Forums Migration
Please read this thread
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
Mopar Extended Warranty with 100% Refund Option
by The Critic - 07/10/20 12:46 PM
The great lakes are warm!
by OVERKILL - 07/10/20 11:38 AM
OSX 10.15.5 Mail Program POP Issue
by JHZR2 - 07/10/20 10:51 AM
Slightly used Hyundais's and Kia's for sale...
by mattwithcats - 07/10/20 10:38 AM
Best power steering fluid to quiet fussy pump
by dfarr67 - 07/10/20 10:30 AM
Triple QX 5W40 Oil.
by SpitFire6 - 07/10/20 09:46 AM
626,000 mile Pentastar teardown
by wwillson - 07/10/20 08:25 AM
Price components of gasoline and diesel
by Snagglefoot - 07/10/20 08:20 AM
Peak Synthetic
by oilchangeguy - 07/10/20 07:01 AM
[Cut Open] FRAM Ultra XG7317 (6230 miles)
by DuckRyder - 07/10/20 06:41 AM
Need a New Frig
by Boomer - 07/10/20 06:01 AM
How to tell what engine mount is gone.
by mossietheno1 - 07/10/20 04:28 AM
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
95 registered members (Averroes, Astro14, 53' Stude, alchargo, aquariuscsm, 01rangerxl, 14 invisible), 1,857 guests, and 52 spiders.
Topics307,690
Posts5,315,904
Members71,907
Does TBN matter for low miles longer time change intervals? #5208150 09/09/19 01:38 AM
O
OilUzer Offline OP
O
Which oils are better for let's say 2 or 2.5 years oil change intervals?
Assume 2-3K miles a year, no short trips and good fuel.
Please let's forget about changing the oil once a year ... I am basically interested in knowing what makes one oil better than other for extended time.
Are the extended mileage oils also better for extended time? what can make one oil more suitable than other for example does TBN matter for extended time intervals?
Thanks!
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208152 09/09/19 01:42 AM
Z
zeng Offline
Z
It's the clinging that matters.
My vote goes to Magnatec and esters.
Re: Does TBN matter for low miles longer time change intervals? [Re: zeng] #5208158 09/09/19 02:12 AM
O
OilUzer Offline OP
O
Interesting you say that ... Was having lunch with couple of co-workers when this subject came up. I said I wouldn't waste my $ on expensive extended mileage or high TBN oils for a 2 years 5K miles oil change ... But I wasn't sure and that's why i posted this question.
My other friend said Magnatec can stick and dry up or leave stain if you don't drive the car much so he recommended against oils that stick (ester, magnatec, etc.) for this kind of application! lol idk, maybe he knows something!
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208161 09/09/19 02:26 AM
Z
zeng Offline
Z
2-3 years oci or storage at 2-3k miles per year is almost 'wholly' about corossion wear, despite no short trips.
Hence only high polarity or clinging matters, which prevents 'dry up/staining' as per your friend alluded to .
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208171 09/09/19 03:18 AM
csandste Offline
How much of Magnatec is technology (I'm sure it's somewhat better) and how much is ad copy?
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208191 09/09/19 04:42 AM
M
Mad_Hatter Offline
M
If you're not changing the oil but once every two years I'd think you could afford to send a sample in at the half way mark and have the TBN checked because no matter how much you try and prevent it, moisture will find a way into the engine.
That said, I'd guess to a formulator TBN retention is a "thing" for extended drain lubes. Can't very well advertise the lube is serviceable at 15 or 20k miles if the TBN drops out after 10k on the test rigs in the lab. And me personally, I'd like to have "clingy molecules" oil film if I'm only turning the engine over 3, 4 or 5x a year, to avoid dry starts if at all possible.
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208200 09/09/19 05:21 AM
M
Mainia Offline
M
Pull the fuel pump fuse or relay and crank the engine for 10 seconds then put the fuse relay back in. No worries about yearly changing unless you plan to road race for an hour. And don't waste your money with a UOA .....it is not 1970 oil.
2018 Lowered Hyundai Kona AWD 1.6T https://www.hyundaikonaforum.com/showcase/2018-kona-awd-1-6t-lowered.1162/
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208204 09/09/19 05:32 AM
Donald Offline
One would assume an extended mileage oil would have a higher TBN. But depletion of the additive package occurs from combustion byproducts. Which is mileage based.
However this assumes a properly working engine. If you have a coolant leak into the engine oil then better to get the oil out sooner than latter.
2015 Ford F-250 w/Powerstroke
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208257 09/09/19 07:26 AM
B
btanchors Offline
B
I wonder if a Marine oil might work well in this situation. Marine oils can contain extra rust inhibitors since those engines often sit in humid environments unused for periods of time.
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208284 09/09/19 08:17 AM
DrDanger Offline
High TBN is there to neutralize acids and combustion bi-products.
Low sulfur (something along 0,3%) means no aromatic compounds there to turn into waxy stuff/ sludge.
Quality fuel would not introduce this from the outside.
So any high mileage oil, specd at MB 229.5, BMW LL01 would do.
Those were especially formulated for longer drains and claims of ~30k km normal, 2 years/20k km severe, 1 year service OCI back here in Europe.
Re: Does TBN matter for low miles longer time change intervals? [Re: Donald] #5208312 09/09/19 08:59 AM
M
Mad_Hatter Offline
M
You're basically asking, what is the shelf life of opened oil. I don't know that it's possible to calculate that exactly because it’s situation-dependent. Oil need not be ran in order to degrade. Simply being exposed to oxygen and moisture can cause oil degradation. Unless you have absolute control of the factors that create acids in the oil, your oils TBN (or alkalinity) will drop over time. How much and how fast is anyone's guess (too many variables) but if I were essentially storing a vehicle I'd want a lube in there with a high starting TBN.
Knowing the TAN and TBN at the halfway mark would tell you if the oil is serviceable. Now whether or not YOU see the value in knowing the TAN/TBN is entirely up to you..but if I had an expensive hunk of metal sitting in my garage not being ran regularly, I'd consider the cost of such an analysis as an insurance policy against corrosion... and that is my 2 pennies.πŸ˜‰
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208369 09/09/19 10:14 AM
N
NO2 Offline
N
A higher TBN oil , such as M1EP, is available at very little additional cost, something like $3 per 5Q jug. I'd just use one of those and run it 2-3 years, or a Euro-spec oil if you have have a European car.
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5208938 09/10/19 05:08 AM
L
Linctex Offline
L
Any oil.... that is the answer.
It really doesn't matter.
I have started up engines that have sat for 20 years - on whatever oil has been sitting in the sump for the last 20 years.
I honestly don't think ANY amount of "speculation" on here will make any difference.
Re: Does TBN matter for low miles longer time change intervals? [Re: OilUzer] #5209028 09/10/19 08:23 AM
K
KevinP Offline
K
My vote goes with the "It doesn't really matter". Sell your car and take an Uber. LOL....
Re: Does TBN matter for low miles longer time change intervals? [Re: KevinP] #5209035 09/10/19 08:31 AM
M
Mad_Hatter Offline
M
Makes sense, if it's not a classic or sought-after model.. it's a depreciating asset.πŸ˜‰
