Originally Posted by Stickygreen
Local dealer wants $8/qt for tgmo and haven't been able to find much better online. The Zepro moly looks good and I just used that this past oil change, but it also comes out to roughly $8/qt. Plan was to switch over to qsud 0w20 or stick with the Zepro if it comes on sale, but impulsively picked up two jugs of edge 0w20 for $17/ea. Being that our cx5 will be getting oil changes every 6 weeks or so (5k oci, 3-4K miles per month), would prefer to use a cheaper oil. Based on the edge 5w20 voa, thinking the 0w20 should be fine
With a 5K OCI, I really think you will be more than adequately protected using the Edge or even the Magnatec. I use no-name (Milesyn) bulk oil that's SN and DexOs certified at 5K OCI and the UOAs are just fine & dandy.
I'm not sure if the CX5 calls for 0/20 or 5/30 but in Cali, you'd be fine either way. I know some people will cringe but I've mixed 0/20 and 5/30 on plenty of occasions and the UOAs look equally stellar. If I intentionally mix, I use the same brand and product-line of oil. In my case, I purchase Milesyn in bulk buckets in both those grades. Been doing this for nearly a decade and my engines outlast the rest of the vehicles. -The important part is OCI commensurate with your driving demands.
Ray
EDIT: I have 2 Mazdas...
