Originally Posted by Ws6
Is this why the 370Z makes 332hp and gets 26mpg highway and the LS7 Z06 made 505hp and got 24mpg highway?
(I owned both cars. The 370Z actually managed 26.5 and the Z06 managed 26, both driven at 75mph).
Man, that theory is all wet.
I'd say that's a poor comparison to something that will be humping hills with the aerodynamics of a barn door with the weight of a barn all day long.
Not only that but you invalidated your point. Both cars get... the same mpg... doing the same work (traveling unloaded at 75mph). Neither is requiring anything close to their max power to cruise. Is one heavier and/or boxier than the other?
You can bet the BSFC for the Ford will be poor.
-Port fuel injection
-No DoD
-Probably
It does look like they did a pretty solid job building what, barring some Murphy intervention, should be "a million mile engine", though. It's hard to argue their choices with durability in mind sacrificing efficiency and performance. I do applaud Ford for seeing the death of Diesel and doing something proactive about it.
Port fuel injected engines can get great BSFC if they are designed and tuned correctly.
For an engine that is running loaded, DoD is of limited value for saving fuel.
Don't know what the CR is, but I did briefly get a glimpse of the piston crown on Mr. Truck's YouTube video, and it was an inverted dome, so probably is significantly less than 11:1. That will hurt fuel economy.
When Ford first announced the engine months ago, their engineer said the 7.3 is tuned stoichiometric everywhere on the map, and that will help fuel economy. I don't know what kind of tricks they are pulling to save the catalytic converters at exhaust temperatures that must be topping 1700F, but I hope they have a solution. I got to be familiar with the tuning of GM's L83 and L86 engines a few years ago, and they are tuned to run rich at WOT, but the point of enrichment varies according to engine speed. At 1500 rpm, throttle setting has to be above 90% to get full power enrichment. At 3600 rpm, 75%. At 5000 rpm, 50%. (Approximate numbers quoted from memory.) Peak thermal efficiency of the L83 was 37% at 2500 rpm, 160 hp. But thermal efficiencies of 33% persist up to 3600 rpm. But by the time the engine got to peak torque WOT at 4100 rpm, thermal efficiency was below 30%.
I've never bought into the concept of having a truck engine with peak torque above about 3000 rpm; in my opinion, the power isn't really usable for the heavy duty customer. I don't want to hear the engine screaming above 4000 rpm when I'm pulling grades during a 10-hour day. And more important than not offending my tender ears is the need for good fuel economy and saving stress cycles on the machinery. For the customer that makes his living with his engine, these are very important considerations.
