Rear Main Seal: Pre-Lubricate or install dry?
by WondrousBread - 10/22/19 01:38 PM
Credit Karma
by aquariuscsm - 10/22/19 01:20 PM
Does Fuel Dilution Leave Oil After Cause Resolved?
by LoneRanger - 10/22/19 01:11 PM
How do you select tires?
by ZZman - 10/22/19 12:12 PM
Shell TF-0870
by rooflessVW - 10/22/19 12:07 PM
Reverse tire look up?
by tiredguy - 10/22/19 11:35 AM
Oil consuming 2004 Mercury Marauder
by 2013ecof150 - 10/22/19 11:09 AM
2015 Triumph Trophy SE - Castrol 10W40
by Rick505 - 10/22/19 11:08 AM
need a mini van/suv for my son 10k
by BeerCan - 10/22/19 10:52 AM
Propene, polymer with ethene use in motor oil
by DrDanger - 10/22/19 10:29 AM
Wax recommendations
by dawgn86 - 10/22/19 09:46 AM
Oil and Filter Advice
by dawgn86 - 10/22/19 09:44 AM
Lift Master Remote RE-Programming
by Gebo - 10/22/19 09:10 AM
My '88 Daytona
by IronMaidenRules - 10/22/19 09:08 AM
QSUD and cleaning?
by irv - 10/22/19 08:56 AM
New 2019 Toyota Highlander first oil change
by thooks - 10/22/19 07:50 AM
2019 Golf R
by wings&wheels - 10/22/19 06:47 AM
My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
TV_Viewer2, Finner, blimo, Haiducek, NoRegrets
69642 Registered Users
112 registered members (2013ecof150, 67ZL1, 28oz, AdditiveOCD, 97f150, 6 invisible), 2,227 guests, and 27 spiders.
Topics296,330
Posts5,095,745
Members69,642
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Curious if any issues here. #5132482 06/12/19 04:43 PM
B
Bill_W Offline OP
B
Suppose you use a jug of oil just for a engine flush. Warm up the oil while still on the jack stands then drain back in the jug. Then install the normal oil you would use. Will that jug of oil be good to use for same purpose next oil change?
Slick
Re: Curious if any issues here. [Re: Bill_W] #5132490 06/12/19 04:57 PM
53' Stude Offline
Easy enough to lube hinges with or whatever. I'd give flush oil to friend for waste oil heater shop or dump it on waste oil tank at work wink
Re: Curious if any issues here. [Re: Bill_W] #5132519 06/12/19 06:02 PM
B
Brojo Offline
B
I wouldn't. If you're just using it as a flush I am assuming you are using something inexpensive like ST conventional. Not sure how many quarts you need (jug=5qt?), but I think I would just spend another $10-$15 on cheap oil next time I needed to flush again. For peace of mind.
Re: Curious if any issues here. [Re: Bill_W] #5132534 06/12/19 06:20 PM
SirTanon Offline
Why not put a cheap oil filter on there, run it for a week or two, then drain it out?
While we're here, what exactly are you hoping to accomplish with a short flush with cheap oil that a normal OCI with a "better" oil won't accomplish?
2013 Nissan Altima SV - 2.5 liter/CVT - 122,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 69,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Curious if any issues here. [Re: Bill_W] #5132540 06/12/19 06:35 PM
P
philipp10 Offline
P
Rather than do what your doing, just shorten your normal OCI. I cannot understand what you are trying to accomplish with this scheme.
Re: Curious if any issues here. [Re: Bill_W] #5132561 06/12/19 06:58 PM
J
John_K Offline
J
To me the whole point of a flush is to remove crud. So why would you save the crud and pour in again? shrug
2009 Mercury Grand Marquis, 8 cyl auto, 93xxx miles, PU/Fram Ultra
2005 Hyundai Sonata, 4 cyl auto, 99xxx miles, Maxlife/OEM Filter
Current oil stash: 459 qts.
Re: Curious if any issues here. [Re: 53' Stude] #5132575 06/12/19 07:14 PM
DoubleNickels Offline
Originally Posted by 53' Stude
Easy enough to lube hinges with or whatever. wink
That is a lifetime supply of oil for door hinges.
Re: Curious if any issues here. [Re: SirTanon] #5132582 06/12/19 07:24 PM
B
Bill_W Offline OP
B
The oil I want to use is Zepro with moly. I have Castrol Edge, which is a pretty good oil and recommended by Mazda. I was thinking about for the first oil change in my 2019 Miata I would try that to get all the break in nasties. Install the new filter before the flush. Since I am installing a Fumoto drain valve I can run a clean tube in to the jug and drain it in there. Fill the jug to top with oil and let any containment settle for next oil change. Kinda anal but like a mouthwash for my engine. While the car is on the jack stand should not take too long.
Slick
Re: Curious if any issues here. [Re: Bill_W] #5132583 06/12/19 07:26 PM
donnyj08 Offline
I don’t see any reason to use any clean oil to flush an engine. If you definitely need a flush use an engine flush before changing the oil.
2008 Silverado Z71 LT 99k Maxlife FS 5w30
2010 Ford Escape 199k QSUD 5w20
2016 Tucson Limited 1.6T AWD 27K A5/B5 5w30
2016 Yamaha XSR900 13k, Spectro 10w40, Yamaha Filter.
Re: Curious if any issues here. [Re: DoubleNickels] #5132587 06/12/19 07:31 PM
53' Stude Offline
Better to have some oil than no oil wink
Re: Curious if any issues here. [Re: Bill_W] #5132598 06/12/19 07:42 PM
K
kstanf150 Online Content
Online Content
K
Hey Stude
How’s the beach ???
If OP wants a flush oil
I found this at my local grocery for buying the best ribeye in town 👍
Re: Curious if any issues here. [Re: Bill_W] #5132604 06/12/19 07:46 PM
CR94 Offline
Besides the other reasons that exercise would be illogical, it would be difficult to avoid contaminating the "flush" oil with dirt off the underside of the engine and surrounding parts. Better and easier to simply do a short change interval, if needed.
2011 Toyota Prius now at 104K
Re: Curious if any issues here. [Re: Bill_W] #5132612 06/12/19 07:52 PM
T
Triple_Se7en Offline
T
At what vehicle mileage will that first oil change be at?
If you are changing that new oil at 1-2K, then there's no need for a flush soon after.
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Curious if any issues here. [Re: kstanf150] #5132616 06/12/19 07:58 PM
53' Stude Offline
Originally Posted by kstanf150
Hey Stude
How’s the beach ???
Beach is nice, I find that oil for $2.99 a quart all day at my Rural King in 5w20 and 5w30
Re: Curious if any issues here. [Re: 53' Stude] #5132619 06/12/19 08:02 PM
T
T
Hey Stude
How’s the beach ???
Just all day?...... not at night too? Have you been there after midnight to check-out the price? Does Rural King raise the price when you turn off your bedroom light and hop in bed?
Page 1 of 3 1 2 3
