Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
77 registered members (AndyB, aba4430, atikovi, 4WD, 53' Stude, 2010Civic, 4 invisible), 1,670 guests, and 18 spiders.
Topics301,818
Posts5,203,264
Members70,784
Page 1 of 3 1 2 3
Overfilled diff? #5166770 07/20/19 09:02 PM
H
HoosierJeeper Offline OP
H
Did the diffs on my Liberty, filled the front till it ran out the fill plug and let it drain out of the fill, so the level is probably about even with the bottom of the fill plug. I was checking the manual today for a light bulb part # and noticed for the diffs it said spec is 1/2" below the fill hole. Should I suck a little out or is it okay to leave as is? Don't want to blow any seals out.
Thanks!
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: Overfilled diff? [Re: HoosierJeeper] #5166773 07/20/19 09:08 PM
gathermewool Offline
At what temperature?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (72,320mi, 8/24/19)
15 Legacy Premium FB25
Magnatec 5W-20 + FU filter (47,300mi, 5/11/19)
Re: Overfilled diff? [Re: HoosierJeeper] #5166774 07/20/19 09:10 PM
H
H
I'm at below the fill plug cold, assuming the manual is a cold spec too.
Re: Overfilled diff? [Re: HoosierJeeper] #5166776 07/20/19 09:14 PM
Your manual doesn't spec cold or hot?
Re: Overfilled diff? [Re: HoosierJeeper] #5166780 07/20/19 09:17 PM
H
H
Nope!
Re: Overfilled diff? [Re: HoosierJeeper] #5166784 07/20/19 09:21 PM
Dyusik Offline
There is a breather on the diff. I'm overfilled on the Jeep, but have no idea by how much because my pinion angle is way off. No issues, additional drag is not a concern on that rig.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
Re: Overfilled diff? [Re: HoosierJeeper] #5166794 07/20/19 09:26 PM
Z
zeng Offline
Z
Leave it alone ......
for there isn't any (engine) crank to 'hit' the gear oil.
The gears and bearings will thank you for that.
The proof of the pudding is in the eating ....., by checking and ascertaining it's cool operating temperature.
Re: Overfilled diff? [Re: HoosierJeeper] #5166807 07/20/19 09:44 PM
01rangerxl Offline
I don't do the x amount below plug thing...fill it until it drips out.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 236K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 202K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 254K miles
Re: Overfilled diff? [Re: HoosierJeeper] #5166853 07/20/19 11:31 PM
R
Reddy45 Offline
R
Did you perform this service on a slightly angled driveway? If so, it's possible you got it exactly right anyway.
Re: Overfilled diff? [Re: HoosierJeeper] #5166883 07/21/19 01:53 AM
Char Baby Online Content
Online Content
Most or all of the diffs that I have serviced called the unit full when the gear oil drizzled out of the fill hole.
However, they also stated that if you can feel/get oil on your finger(when inserting in the hole) than that's good enough.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Overfilled diff? [Re: HoosierJeeper] #5166898 07/21/19 03:58 AM
demarpaint Offline
If it is level with the lowest part of the threads of the fill hole it is fine. In fact that is how I was taught to fill them in school. It can be there or up to a 1/4" below with no worries.
God Bless Our Troops
Re: Overfilled diff? [Re: HoosierJeeper] #5166918 07/21/19 05:19 AM
T
tblt44 Offline
T
I'm anal about that stuff, I would remove some.
Does it really matter I don't know.
I'm sure it's cold level not hot level.
My Chevy 10 bolt rear ends have that same call out.
Why in the world would they not place a drain plug in a location so you could fill to top of the hole.
It's hard to get it 1/2 to 5/8 below the fill hole on mine.
I use a bent pappaer clip to measure mine.
2003 Avalanche Z71 5.3
2006 Tahoe 5.3
1989 Yamaha moto 4 250
2004 Key Largo w/70 Yamaha 2 stroke
Re: Overfilled diff? [Re: 01rangerxl] #5166944 07/21/19 06:37 AM
4WD Online Confused
Online Confused
Done this way for years … front and rear on two sets of ramps to be level …
Re: Overfilled diff? [Re: HoosierJeeper] #5166992 07/21/19 07:24 AM
Sam_Julier Offline
I fill the diffs until it flows out on the Volvo 240 Dana 30 axles. This is what the Bentley 240 manual and my mechanic suggest. There’s never been an issue.
2013 Toyota Avalon Hybrid TGMO 0W20, 81k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 177k
Re: Overfilled diff? [Re: tblt44] #5166997 07/21/19 07:28 AM
P
philipp10 Offline
P
get therapy....lol
Page 1 of 3 1 2 3
