2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
Ollie_B_2000, akarip, BJD2020, ToyTaco2002, EarlT500
70802 Registered Users
109 registered members (1978elcamino, 4WD, 64bawagon, 2012AccentSE, 1911CHAMPION, 2015_PSD, 8 invisible), 2,002 guests, and 16 spiders.
Topics301,945
Posts5,205,971
Members70,802
Best strut mounts? #5210197 09/11/19 01:51 PM
I
inquirer Offline OP
I
After replacing my car's front strut mounts (Mitsubishi Lancer 1.5L, model of 2010) with KYBs, one of which has started to fail only after about 12000 miles, I wonder which manufacturers produce top quality aftermarket strut mounts.
Currently I'm between Monroe and NTN-SNR.
Any opinions about the quality of their strut mounts or maybe any other suggestions?
Thanks!
Re: Best strut mounts? [Re: inquirer] #5210212 09/11/19 02:05 PM
B
Bottom_Feeder Online Content
Online Content
B
It's failing or simply loosened up?
KYB's are highly decent and should last a while. Monroes should be avoided. Best bet would be OEM.
Re: Best strut mounts? [Re: inquirer] #5210217 09/11/19 02:11 PM
Char Baby Offline
OE
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Best strut mounts? [Re: Bottom_Feeder] #5210227 09/11/19 02:17 PM
I
inquirer Offline OP
I
Well, the piston of the shock absorber jumps when turning the steering wheel. Also the mount is noisy when driving over small bumps. It crossed my mind to tighten the bolts. Can it be something that simple? I hope so.
Anyway, I was not impressed with their quality. The bearing didn't fit tightly in the mount and the mechanic used the old bearings to avoid creating a noisy set up. I also have to mention that by Googling I have found many negative posts about KYB strut mounts in different forums.
Re: Best strut mounts? [Re: Char Baby] #5210231 09/11/19 02:20 PM
I
inquirer Offline OP
I
Originally Posted by Char Baby
OE
Sure, but they are definitely overpriced. I exclusively use aftermarket parts and that's my first bad experience.
Re: Best strut mounts? [Re: inquirer] #5210247 09/11/19 02:28 PM
The Critic Offline
OE
The situation with aftermarket seems to get worse by the month. I would strongly caution against taking that position.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Best strut mounts? [Re: inquirer] #5210249 09/11/19 02:28 PM
T
Trav Offline
T
NTN-SNR are better quality than Monroe or KYB aftermarket. Those or OE.
Re: Best strut mounts? [Re: inquirer] #5210251 09/11/19 02:29 PM
W
Wolf359 Offline
W
Monroe is probably the top seller so that's why you get people who say to avoid them because statistically you're going to get a range of people who will have problems with them and the most popular one is going to have the most negative comments. KYB is also up there and same with the negatives. I've had ok results with Monroe myself. Usually best in general is OEM.
Re: Best strut mounts? [Re: The Critic] #5210265 09/11/19 02:37 PM
I
inquirer Offline OP
I
OE
It depends. At the same price as OE brake pads or shock absorbers, you can buy upgrade parts.for example, brake pads that are intended for high temperatures or shock absorbers intended for sports driving like Bilstein B6.
Re: Best strut mounts? [Re: inquirer] #5210321 09/11/19 04:10 PM
M
maxdustington Online Content
Online Content
M
Powerflex. They make a noticeable difference in grip while cornering and you will never have to replace them again.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Best strut mounts? [Re: maxdustington] #5210328 09/11/19 04:20 PM
I
inquirer Offline OP
I
I don't think they have any products listed for the 1.5 Lancer or am I wrong?
Re: Best strut mounts? [Re: inquirer] #5210347 09/11/19 05:03 PM
M
maintenanceMan Offline
M
I bet your top mount bolts aren't tight. When I install struts, I find that after driving for the first time, I often need to tighten things up.
Re: Best strut mounts? [Re: inquirer] #5210355 09/11/19 05:21 PM
G
GZRider Offline
G
Do believe Sachs is OEM on American built Toyota,seems like the route to go if you cannot get OEM at a reasonable price.
Re: Best strut mounts? [Re: inquirer] #5210423 09/11/19 06:25 PM
J
Jimzz Offline
J
Most are made in china. So its a crap shoot at best.
What I have done that seems to work well is take them apart and put better grease in them. The ones I have opened had very little grease and it did not look that good as well. Cleaned the bearings and pack them well with a good grease. Marine grease works well due to its wash out resistance.
Some are sealed so those are a bigger gamble.
yup
Re: Best strut mounts? [Re: inquirer] #5210445 09/11/19 07:00 PM
DukeOfFrontenac Offline
Not sure what to suggest in your case but the last couple sets of KYB shocks and struts I bought were a complete disappointment. Blew their guts out rather quickly. Sure, they are warrantied - send the dead ones back to them, they will inspect it, and let you know. While you wait for their answer, your car is up on jack stands going nowhere.
Years ago, KYB was my 'go to'. Not anymore.
