Cadillac parked for 25 years...
by mattwithcats. 07/17/19 09:52 AM
Sumitomo Encounter Tires
by parshisa. 07/17/19 09:40 AM
API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
105 registered members (anw2397, Alfred_B, 4WD, 87sammy, aquariuscsm, 69GTX, 9 invisible), 1,937 guests, and 24 spiders.
Topics291,982
Posts5,014,534
Members68,682
Most Online2,967
Mar 10th, 2019
Greasing without a gun? #5143182
06/24/19 08:56 PM
06/24/19 08:56 PM
MURICA
maverickfhs Offline OP
MURICA
Alright so I don't own a grease gun yet and was wondering if I can grease up recently acquired trailer bearings without it?
I have ST all purpose grease and ST Moly Lithium, which would be good for it?
Thanks for the help and advise thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Greasing without a gun? [Re: maverickfhs] #5143189
06/24/19 09:02 PM
06/24/19 09:02 PM
Suburban Washington DC
atikovi Online content
atikovi  Online Content
If trailer bearings are regular tapered roller bearings, a grease gun would take a long time nor is chassis grease for wheel bearings. You need to pack them with grease by hand
Re: Greasing without a gun? [Re: maverickfhs] #5143201
06/24/19 09:23 PM
06/24/19 09:23 PM
SE Alabama
Fawteen Offline
Fawteen  Offline
SE Alabama
Buy a grease gun. You can get a cheapie disposable for less than $20. Or you can find one that is made in the USA and will last the rest of your life.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: Greasing without a gun? [Re: Fawteen] #5143203
06/24/19 09:25 PM
06/24/19 09:25 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Originally Posted by Fawteen
Or you can find one that is made in the USA and will last leak the rest of your life.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Greasing without a gun? [Re: Fawteen] #5143325
06/25/19 12:28 AM
06/25/19 12:28 AM
Cincinnati, USA
Dave9 Online content
Dave9  Online Content
Cincinnati, USA
Or you can find one for less than $20 that lasts the rest of your life. Grease guns don't tend to wear out, because they're WELL LUBED lol.
Re: Greasing without a gun? [Re: maverickfhs] #5143460
06/25/19 07:33 AM
06/25/19 07:33 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
As other have said, trailers typically have roller bearings. They last a long time if not abused. They need to be greased by hand with a blob of grease in your palm, pushing the bearings into it while rotating the bearing a little before each pushing. Your Dad typically show you how when you are a kid. You will need a new seal to do the inner bearing.
Now if a boat trailer then you want marine grease that says OK for boat trailers. I use the blue grease.
Boat trailers often have a bearing buddy on the axle to keep grease under a very slight pressure . They need a grease gun filled with marine grease for the bearing buddy.
People often check trailer bearings with a IR temp gun.
2015 Ford F250 w/Powerstroke
Re: Greasing without a gun? [Re: atikovi] #5143507
06/25/19 08:35 AM
06/25/19 08:35 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by atikovi
If trailer bearings are regular tapered roller bearings, ...... You need to pack them with grease by hand
100%
You really MUST pack tapered wheel bearings by hand to do it right.
Re: Greasing without a gun? [Re: maverickfhs] #5143512
06/25/19 08:42 AM
06/25/19 08:42 AM
WY
sloinker Offline
sloinker  Offline
WY
I like wheel bearing grease with lots of moly. It also needs to be "Ropy", meaning that it has real long strands of grease as you separate it. Hand packed only. As said above, you need to remove/replace the rear seal to grease that bearing. If it's a boat trailer then ignore my input as I don't know which grease you should use.
Re: Greasing without a gun? [Re: Linctex] #5143556
06/25/19 09:48 AM
06/25/19 09:48 AM
Northern KY
Elkins45 Offline
Elkins45  Offline
Northern KY
100%
They make a gizmo that lets you sandwich the bearing between two cones and pack it with a grease gun, but it’s probably more trouble than it’s worth. Your hands still get covered with grease regardless.
When I repacked my boat trailer I used the Mystic blue marine grease. It’s supposed to have maximum water resistance because the hubs get immersed all the time. For my utility trailers I just use the same high temperature lithium bearing grease that I keep in my gun. I have a separate smaller gun for the boat.
People agonize over grease choices but the important thing is just to make sure there’s grease in the bearing. Just about any grease will do as long as it’s rated for roller bearings and high temp.
Re: Greasing without a gun? [Re: maverickfhs] #5143674
06/25/19 11:59 AM
06/25/19 11:59 AM
NH
supton Online content
supton  Online Content
NH
I had bearing buddies on a new to me camper. I did some reading, decided I didn't like them, so I went to pull them off. They were pumped up nicely, but, all the grease was on the outside bearing. They had not gotten through to the inner. Maybe there was an air pocket and the grease would eventually work over, but in the end, since it wasn't going into water I removed altogether.
My latest acquisition has a zerk in the axle, in the center, the nut and bearing go over it. It's an E-Z-Lube or similar. Not trusting it, I pulled apart the bearings once I got the trailer home. This axle is set up to direct the grease through the spindle and to the bearing surfaces. Cool. I'm not sure how much I would trust it, maybe hit it with a few pumps once every 1,000 miles or somesuch--but I think pulling apart, inspecting, and packing in some fresh grease is always a good idea. I just don't know what is a good interval for it (yeah you can read your owners manual but who wants to do that?).
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
Re: Greasing without a gun? [Re: Elkins45] #5144325
06/26/19 07:00 AM
06/26/19 07:00 AM
100%
The problem is that most grease cartridges for guns have grease suitable only for suspension parts. Tie rods and steering linkage joints don't get hot during use like roller bearings do which are in nearly constant motion. You need that ropey consistency specific wheel bearing grease and that is probably too thick to dispense with a gun.
Re: Greasing without a gun? [Re: maverickfhs] #5145273
06/27/19 05:37 AM
06/27/19 05:37 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
The best way to lube wheel bearings is to pack them by hand. Using a grease gun leaves old grease in and you would stress the seal trying to get it out. Never could understand why a fitting is put on the grease cap anyway.
The "thinking" man's friend.
