This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
oilylp, Motorapido, TyMillerfc, AcadiaDave, lmt1911
70106 Registered Users
52 registered members (bbhero, aquariuscsm, BLND1, BlakeB, bdcardinal, Bailes1992, 3 invisible), 1,150 guests, and 27 spiders.
Topics298,605
Posts5,139,019
Members70,106
Most Online3,589
Nov 2nd, 2019
SN-Plus VS Dexos1-GEN2 #5131126 06/11/19 07:13 AM
Y
yowps3 Offline OP
Y
Which is better at eliminating LSPI, IVD and turbocharger coking?
Assuming only one could be chosen over the other..
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5131132 06/11/19 07:21 AM
K
ka9mnx Offline
K
D1G2
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5131134 06/11/19 07:28 AM
R
Rand Offline
R
Assuming you dont breathe air which would kill you first, snakebite or a nuclear bomb 10miles away.
Most/all D1G2 oil should be api SN+ so you never have to choose.
Chrysler MS-13340 is a similar spec(gdi turbo lspi) for the 2.0t engine
however only Pennzoil Platinum has that spec so its not much help unless you are a PP fan.
API SN+ isnt as stringent as d1g2 or chrysler ms-13340
However API SN+ has a wider viscosity range than D1G2
and D1G2 is a paid spec.. they have to pay GM to put it on the bottle.
so there may be other reasons why an oil is api sn+ but not d1g2, you cant automatically assume its inferior.
Re: SN-Plus VS Dexos1-GEN2 [Re: Rand] #5131137 06/11/19 07:30 AM
F
Floyd1 Offline
F
Any D1G2 oil should be api SN+ so you never have to choose.
Chrysler MS-13340 is also a similar spec for the 2.0t engine
This is what I was wondering. Is it possible to even get one without covering the other?
Re: SN-Plus VS Dexos1-GEN2 [Re: Floyd1] #5131155 06/11/19 07:46 AM
V
Virtus_Probi Offline
V
Well, one difference I know off the top of my head is that the max Noack loss for d1G2 is 13% while it is 15% for SN+.
So, an oil could meet SN+ but fail for d1G2 on the basis of that measurement.
It is also my understanding that SN+ doesn't include a turbo deposit test like d1G2 does.
I guess I might be a tad suspicious of an oil that is SN+ and not d1G2 UNLESS it is a grade that is not covered by d1G2...like the 10W30 I am running now.
This is the first non-d1G2 oil I have run since I bought a bottle of M1 5W30 AP because it was the only oil on the WM shelf that had a d1G2 license number! Didn't say Gen 2 on the front because the standard was not "live" yet...Gen 2 is a superset of dexos1 so it met the standard claimed on the bottle by default.
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: SN-Plus VS Dexos1-GEN2 [Re: Virtus_Probi] #5131181 06/11/19 08:17 AM
SubieRubyRoo Offline
An oil manufacturer may not want to pay the dexos royalties on their SN+ oil... and regardless, dexos is only "required" by GM. You have to make the personal choice of this; with a 5 year old vehicle either SN+ or d1G2 will exceed your engine's oil requirements.
OP, by adding what engine you are talking about, you will likely get better recommendations than just the nebulous question you asked.
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5131184 06/11/19 08:19 AM
Snagglefoot Offline
Correct me if I am wrong but a 10w30 can be SN+ but not D1G2. Also, lower calcium is a big player with SN+.
If you want the job done right......do it yourself.
Re: SN-Plus VS Dexos1-GEN2 [Re: Snagglefoot] #5131206 06/11/19 08:37 AM
V
V
Yeah, my M1 10W30 HM I am running now cannot be d1G2 by the definition of the standard...but it is SN+.
Last Change;
PP 5w30 d1G2
Re: SN-Plus VS Dexos1-GEN2 [Re: SubieRubyRoo] #5131216 06/11/19 08:57 AM
V
V
I guess I don't really trust Subaru's oil recommendations after they had to recall the FA20DIT engines due to LSPI as well as carbon buildup issues...I only got new plugs and a new ECU program, but some people had engine damage and many others got a free chemical cleaning (no walnut blasting AFAIK). I had already been running M1 5W30 for some time and was glad for it...I'm sure Subaru changed the engines to run a little richer at LSPI danger points as I understand that is supposed to help prevent it, but I'm still going to do whatever I reasonably can to limit the chance of LSPI with my maintenance choices. I don't think Subaru ever updated their oil recommendations for the FA20DIT, unlike GM which was calling out either AC Delco or M1 5W30 specifically after their 1.5l DIT debacle (I would imagine since changed to d1G2).
Like you said, personal choice...I'm sure plenty have people have been putting whatever they want in FA20DITs with no issues.
As evidenced by my present oil, I'm fine with SN+ alone...I just think that I might shy away from a 5W30 that was only SN+ and not d1G2, it would be so easy to get a 5W30 with both.
Last Change;
PP 5w30 d1G2
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5131220 06/11/19 09:02 AM
csandste Offline
So I make two semi syn oils that I want to differentiate by price. I pay D1g2 fees on one and slap semi syn on the label ... and charge extra for it.
2017 Kia Soul Plus-- VWB 5w30+ a bit of Harvest King syn 5w30-- 70,000 miles
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5131221 06/11/19 09:03 AM
slacktide_bitog Offline
d1g2
You know that d1g2 encompasses SN+, right? smirk2
You might also want to consider dexos2 if you desire a thicker oil. dexos2 is like C3 and is used for all GM cars in Europe, gas/petrol and diesel. In the US, GM only uses dexos2 for the Cruze diesel and C7 Corvette
Re: SN-Plus VS Dexos1-GEN2 [Re: slacktide_bitog] #5133720 06/13/19 10:49 PM
V
vsssarma Offline
V
Typical specification of dexos 1 PCMO available is:
API SN Plus RC (RC = Resource Conserving)
GM dexos 1 Generation 2
GM 6094M
Chrysler: MS-6395
ILSAC GF-5
Ford WSS-M2C947-A (0W20)
Ford WSS-M2C947-B1 (0W20)
https://www.mobil.com/english-us/passenger-vehicle-lube/pds/glxxmobil-super-synthetic
dexos 2 is more focused on Diesel Engines. dexos 1 is a PCMO.
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5133755 06/14/19 01:07 AM
O
OilUzer Offline
O
Didn't some experts say in Europe they don't have/use d1g2 or d2 and they have no lspi issues?
I think they use thicker and/or higher hths oil!
Re: SN-Plus VS Dexos1-GEN2 [Re: OilUzer] #5133759 06/14/19 01:55 AM
W
weasley Offline
W
On the contrary - GM brands here issued a service bulletin a while back requiring certain gasoline-engined cars to use dexos1g2 to mitigate LSPI. This was slightly inconvenient as most oils here were dexos2, with few d1g2 options available.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: SN-Plus VS Dexos1-GEN2 [Re: yowps3] #5133818 06/14/19 05:35 AM
Solarent Offline
Both options have LSPI testing - GM uses the GMOD, and SN+ uses the Sequence IX which is a Ford engine.
Eliminating LSPI is an interesting part of this question. Lubrizol has been out in the market talking about LSPI protection on used oil (both the tests only
look at LSPI protection on new oil).
Lubrizol Podcast on LSPI
