Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
Tar, cast71, bamadog1, jrogahn, DeathByNissan55
69571 Registered Users
25 registered members (billt460, Ag76, carlprop, Bailes1992, amng04, 5 invisible), 701 guests, and 25 spiders.
Topics296,028
Posts5,089,556
Members69,571
Most Online3,532
Jul 30th, 2019
2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter #5154353 07/08/19 05:14 AM
Deontologist Offline OP
2GR-FSE engine, 117k miles total, last OCI was 6500 miles with 0W-30 Mobil 1 AFE. Filter was an Amsoil Ea filter. Air filter is a Wix.
Lexus calls for 5000 mile OCI. I extended it to 6500 this time with a lot of idling too. Car is driven extremely hard. Sees 3.5k+ RPM on the regular. Oil consumption--car used maybe 1/3 to 1/2 a quart over the 6500 OCI. I actually overfilled the car slightly (maybe 1/4-1/3 of a quart) so by the end of the OCI, the oil level was just slightly below the second dot on the dipstick.
What are your thoughts?
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5154380 07/08/19 06:18 AM
F
ford46guy Offline
F
I have the same engine. I went by the oil indicator lamp and it allowed almost 11 months for about 4K miles. I use PP HM 5W30. Numbers look great, but it is one of the best engines on the planet.
That car should see 3K, it has IMRCs that need to be opened.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: ford46guy] #5154385 07/08/19 06:32 AM
What kind of car is your 2GR in? AFAIK no Toyota or Lexus has a "smart" oil life monitor as opposed to simple mileage/time counters.
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5154407 07/08/19 07:03 AM
F
ford46guy Offline
F
11 GS350. I know the one in my explorer has an additional oil temperature sensor to the computer and will always tell you to change in 6 months no matter what.
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: ford46guy] #5154416 07/08/19 07:24 AM
Ah, I see.
What do you mean by "IMRCs"?
Second, I noticed that viscosity of the 0W30 had sheared down right to the minimum viscosity for a 30 weight. According to EM, Mobil 1 0W30 AFE starts with a viscosity of 10.9 cSt at 100 C. My viscosity after 6500 miles is a paltry 9.3 cSt. Is this cause for concern? I'm running 5 qts of Mobil 1 HM 5W30 and 1.3 qts of Mobil 1 0W30 this time; this combination should probably shear less, huh?
What has me confused is that people keep saying that the 0W30 from Mobil 1 is extremely shear stable, but I'm getting the exact opposite. I ran the oil for only 6500 miles, and it was about to be a 20 weight. It wasn't as if I ran the oil for 10 or 15,000 miles. It's definitely not fuel dilution that's shearing the oil, as 2GR-FSEs, while direct injected, have few to no reports of fuel dilution issues (unlike Hondas). I'm guessing it just comes down to Florida heat coupled with a very aggressive driving style? Would I benefit from a thicker oil?
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=21945
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1878840
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5154477 07/08/19 08:35 AM
W
Wildcard Offline
W
i have the same engine in my car and i also bounce it off the redline daily yet youve got triple the amount of iron in your sample with less mileage than my last uoa... any reason you arent using 0w20 like its specced for?
also besides fuel dilution, this car has a timing chain that shears the oil, im also currently looking for something more stable that will hopefully also Cut down my fuel dilution
2002 acura 3.5RL
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Wildcard] #5154485 07/08/19 08:52 AM
It says 5W-30 on the cap and in the manual. I believe only earlier model years (like 2007) were back-specced to 5W-20.
Is the iron at a level to cause concern?
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5154569 07/08/19 10:42 AM
B
buster Offline
B
Results are fine. I'd try a stout 5w30 or a 10w30 in this high mileage engine.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5154699 07/08/19 01:08 PM
W
Wildcard Offline
W
ohhh this is gen 3 of the is350, gen 4 specs 0w20 but its weird, my car is the same exact engine, specced 0w20
2002 acura 3.5RL
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5156333 07/10/19 03:41 AM
Yeah I'm not sure why this engine got specced for 5W30, then 5W30 and 5W20, then only 5W30, and now 0W20.
Anyone else want to chime in on the results? The iron PPM/mile is similar to the iron PPM/mile on my neglected Camry, which had >80 PPM iron in its UOA.
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5171245 07/26/19 10:08 AM
K
kschachn Offline
K
One cannot tell from that UOA whether it is mechanical shear or fuel dilution that is affecting the viscosity. People on here like to blame viscosity deviations on mechanical shear but for the most part the UOA they post cannot distinguish between the two.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: Deontologist] #5171551 07/26/19 05:54 PM
B
bahnstormer Offline
B
I have a 2006 IS 250 that I bought new. Have been doing analysis every oil change since new. It has the 4GR-FSE which is down about 100HP on the 2GR-FSE. The engine is 2.5L not 3.5L and has only direct injection but basically has the same internals, valve train, timing chain, etc. It sees high revs regularly and also extended idling in Chicago traffic. I have run different types of oils over the years and it iron wear averages around 2ppm / 1K miles, sometimes less than 2. This wear rate is significantly lower than what your 2GR-FSE is showing despite regular hard driving that I do as well.
Re: 2012 Lexus IS350c, 6500 mi on Mobil 1 0W-30, Amsoil Ea filter [Re: kschachn] #5172226 07/27/19 02:53 PM
W
Wildcard Offline
W
i agree, you need a more thorough analysis to figure out whats goin on there, from a reputable lab
2002 acura 3.5RL
