What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
Oil changed yesterday on F150
by redhat - 02/28/20 07:30 AM
Intel or AMD Processor
by ZeeOSix - 02/28/20 04:02 AM
Denso Reman Starter Noise
by The Critic - 02/28/20 02:59 AM
Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
89 registered members (14Accent, 77GrandPrix, 4WD, 1978elcamino, andyd, 440Magnum, 7 invisible), 2,229 guests, and 15 spiders.
Topics302,036
Posts5,207,809
Members70,821
HM oils #5186045 08/13/19 01:25 PM
L
loneryder Offline OP
L
Just what is in HM oils that stops or slows oil leaks? Also do they contain more detergents?
Re: HM oils [Re: loneryder] #5186064 08/13/19 01:43 PM
SirTanon Offline
The consensus here is that HM oils have a slightly higher dose of detergents and a heavier dose of seal conditioners.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: HM oils [Re: SirTanon] #5186100 08/13/19 02:13 PM
demarpaint Offline
And are on the "thicker" side of the grade.
God Bless Our Troops
Re: HM oils [Re: demarpaint] #5186204 08/13/19 04:02 PM
CR94 Offline
Originally Posted by demarpaint
... And are on the "thicker" side of the grade.
Not necessarily. See Pennzoil Platinum HM.
2011 Toyota Prius now at 109K
Re: HM oils [Re: demarpaint] #5186278 08/13/19 05:32 PM
spk2000 Offline
I have found the Valvoline Maxlife to be on the lighter side of the spectrum. Mobil 1 and most brands are generally of higher viscosity though.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: HM oils [Re: loneryder] #5186386 08/13/19 08:00 PM
L
Loobit Offline
L
HM oils have a larger dose of seal conditioners. Other things that differentiate it is a tad more ZDDP, most may be on the thicker side of the specified weight, more detergent is definitely included and makes the oil act like a mild flush, and you may even see a good dose of moly. I think many HM oils were API SL up until recent years (correct me if I'm wrong). Mobil 1 HM recently became an API SN oil. The only HM oil I can think of that is API SL still is Royal Purple HMX.
Re: HM oils [Re: demarpaint] #5186394 08/13/19 08:09 PM
B
bbhero Offline
B
True ^^^^^
On both counts..
Havoline high mileage 5w30 has a HTHS of 3.4... And most others are above 3.2.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: HM oils [Re: SirTanon] #5186941 08/14/19 11:32 AM
L
L
What do they use for "seal conditioners"?
Re: HM oils [Re: loneryder] #5186966 08/14/19 11:55 AM
O
OilUzer Offline
O
I don't recall any consensus except that HM oil are on the thicker side of the spec. Meaning that a thicker non HM oil would be the same ... I thought HM oils having extra seal conditioner and/or sweller were not substantiated?!
