Originally Posted by Snagglefoot
Sure. Vacuum it out with a plunger tool.
Not an option.
Originally Posted by 69GTX
When you run the mower out of gas, it takes about 30 sec to 1 minute to turn the mower on its side to drain out all the oil into Your drain pan. Actually, easier than used to be with the drain bolt on the bottom.
When I tipped my mower over to it's side - to enter into my vehicle's plastic six quart drain pan, the mower touches the drain pan - darn-near squashing it - to where it wants to teeter-toter and tip over.
(Or) Do I need to dig a hole in the grass - circling around my drain pan, allowing the drain pan to sit flush with the ground, to avoid tetter-totering?
Or am I supposed to hold the lawn mower upside down in total air suspension, while it drains - thus not tipping over my oil pan? Then go and have surgery for a hernia?
(Or) this one makes the most sense....
Have a 2nd person nearby to hold the oil drain pan while I turn it over. Then with the 3rd hand holding close to the fill hole, unscrew the cap and remove it fast, thus the oil drains into the plastic oil pan, while a 3rd and 4th hand is holding it close to the fill hole and firmly?
Why does this need to be a two person job? Or should I leave the round hole in my grass permanently and employ that flush-to-the-ground method, once every two years?
