Let's Talk Porsche 911
by john_pifer - 02/21/20 02:51 AM
CLEARANCE ALERT O'Reilly's Mobil Super Oil
by GMguy84 - 02/21/20 01:27 AM
No more poulan / weedeater at walmart.
by jakewells - 02/21/20 12:44 AM
1991 Land Cruiser FJ80
by CCI - 02/20/20 09:57 PM
Gas price spread
by Chris142 - 02/20/20 09:28 PM
Need an Ecoboost Oil
by kstanf150 - 02/20/20 08:47 PM
2007 sedona
by macdole99 - 02/20/20 08:29 PM
USB-C, USB 3.0, 3.1Gen1, 3.1Gen2 Confusion.
by SubLGT - 02/20/20 08:12 PM
Apple Air Pro 2 tablet, How to send a link by email
by JLawrence08648 - 02/20/20 07:56 PM
Needed A Truck
by MParr - 02/20/20 07:21 PM
Battery Charger/Desulfator
by DBMaster - 02/20/20 06:45 PM
STP 0W-16 found in NC Autozone
by mv6845 - 02/20/20 06:20 PM
Cats
by Anduril - 02/20/20 06:12 PM
Are Onan oil filters now Fleetguard?
by atikovi - 02/20/20 05:57 PM
Car overheating under different conditions.
by MichaelRS - 02/20/20 04:39 PM
2008 CR-V AT Question
by Gebo - 02/20/20 04:18 PM
2019 Sienna
by s2krunner - 02/20/20 04:01 PM
Grennx, coverage, Bubbabighatt, AAIRCraig, Jason454
70763 Registered Users
27 registered members (alcyon, bachman, ctechbob, CNT, 53' Stude, 3 invisible), 1,065 guests, and 15 spiders.
Topics301,733
Posts5,201,586
Members70,763
Using synthetic to clean a crankcase #5162615 07/16/19 01:26 PM
NavyVet88 Offline OP
2002 Ford Ranger Edge 3.0L 67k
So my ranger that I have made quite a few threads about lately is running much better now after having replaced bad plug wires and a coil pack. Went ahead and replaced the serp belt and tensioner as well as the idler pulley.
The truck had Castrol conventional 5w-20 and a purolator filter from a quick lube joint when I bought it from previous owner. First thing I did was changed oil and filter to Castrol Edge 5w-30 and a fram xg3600.
How long should I run this OCI before changing it again if I’m wanting to clean the motor internally? I know it will take more than one change to see most if any results.
Do I leave the CE in it for a full 5k then dump it or sooner? What do you guys think? I do want to do a black stone UOA but I think doing one on a “cleaning” OCI would be pointless because of possible contamination from prior conventional oils.
2013 Honda Civic LX 1.8L 178k M1 HM 0w20 with Fram XG7317
2002 Ford Ranger Edge 3.0L 67k Castrol Edge 5w30 with Fram XG3600
Maintenance Technician by trade, working class for life.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162625 07/16/19 01:33 PM
Edit: forgot to mention that I did run a can of seafoam through the gas tank and then filled with premium gas as well. So for sure won’t be sampling this OCI for black stone.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162628 07/16/19 01:35 PM
O
oldhp Offline
O
What did the oil look like when you drained it? Did you cut open the filter? I would run it at least 2000 miles depending on what the old oil looked like.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Using synthetic to clean a crankcase [Re: oldhp] #5162677 07/16/19 02:17 PM
The oil looked decent for having been told by the previous owner that it had been changed approximately three months prior. Her driving conditions are/were unknown to me so I don’t know what it was exposed to during her time of ownership.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162687 07/16/19 02:37 PM
GumbyJarvis Offline
I had a 2.3L 2005 Ranger that was a fleet vehicle for a few years before I purchased it in 2008. It had 80,XXX miles on it and tons of idle time when I purchased it, there was some build up under the covers and even in the oil pan more than likely due to cheap conventional + high idle time.
I ran regular old quaker state/formula shell and kreen for a few short 500-1000 ocis. It cleared everything up and the engine now has 3x as many miles on it than it did when I got it new.
After that, QSHM/later Defy was usually used unless something was on sale/closeout (Eneos, Amsoil, MC, I ran anything) it's a Ranger, it really isnt going to be to picky as those Ford/Mazda truck engines are built to run for a long time.
