 Offline
N
All the 15" tires that have been installed in our work trailers none have lasted and I don't mean thread wear i mean absolute tire failure broken cords and what not. I see they sell 12 plys now for 15" wheels, so you might want to check that out. If you can up the size to a 225 75 15 there is 12 plys for this size tire only from my research.
Re: Utility trailer tires.... [Re: kenwin30] #5213874 09/15/19 10:37 PM
N
Newman88 Offline
N
Oh inside wear could be from bad/loose bearings or the axel is bent (AKA straight axel) instead of having the bend all axles have before overloading them.
Re: Utility trailer tires.... [Re: kenwin30] #5213884 09/15/19 10:50 PM
ls1mike Offline
I run a load range D Carlisle Radial Trail HD on my TT. I put about 3000 to 5000 miles on them a year.
The last set were the same just a load range C and they did very well. They are 8 ply and rated to 81 mph.
Have you considered an LT tire? I know guys who use the on their trailers.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Utility trailer tires.... [Re: ls1mike] #5213887 09/15/19 10:54 PM
N
Newman88 Offline
N
Thats all we use on the 15" wheels (10 plys) none have lasted in our type of work. But to be fair our guys probably go over the speed rated on the tire.
Re: Utility trailer tires.... [Re: kenwin30] #5214011 09/16/19 05:43 AM
Donald Offline
Go up to load range D. Avoid the cheap Chinese tires you never heard of.
2015 Ford F250 w/Powerstroke
Re: Utility trailer tires.... [Re: kenwin30] #5214046 09/16/19 06:49 AM
K
krismoriah72 Offline
K
Been there done that.. like someone said its either bearings or bent axle. Mine had a bent axle. I sold mine for $300 less than i paid for it, which would have been about the cost of repairing mine.. and bought a new one.
Re: Utility trailer tires.... [Re: kenwin30] #5214059 09/16/19 07:06 AM
CapriRacer Offline
First, a 5X10 trailer isn't going to carry much load unless it is overloaded. So I don't think the tire brand matters too much.
Second, tire wear on the inside shoulders is an alignment problem - either a bent axle or the trailer is being overloaded.
Third, the Goodyear Endurance series seems to be performing well. Been out in the market for 3 years and no failures reported.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Utility trailer tires.... [Re: kenwin30] #5214167 09/16/19 09:12 AM
M
Miller88 Online Content
Online Content
M
I third the axle being bent or the bearing being bad.
That's one of the downsides to used trailers , they always have bad bearings or a bent axle
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Utility trailer tires.... [Re: kenwin30] #5214281 09/16/19 11:32 AM
T
thastinger Offline
T
I think you have a bent axle...but Maxxis makes an E load tire for a 15 inch wheel. I have 4 of them on my toy hauler with thousands of issue free miles.
Re: Utility trailer tires.... [Re: thastinger] #5214285 09/16/19 11:34 AM
M
mattd Offline
M
I prefer Goodyear marathons for trailer tires.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Utility trailer tires.... [Re: kenwin30] #5214315 09/16/19 12:06 PM
CKN Offline
Curb hopping usually causes bent axles. As an avid RV (travel trailer) tower-I can tell you that any tire that has a nylon belt under the tread is OK to buy. The biggest cause of trailer tire failures are curb hopping, under inflation and excessive speed. Many trailer tires in that size are only rated for a maximum of 65mph at the maximum inflation.
The GoodYear Marathon and Carlisle HD (ST) are great tires.
Re: Utility trailer tires.... [Re: kenwin30] #5214324 09/16/19 12:15 PM
1
1978elcamino Offline
1
You would be better off replacing tires once a year and saving your money to upgrade your trailer with a new unit that has a more heavy duty axle, springs and room in the well for a 16" tire so you can run LT truck tires. For everyday use with a utility trailer, that will be the only solution besides replacing the axle and upgrading springs, which your trailer may not be worth putting that kind of money in to. In Florida, tons of 6 1/2 X12 trailers are sold as "heavy duty" with 5000lb axle's and 16" wheel & tire package to lawn care guys.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Utility trailer tires.... [Re: kenwin30] #5214550 09/16/19 05:51 PM
BeerCan Online Content
Online Content
Maxxis or GY Endurance are my favorite trailer tires in 15 inch. I have had great luck with the Maxxis through the years
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: Utility trailer tires.... [Re: kenwin30] #5215009 09/17/19 07:44 AM
E
Excel Offline
E
ill never buy trailer tires again for a trailer,I switched to LT tires and never looked back
2015 Ford F150
2015 Ford Mustang GT,Whipple powered
2017 Yamaha FZ09
