Did the diffs on my Liberty, filled the front till it ran out the fill plug and let it drain out of the fill, so the level is probably about even with the bottom of the fill plug. I was checking the manual today for a light bulb part # and noticed for the diffs it said spec is 1/2" below the fill hole. Should I suck a little out or is it okay to leave as is? Don't want to blow any seals out.
Thanks!
Thanks!
