Rental review : 2019 Dodge Charger
by FirstNissan - 08/20/19 12:14 AM
Truck diesel oil in Lawn mower (SAE30)
by Polyalphaolefin - 08/19/19 11:18 PM
Pinstripes Not Popular on Pickup Trucks?
by LoneRanger - 08/19/19 10:04 PM
More choices
by KeithS_NW_Ohio - 08/19/19 09:43 PM
INEOS to Surpass EXOM in PAO production.
by MolaKule - 08/19/19 09:17 PM
Need a miter saw
by JLawrence08648 - 08/19/19 09:01 PM
Using a 7.1 receiver with only 2 speakers
by Papa Bear - 08/19/19 08:44 PM
HD Sportster 5000 mi Red line PS 20w-50
by shanneba - 08/19/19 07:17 PM
College Football Time
by kstanf150 - 08/19/19 07:17 PM
Eco Plug oil drain plug
by passgas55 - 08/19/19 07:15 PM
Pep Boys Deals
by kstanf150 - 08/19/19 06:43 PM
MB229.5 and MB229.51
by Tikka - 08/19/19 06:35 PM
2019 Mazda 3 Recall....Wheels fall Off!
by Boomer - 08/19/19 05:43 PM
Rut Roh!😂
by Mad_Hatter - 08/19/19 04:40 PM
Oil for vintage Mopars
by 440Magnum - 08/19/19 04:37 PM
M1-102 vs M1-103
by Deontologist - 08/19/19 04:06 PM
Why no love for M1 gear oils?
by zuluplus30 - 08/19/19 03:02 PM
2005 Chrysler 300 HEMI cam position sensor diagnosis
by 53' Stude - 08/19/19 02:38 PM
Noisy idle in gear but not neutral or park
by cwilliamsws6 - 08/19/19 02:30 PM
Brandon86, smartd_e, serhat, BlueSky, 444samc
69000 Registered Users
34 registered members (53' Stude, billt460, Bailes1992, 8 invisible), 645 guests, and 20 spiders.
Topics293,544
Posts5,042,090
Members69,000
Most Online3,532
Jul 30th, 2019
2002 Suzuki Vinson Rear Rotor #5130621 06/10/19 06:32 PM
R
Recalculating Offline OP
R
This ATV has near 2000 miles on it. Good running.
I have purchased a new rotor, pads and replacement bolts.
As shown in the photos, the hex mounting bolts have been rounded off and are solidly corroded in place.
Is the only answer to remove the rounded off bolts is grinding the heads off and what remains use locking pliers, penetrating oil and heat?
25FD9094-BE6E-499D-A1BB-9072F053D929.jpeg372DF11C-1F46-4D8B-B32E-33889BBD0598.jpegEFFC2DC5-AD36-4A13-B5B8-5F5E84FABB2B.jpeg
2009 Honda CR-V EX-L 59k
2007 Buick Lacrosse 59k
2008 Ford Ranger XLT V-6 4.0 SOHC 75k
Re: 2002 Suzuki Vinson Rear Rotor [Re: Recalculating] #5130711 06/10/19 07:44 PM
I
Imp4 Online Content
Online Content
I
Flat head cap screws are typically easy to drill out because the head is so low profile.
I just use a drill bit equal to the screw major diameter and it's easy to pop the head off.
Then some PB Blaster and a beer break.
Follow up with some vise grips and it usually loosens.
Otherwise, drill the whole bolt out using a drill bit 1/64" under the tap drill size and run a tap down the threads.
Things can get dicey if your drill walks off center...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: 2002 Suzuki Vinson Rear Rotor [Re: Recalculating] #5130725 06/10/19 07:56 PM
Saul Offline
I would use stubby easy out first, hammer a close size in, no drilling. If that doesn't work then I would take the head off. If the shank won't come out with the head off I would then easy out that.
This or similar. There are also chinese kits if this is a one time use tool.
https://www.amazon.com/Irwin-Tools-...mp;psc=1&refRID=WNBJFXDX1NEFV191DKQT
Re: 2002 Suzuki Vinson Rear Rotor [Re: Recalculating] #5130807 06/10/19 08:57 PM
R
racinjason Offline
R
Weld a nut to them. If you can, drive it down then weld it. Heat will help loosen it up also.
If you don’t have a welder, get the drill out.
Re: 2002 Suzuki Vinson Rear Rotor [Re: Recalculating] #5131759 06/11/19 09:00 PM
R
R
No welding so I will drill the flat head off the four and tackle the leftover stubs.
Thanks for the suggestions BITOG.
