API 1509 Updated with New GF-6B Shield
by Solarent. 07/17/19 07:27 AM
Car Vac Recommendations
by klt1986. 07/17/19 07:05 AM
ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
guru2019, MBhuntington, captainfloss, Lyndol, Belczek
68682 Registered Users
103 registered members (4WD, AlienBug, AandPDan, 69GTX, Alfred_B, 2010Civic, 10 invisible), 1,884 guests, and 22 spiders.
Topics291,979
Posts5,014,501
Members68,682
Most Online2,967
Mar 10th, 2019
Volvo S80. #5142553
06/24/19 08:23 AM
06/24/19 08:23 AM
Ohio
D1dad Offline OP
D1dad  Offline OP
Ohio
My daughter has an 07 s80, 3.2 liter and is a royal pita to service and I dread every oil change. I’ve never done an analysis and really don’t want to, yet I get that’s the only way to tell how long she can go between changes. I’ve been doing 10-15k on liqui moly but have ran out and scored some crazy good deals on oil lately and wanted an opinion of which oil I should use and recommended length I can go. I’m not an extended drain kind of guy but being a non turbo with a huge sump I feel you can. The car takes over 8 quarts and uses a canister filter, which I use Mann filters. On hand I have these oils.
PP 5-30 HM
Valvoline 0-40, not the European oil
PP 10-30
Mobil 10-30 HM synthetic
The car uses no oil and no drips or leaks and has just over 100k.
Re: Volvo S80. [Re: D1dad] #5142561
06/24/19 08:27 AM
06/24/19 08:27 AM
South Wales, UK
Bailes1992 Online content
Bailes1992  Online Content
South Wales, UK
If it's that hard to change the oil is it worth looking at external filters and maybe a bypass filter? You may be able to get away with just filter changes and never have to change the oil.
'17 Volvo V40 D3 Geartronic - Castrol Edge 5w30 LL
'19 Dacia Sandero 0.9T - Shell Helix Ultra 5w40
'96 LR Defender 300TDi - Castrol Vecton 10w40
'03 Ford Mondeo ST220 3.0 V6 - Shell Helix Ultra 5w40
Re: Volvo S80. [Re: D1dad] #5142568
06/24/19 08:38 AM
06/24/19 08:38 AM
Ohio
D1dad Offline OP
D1dad  Offline OP
Ohio
It’s not the filter that’s the pain. It’s the drip pan and the 75 bolts they use to attach it. Doing it without a lift makes for a difficult job.
Re: Volvo S80. [Re: D1dad] #5142581
06/24/19 08:49 AM
06/24/19 08:49 AM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
Can you vacuum it out?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Volvo S80. [Re: D1dad] #5142582
06/24/19 08:49 AM
06/24/19 08:49 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Can you do it through an extractor, topside?
2018 KIA Sportage LX 2.4 AWD:
QSAD 5W-20, PH9688
2013 Hyundai Santa Fe Sport 2.0T:
PP 5W-30, OE
Re: Volvo S80. [Re: D1dad] #5142585
06/24/19 08:53 AM
06/24/19 08:53 AM
PimTac Offline
PimTac  Offline
Are there really 75 bolts holding up the splash shield?
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Volvo S80. [Re: PimTac] #5142593
06/24/19 09:08 AM
06/24/19 09:08 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Might not be much of an exaggeration. I've counted as much as 32 on some euro cars.
This is a job for an oil extractor.
Re: Volvo S80. [Re: D1dad] #5142598
06/24/19 09:16 AM
06/24/19 09:16 AM
Southeast
meep Online content
meep  Online Content
Southeast
In our volvos I've leaned towards the heavier - 10-30 and 0-40 oils. The OM on ours listed 40 weight as acceptable, and they stayed quieter on heavier oils when running the 7-10k OCIs we do in my home. Our S60s have 10 bolts I think for the splash guard and I usually drive them up on a couple of stacked 2x10s for a little wrench room. Yes, they take a little more time, as they have no ground clearance.
We do have a mityvac - and if your circumstances don't favor taking off the engine diaper, it's a no-fuss, almost relaxing way to go. Well worth the money, especially if you choose to change things like steering fluid and transmission fluid. I wore my first one out, gave it to a friend (they sell rebuild kits for them) and bought a second. Remember that these cars have a complex breather system that *will* punish you if you do not stay on top of oil changes and use a full syn oil.
https://www.amazon.com/Mityvac-7400-Liter-Fluid-Evacuator/dp/B000JFJM14/ref=sr_1_7?crid=34JM6HA086NLP&keywords=mityvac&qid=1561385818&s=automotive&sprefix=mityvac%2Cdigital-music%2C252&sr=1-7
-m
2018 F150
2015 crv (wifey!)
Re: Volvo S80. [Re: D1dad] #5142599
06/24/19 09:20 AM
06/24/19 09:20 AM
PimTac Offline
PimTac  Offline
Okay, I watched that video and see that the oil filter is accessible from the top.
Oil extractor is the way to go.
2017 Mazda CX5
Roki OEM filter.
Re: Volvo S80. [Re: meep] #5142627
06/24/19 09:49 AM
06/24/19 09:49 AM
Ohio
D1dad Offline OP
D1dad  Offline OP
Ohio
I had an s60 t5 for years and was one of the best cars I’ve ever owned. I believe the manufacture recommendation is 7500 which I always followed with a 6qt capacity. The 3.2 is non turbo and from what I’ve read on Volvo forums is rather easy on oil. My t5 oil was black as night when I drained as the 3.2 is still very clean at 10k. I know color means very little but clean oil gives me a warm and fuzzy as opposed to to the color of tar. Is valvoline or PP considered extended drain oils?
Re: Volvo S80. [Re: PimTac] #5142694
06/24/19 11:08 AM
06/24/19 11:08 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Another factory anti DIY effort by manufacturers.
2004 Corolla 134004
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 75175
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Volvo S80. [Re: JohnnyJohnson] #5142698
06/24/19 11:15 AM
06/24/19 11:15 AM
PimTac Offline
PimTac  Offline
It surely is. Volvo could have added a access panel but they didn’t. Many auto manufacturers do include them.
2017 Mazda CX5
Roki OEM filter.
Re: Volvo S80. [Re: D1dad] #5142720
06/24/19 11:30 AM
06/24/19 11:30 AM
Suburban Washington DC
atikovi Online content
atikovi  Online Content
Makes little sense to spend money for that on a $1,000 car. Put the money towards increasing the frequency if it makes you feel better.
Re: Volvo S80. [Re: D1dad] #5142738
06/24/19 11:57 AM
06/24/19 11:57 AM
South Carolina
ka9mnx Online content
ka9mnx  Online Content
South Carolina
My 4Runner had 2 front heavy skid plates. I never go "trailing". They were such a PITA I left them off.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Volvo S80. [Re: PimTac] #5142739
06/24/19 11:57 AM
06/24/19 11:57 AM
Ohio
D1dad Offline OP
D1dad  Offline OP
Ohio
Exactly. I’d ditch the diaper all together but there appears to be some sensitive parts on the bottom of the engine.
