Originally Posted by maxdustington
The Trav method for breaking them loose is gold: six point wrench with a decent amount of tension, then beat the top of the bleeder with a hammer. Do yourself a favor and get four new bleeder screws and apply anti seize to them.
It's a very easy job on a car that you know the bleeders have been exercised. A massive potential nightmare when they haven't been. Might be worth taking it to a shop if it's your DD. You can let them crack the bleeders and then DIY it in two years time.
I've had to take a pair of Vise Grips to a seized bleeder screw, luckily I was able to bleed the brakes and that caliper was replaced at the earliest opportunity. Penetrating oil(I like Penetro 90) applied a few days before the job and heat-cycled might help you out.
In this case, having a shop do it might not be an bad idea. If a bleeder screw seizes or breaks on them, you
may get a caliper on the house. I don't think Honda uses Ni-Cu lines in their braking systems. The Japanese seem to prefer stainless steel, I could be wrong.
For the cars I can get this to fit, this has been a time saver, and it's better than risking a damaged master cylinder(if the fluid was never changed, since rust past the MC's piston travel can damage the seals in it) -
https://www.motiveproducts.com/coll...r-kits/products/import-power-bleeder-kit
