BMW LL04 Dissapeering?
by Bailes1992. 07/19/19 03:51 AM
Which Synthetic Oil Do You Use, And Why?
by BlueOvalFitter. 07/18/19 10:50 PM
do laptop batteries really go bad or
by WhyMe. 07/18/19 10:32 PM
2016-2017 Chevy Equinox reliability
by gregk24. 07/18/19 10:12 PM
Mann HU816 x
by IllinoisSparky. 07/18/19 09:41 PM
Seafood Combo
by vavavroom. 07/18/19 09:37 PM
‘13 Silverado 1500 Extended Cab
by parshisa. 07/18/19 09:35 PM
Where to have a watch serviced?
by E150GT. 07/18/19 08:32 PM
Stubborn diff fill plug
by HoosierJeeper. 07/18/19 08:21 PM
Big score on auto parts clearance AAP
by Marco620. 07/18/19 08:05 PM
Would this cause my jeep to stall?
by MileHigh18. 07/18/19 08:00 PM
Looking for Highlander '06,'07, '09
by Gebo. 07/18/19 06:39 PM
'03 F150 Parking Brake Adjustment
by benjamming. 07/18/19 06:17 PM
Do You Still Change Your Oil at 3K?
by Gebo. 07/18/19 05:33 PM
Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
Raunper, OilDrinkingHemi, suuru, Hollicrev, Richb55
68704 Registered Users
31 registered members (53' Stude, ctechbob, Bailes1992, 2015Corolla, AlienBug, 6 invisible), 713 guests, and 21 spiders.
Topics292,061
Posts5,016,115
Members68,704
Most Online2,967
Mar 10th, 2019
engine air filters...all the same? #5138536
06/19/19 03:37 PM
06/19/19 03:37 PM
New Jersey
flinter Offline OP
flinter  Offline OP
New Jersey
Hi,
Im looking to replace the engine air filter in my 2017 Hyundai Elantra VE 2.0. Are engine air filters pretty much all the same quality? Is there really one brand far superior than other, or all the same quality? Just go to Wal Mart, pick one and be done with it?
Thanks
Michael
2017 Hyundai Elantra SE Value Edition
Purchased new with 10 miles
Re: engine air filters...all the same? [Re: flinter] #5138550
06/19/19 03:45 PM
06/19/19 03:45 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
The Fram air filters at WM are a good choice. Great fit and a little heavier than the oem ones. Fit and finish were very good unlike some of the ones I've seen at the auto parts store. thumbsup
Re: engine air filters...all the same? [Re: flinter] #5138554
06/19/19 03:48 PM
06/19/19 03:48 PM
CA
The Critic Offline
The Critic  Offline
CA
If the OE filter is oiled, I try to replace with the same.
Otherwise, I use aftermarket. But the filtering efficiency of air filter media does vary. How much it matters is hard to say...
2011 Toyota Prius 1.8L - 193K - Idemitsu ZEPRO Adv. Moly 0W-20
2007 Honda Accord 2.4 - 137K - Mobil 1 EP HM 5W-30
Re: engine air filters...all the same? [Re: flinter] #5138584
06/19/19 04:25 PM
06/19/19 04:25 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
When my '18 needs an air filter, I'm just going to pick up a FRAM from Wally World. FRAM filters have worked fine in my cars over the years.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: engine air filters...all the same? [Re: flinter] #5138591
06/19/19 04:36 PM
06/19/19 04:36 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
AC Delco, they do best in testing for diesels and a diesel is much more demanding on the air filter than any gas engine.
[Linked Image]
Re: engine air filters...all the same? [Re: flinter] #5138609
06/19/19 04:58 PM
06/19/19 04:58 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
Those test results are from a 2004 study. While I hope they are still an indication of quality, alas 15 yeas later outsourcing and companies quest to save money may yield different results today.
coffee
13 Civic Si 2.4L- 94Kkms(58Kmi)-QSUD,Wix
05 LeSabre 3.8L-274Kkms(171Kmi)-QSUD,Wix
03 Sierra 2500 6.0L-209Kkms(130Kmi)-QSUD,Wix
All with mpg > EPA
Re: engine air filters...all the same? [Re: flinter] #5138617
06/19/19 05:09 PM
06/19/19 05:09 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
There is a difference in quality. From one brand to the other, it's probably a crap shoot unless efficiency is published somewhere. Generally the higher priced / top tier filters will be better quality than the others.
For example, Carquest Red and Blue are different-- red being a paper element for my application and blue being a woven cotton type element. You'll find that cheaper filters generally are made cheaper, and more expensive ones made better.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 265k Chevron Delo LE 5w-40
07 Chrysler Pacifica Limited 4.0L 140k Belgian Castrol Edge 0w-30 Euro
Re: engine air filters...all the same? [Re: flinter] #5138628
06/19/19 05:24 PM
06/19/19 05:24 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
I would say they vary. I put a Napa (Wix) air filter in my 1999 Saturn and there was a 1 inch hole in a few thousand miles. Switched to Fram and never had issue for 200k. With my Elantra it will be OEM. If that was not available a Fram.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: engine air filters...all the same? [Re: Smokescreen] #5138742
06/19/19 07:51 PM
06/19/19 07:51 PM
Trav Offline
Trav  Offline
I am sure they are still good as they still make OE filters. I don't know anything about Fram air filters the does not seem to any sort of test with them. Delco or Mann is what I use mostly.
I have to question how anyone can say Fram or this one or that one works great other than the fit when there is no easily found data to prove it does or doesn't.
I suppose as long as its not a K&N most are all good.
Re: engine air filters...all the same? [Re: flinter] #5138745
06/19/19 07:56 PM
06/19/19 07:56 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
"I suppose as long as its not a K&N most are all good."
Yup. What he said.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: engine air filters...all the same? [Re: flinter] #5138787
06/19/19 08:49 PM
06/19/19 08:49 PM
south dakota
joekingcorvette Offline
south dakota
I usually go with Fram or Wix.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: engine air filters...all the same? [Re: flinter] #5138791
06/19/19 08:51 PM
06/19/19 08:51 PM
south dakota
south dakota
I should add previously I had a K&N on the Ford and the Honda and after reading about these on the forum I quit using the K&N. I never had any problems
with them but everyone on BITOG seem to believe the paper filters are better so I quit using the K&N reusable filters.
Re: engine air filters...all the same? [Re: flinter] #5138830
06/19/19 10:00 PM
06/19/19 10:00 PM
Mississippi
TheLawnRanger Offline
Mississippi
I use the microgard from O'Reilly most of the time. It "seems" to be doing its job as I rarely have one that looks dirty. I think a lot of it has to do with where you live. Even living in a mostly rural area like I do, I rarely get on a non-paved road.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: engine air filters...all the same? [Re: flinter] #5138870
06/19/19 11:17 PM
06/19/19 11:17 PM
D/FW Metroplex
The_Nuke Offline
The_Nuke  Offline
D/FW Metroplex
Run whichever one fits into your budget and don't try to clean any of them out (i.e. No vacuuming, no compressed air, no tapping on floor of garage) in between installation and replacement.
Doing that will ensure you never have a problem with the engine that is due to poor air filtration.
Also, submitting used oil samples for a UOA periodically will provide feedback on how well your filter is working. High silica means poor filtration or a leak in air intake somewhere. Low or no silica means you're doing good with current filter.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: engine air filters...all the same? [Re: flinter] #5138874
06/19/19 11:23 PM
06/19/19 11:23 PM
Trav Offline
Trav  Offline
Leaking PCV hoses and missing/broken o ring or seal on dipstick to tube connection are common unfiltered air ingress locations.
