Slick 50
by rrretiree7 - 11/12/19 01:19 AM
Need Spring Compressor OTC 6494?
by Wolf359 - 11/12/19 12:48 AM
2009 Accord V6 terrible MPG
by JEL01 - 11/11/19 11:04 PM
How to fix exhaust broken at the flange?
by slacktide_bitog - 11/11/19 10:53 PM
Bugs Bunny
by red7404 - 11/11/19 10:40 PM
Keep with Conventional for 2001 Buick?
by JGmazda - 11/11/19 09:44 PM
Air Compressor Stalling
by spasm3 - 11/11/19 08:57 PM
1977 2-stroke moped ESSO 2-T 18:1?
by N8conn - 11/11/19 08:50 PM
*NEW* DELO 600 ADF
by SavagePatch - 11/11/19 07:48 PM
2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30
by Colt45ws - 11/11/19 07:24 PM
Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
Chizzle, greenmeanie, vw_sod, Mac87, LazyJ
69833 Registered Users
21 registered members (cjolson140, carlprop, Donald1953, BBDartCA, billt460, ArrestMeRedZ, 3 invisible), 698 guests, and 17 spiders.
Topics297,296
Posts5,112,465
Members69,833
Most Online3,589
Nov 2nd, 2019
Shelf life of Gumout fuel injector cleaner #5166507 07/20/19 04:24 PM
P
pentode Offline OP
P
Anyone out there happen to know what the shelf life of Gumout fuel injector cleaner (poorly stored in high temps) is likely to be? I was out of the country for 5 years and left this with a friend expecting he'd use it... he stuck it in his attic, which I expect was well into the 120F range for 5 summers.
It's not that I'm so cheap I refuse to buy another bottle - I just hate to waste stuff. I'm not so much concerned with how effective it might be, I'm more concerned with whether there might be any detrimental effects to the fuel system after sitting for so long. Anyone out there know enough about the chemical composition of this stuff to comment on whether it might be harmful to just dump it in the tank?
Oh, it's still sealed and looks normal as far as I can tell.
Re: Shelf life of Gumout fuel injector cleaner [Re: pentode] #5166517 07/20/19 04:33 PM
P
pbm Offline
P
I have noticed that Gumout Regane darkens a little over time.....I doubt it will hurt your engine but it may not be 'full strength' anymore....
'Journalism is Dead'
Re: Shelf life of Gumout fuel injector cleaner [Re: pentode] #5166662 07/20/19 07:17 PM
A
Audios Offline
A
Its probably fine if its sealed.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Shelf life of Gumout fuel injector cleaner [Re: pentode] #5166790 07/20/19 09:24 PM
V
VQ35DE Offline
V
Use it.
2017 Mazda CX-5 GS AWD
Re: Shelf life of Gumout fuel injector cleaner [Re: pentode] #5192471 08/20/19 08:06 PM
B
Bonnelvr92 Offline
B
Fuel additives do not really go bad, but if they sit for a long time you should shake them because some of the additives will decepate and get separated from the liquid they are stored in.
Re: Shelf life of Gumout fuel injector cleaner [Re: pentode] #5192579 08/20/19 10:51 PM
M
Mad_Hatter Offline
M
If the bottles been sealed that whole time, use it... worse case is all the more volatile constituents disappeared long ago and what you have left is the heavy parts and they wouldn't have harmed the engine anyhow once diluted in the tank.
