SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Wix 51269 I think cut open
by Mightymouse - 01/23/20 04:08 PM
What oil for a new VW Beetle?
by widetrax - 01/23/20 03:52 PM
Lossless audio music
by Cujet - 01/23/20 03:38 PM
Castrol Edge on Rollback at Walmart
by Matt1980 - 01/23/20 03:35 PM
Regretted Selling a Car?
by RDY4WAR - 01/23/20 02:14 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
38 registered members (1911CHAMPION, Bailes1992, bernardch, 750IX, bachman, 7 invisible), 1,647 guests, and 22 spiders.
Topics300,482
Posts5,176,879
Members70,514
Fumoto valves #5136720 06/17/19 02:12 PM
cwilliamsws6 Offline OP
Are they worth the $28 price tag? They seem like a neat and easy way to drain the oil pan and definitely would save me from almost giving myself a hernia trying to bust my drain bolt loose, and I change my oil about 3 times a year because I drive a lot.
Anyone here have one and can chime in? Thanks!
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Fumoto valves [Re: cwilliamsws6] #5136726 06/17/19 02:19 PM
K
KrisZ Offline
K
I can't say how they perform from experience, but the last thread about it prompted me to look for one for my Grand Caravan and I found it for $18 and change from Amazon. I'm still waiting for next OC to install it.
I would look for a better price than $28.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Fumoto valves [Re: cwilliamsws6] #5136730 06/17/19 02:23 PM
rollinpete Offline
Your over tightening your drain plug.
If you have the clearance go for it.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 190k
03 Saturn Ion 2.2 L4 5spd 241k
Shell Rotella Gas Truck 5w30
PPHM 5w30
Currently under the influence of oil shocked2
Re: Fumoto valves [Re: cwilliamsws6] #5136753 06/17/19 02:53 PM
A
atikovi Offline
A
Common add-on with Honda Insight owners because of the magnesium oil pan that is easily stripped by careless oil change techs.
Re: Fumoto valves [Re: cwilliamsws6] #5136760 06/17/19 02:57 PM
J
JustN89 Offline
J
I have one on both of my vehicles and they're awesome. No leaks, no drips, and no worrying about crush washers or anything like that. I highly recommend them.
Re: Fumoto valves [Re: cwilliamsws6] #5136768 06/17/19 03:06 PM
blupupher Offline
I have one on my truck and Scion, and one going on the next oil change on the Hyundai.
I have had 4 other vehicles with them (Wrangler, Grand Caravan, Elantra and Trailblazer, no idea why I did not take them off when I sold them, I am sure the next owner probably tossed them).
The only con's I see is there could be clearance issues if it is a low vehicle and/or drain plug points downward, and it does drain a little slower than with the plug removed completely (but not that big of a deal for me as a DIY'er, an oil change place would probably hate it).
I know a few have said there could be "sediment" left in the pan since it raises the drain level 1/8" with the threads, but not a concern for me.
Also some are concerned with it getting "knocked" open, which would be very difficult, but they make a latch kit to prevent that if you are really worried about it.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Fumoto valves [Re: cwilliamsws6] #5136772 06/17/19 03:12 PM
P
Patrick0525 Offline
P
I like my Fumoto valve and it makes OC a breeze in sub-freezing temperatures. Tool-less and no more stripped drain plug threads.
Fumoto use to recommend a hose clamp to prevent accidental release of the Fumoto lever. The hose clamp is over-kill. I just use one those bread wire twist ties preferably made from paper. It works great and is a no worry consumable item if you drop it into the “Drink” .... drain pan.
Without crawling underneath, I just reached under and snapped a pic. Hopefully you see the white twist tie.
[Linked Image]
2014 Toyota Venza 2GR-FE 96K mi
2009 Lexus ES350 2GR-FE 49K mi
Fram Ultra filter XG9972
TGMO or Idemitsu Zepro 0w20 (winter)
PP 0w20 (spring/summer/fall)
Re: Fumoto valves [Re: cwilliamsws6] #5136804 06/17/19 03:36 PM
L
Lapham3 Offline
L
I use a few, but don't on others where it's too exposed. They're fine.
Re: Fumoto valves [Re: cwilliamsws6] #5136817 06/17/19 03:55 PM
E
earlyre Offline
E
had one on my sable. no drips, or leaks ever.
they do run a but slower than the open drain hole...
and if you take it to a shop to have the oil change done for whatever reason, be ready for them to refuse, citing liability if they couldn't get the valve to close.
"where did you get your oil changed last? Do you know you don't have a drain plug?"
I've done every oil change on this car since i've owned it...and yes, I installed a Fumoto Valve.
"well, without the standard drain plug, we can't change your oil. the Liability is too risky if we couldn't get the valve to close"
at which point i did a quick search of the car, b/c i had had the OE drain plug in the car a couple days before...but it wasn't there.
they did report a completed oil change to carfax though.. and tried to sell me an unneeded air filter for $26.(had a spare at home already, and I had installed a restriction gauge in the airbox. filter was slightly dirty, but in no way needed changing.)
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: Fumoto valves [Re: cwilliamsws6] #5136843 06/17/19 04:18 PM
Donald Offline
I have one on both Subaru vehicles but not the truck. I do not use anything to lift vehicle or ramps. Slide in drain pan, feel the Fumoto and open it. I only need to slide in a little.
However if the mounting position would cause the valve to be hanging down, easy for rock to rip off, then I would have to think again. In the Subaru it's in a nice little opening, well protected.
2015 Ford F-250 w/Powerstroke
Re: Fumoto valves [Re: cwilliamsws6] #5136885 06/17/19 04:59 PM
F
Flashlightboy Offline
F
I have a couple on two different cars, even low clearance and it's never been a problem in more than a decade of use.
Fumoto now makes the black plastic clip that slides into the slot on the valve to make sure it's highly unlikely for it to open, even if hitting something. I guess the the better way to say express it is to say that if something is under the car that opens the valve through some awefully weird actions, the rest of the car probably looks lik poo with lots of other damage, making my oil drain the least of my worries.
Re: Fumoto valves [Re: cwilliamsws6] #5136912 06/17/19 05:27 PM
B
bobdoo Offline
B
On 4 cars. LOVE them.
Re: Fumoto valves [Re: cwilliamsws6] #5136933 06/17/19 05:54 PM
cb_13 Offline
I've had one on my current truck for 3 years now. Love it. I just make sure to change the oil when the engine is hot. If I do an oil change on a cold engine it takes forever.
Re: Fumoto valves [Re: cwilliamsws6] #5137009 06/17/19 07:22 PM
T
tcp71 Online Content
Online Content
T
on our van since 2005. on both my trucks since 2011. Other than the drain speed, it's so much better. The new truck has one with a nipple and I've got a piece of hose permanently attached. I just pull the hose through a hole in the belly pan and direct the oil into a jug. Clean and practical. The van's is now 14 years old and going strong.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Fumoto valves [Re: cb_13] #5137029 06/17/19 07:37 PM
blupupher Offline
I am a change it cold person.
I just do other stuff while it drains (get oil and filter out, check coolant, washer fluid, etc).