Find whatever 5w30 is on sale and roll with it. The Vulcan engine isnt going to care. I'd be more concerned with the electrical system/ignition system (plugs/coils/wires), transmission fluid, and differential fluid(s) maintenance than I would the oil choice at this age.
If needed, run a few cleaning cycles, RGT right now I believe still has its rebates going if you insist on a synthetic.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162691 07/16/19 02:42 PM
demarpaint Offline
I doubt a synthetic oil is going to clean up an engine by running it for a short OCI or two. IMO you need something to help it along if you're looking for fast results. Synthetic oil might do better cleaning than dino oil, but from what I've seen it needs help in problem or neglected engines.
God Bless Our Troops
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162694 07/16/19 02:44 PM
Yeah I have heard a lot about the Vulcans going 200k+ miles with routine maintenance and general upkeep. Just want to make sure I am doing this the best way that I can.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162698 07/16/19 02:45 PM
RDY4WAR Offline
Synthetic oil doesn't clean any more or less than conventional oil with the disclaimer of that being a broad statement and not including group V oils that aren't used as primary base oils. The only case where group V oils make up the primary base oil is Valvoline Premium Blue Restore which is ~50% polyol ester.
In order to properly clean up varnish and sludge, you need solvency. Group III and IV synthetic base oils have very low solvency, especially group IV, which is why they are often blended with group I or group V base oils to solubilize the additive package. The goal of oil is generally not to clean up dirty engines. It's to keep engines from getting dirty in the first place.
As far as additives are concerned, neutral detergents have more surface affinity and a better cleaning effect. Overbased detergents are much more concerned with acid neutralization than surface cleaning. Most of the detergents in engine oils are overbased.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Using synthetic to clean a crankcase [Re: demarpaint] #5162699 07/16/19 02:46 PM
Well this particular fill of Castrol Edge was put in just before I ran a can of sea foam through the gas tank. I know that sea foaming an engine requires a not so distant oil change due to possible carbon contaminants making its way down to the sump.
Re: Using synthetic to clean a crankcase [Re: RDY4WAR] #5162711 07/16/19 03:04 PM
What do you recommend I do then if I want to clean my engine? What products?
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162714 07/16/19 03:08 PM
GumbyJarvis Offline
The right answer:
A severe service OCI and time.
Edit:
myself and others have had good results with Kreen, yes, but it isnt the "right answer" as most OMs do NOT suggest oil additives of any type
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162717 07/16/19 03:09 PM
10-4
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162718 07/16/19 03:14 PM
demarpaint Offline
Any early oil change after the Seafoam would be a good idea. I personally have seen little to no proof of synthetic oil in and of itself cleaning up an engine with a few short OCI's. Maybe over a few years of use it might do some light cleaning. I agree with RDY4WAR.
I'd give Kreen a shot if you can get it.
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162724 07/16/19 03:20 PM
T
tiger862 Offline
T
I recommend you change your oil at 5k and don't look back. Last vehicle I bought had 80k with sludge in oil filter. I carried it back to dealer and was told since I bought extended warranty to let that kick in then bring it back. I even showed him the car fax where the oil was supposably changed with plugs and brakes where nothing was done. I sent email to general manager and even went to talk to him so long story short I was incorrect and tech was correct. I ran short OCI with Maxlife for 1500 miles then changed oil at 5k or once a year with Pennzoil Platinum. I got 7 years with a small oil leak that developed and no engine problems. Only way to clean up a severely dirty engine is take it apart.
Tiger862
2018 Grand Caravan
Re: Using synthetic to clean a crankcase [Re: NavyVet88] #5162725 07/16/19 03:22 PM
K
Kamele0N Offline
K
Do what I did in my LC.....it was badly neglected....to the point that it "burned" <---- not literally because there was no smoke (its diesel) 4 liters of top off oil in 6 months....its turbine was whining so loud that everyone said that it is toast
I bought HDEO (Shell rimula 10w40 R6M)....plus new filter.....did an normal OCI (10kks)...and voila! Oil consumption is gone ( HDEO loosened its oil rings).....turbo has normal whine for a non DPF car (EURO3 engine...straight pipe)....looks like that oil washed away grit around turbo bearings!
Just buy any HDEO that you like!!!
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
